04-06-2006, 12:06 PM
I know this has been talked about to death but I am having problems with the driveline shops getting my setup right.
I have a 1980 Jeep Wagoneer Custom Ltd. AMC 360, TF727, NP208, SOA D44 Front and Rear Shackle Flip AMC20 Rear with 63" Chevy springs.
I got all the measurements they asked for and this is what I have. (These are all the angles the yokes will work at)
Front Diff 15 deg
Front T-case 30 deg
Rear T-case 12.2 deg
Front drive shaft tube slope 26 deg
Rear drive shaft tube slope 19 deg
Rear Diff 12 deg
Is this normal?
What does everyone else have?
04-07-2006, 12:16 AM
i have dana's 'expert' and allison's driveline programs both on my PC here at work..
i dont like the 5 degree difference in the front DL angles... but isnt the t-case end a CV joint?
i will have all your angles on a sticky-note here in a few.. i will keep track of this post and run the drivelines when we have numbers nailed down...
peace,
Dave
There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
04-07-2006, 12:19 AM
hey, looking at your numbers on paper, i think the rear stuff is fine going down the road...
i will run the program at lunch... can i clarify the t-case angle, i want the angle it sits at, and around here we just use the frame as the 'Zero' line... you can get the angle of the t-case output by just using the angle on the yoke bolting surface, and translate it 90 deg.
let me know when you can.
peace,
Dave
04-07-2006, 01:17 AM
Thanks man.
The front is a CV setup. I can't get to the truck today, but when I do I can get that corrected angle for you.
04-07-2006, 01:39 AM
ok, looking at the note again, you have a 4 degree difference between front pinion angle and driveshaft angle... they should be as close to 'zero' as possible, since you have the CV at the t-case.. 4 deg probably wont hurt much... (part time, right?) but if there was an EASY way to get the front shaft and front pinion closer i would do it.. assuming it didnt wreck your caster..
will fire up the DL programs in about 2.5 hrs local time..
also, projected road speed / gears / tire size (or save me a few minutes and work that all out to a driveshaft max RPM please)
thanks
peace,
Dave
[ April 07, 2006, 07:39 AM: Message edited by: rustywagoneers_com ]
04-07-2006, 02:56 AM
I will be running it ont he highway and trails. The diffs are stuffed with 4.10's and I have 35" tires on her (but they measure 33" high, that will change soon)
I can't figure out the D-shaft speed but I have found a online calculator to help.
http://www.wallaceracing.com/driveshaftspeed.htm
Now for the engine speeds....hope these help.
Highway Table
Transmission Gear: top gear (1:1)
Transfer Case: high (1:1)
mph rpm
50 1968
51 2007
52 2047
53 2086
54 2125
55 2165
56 2204
57 2244
58 2283
59 2322
60 2362
61 2401
62 2440
63 2480
64 2519
65 2558
66 2598
67 2637
68 2676
69 2716
70 2755
71 2795
72 2834
73 2873
74 2913
75 2952
Total gear ratio: 1:4.1
Stoplight Launch Table
Transmission Gear: 1st gear (1:2.45)
mph rpm
1 96
2 193
3 289
4 386
5 482
6 579
7 675
8 771
9 868
10 964
11 1061
12 1157
13 1254
14 1350
15 1446
16 1543
17 1639
18 1736
19 1832
20 1929
Total gear ratio: 1:10.04
Crawling Table
Transfer Case: low (1:2.61)
mph rpm
1 252
2 503
3 755
4 1007
5 1258
6 1510
7 1762
8 2014
9 2265
10 2517
11 2769
12 3020
13 3272
14 3524
15 3775
Total gear ratio: 1:26.22
04-07-2006, 04:36 AM
ok, looking at a max shaft speed of 2500 RPM, it appears that the maximum accelerations of the shaft (inertial effects) are just barely exceeding dana's safe limits of 1000 radians per second squared.. (1025.4 R/S/S on the one which goes out, and 967.5 R/S/S on the other)
the torsional effects are very low, (57.9 R/S/S) because the T-case and Pinion are so close on angle.. basically i think the rear is not a problem at all going down the road, and if you feel some vibration at 70, back it down a few..
the front i cannot check easily, but if you have a full-time t-case, or drive plates instead of lockouts, let me know an i will figure a way out..
peace,
Dave
04-07-2006, 11:27 AM
I just talked to Arizona Drivelines and they tell me I can possibly get away with the Bad Boy Jr CV that operates at 40 deg and locks out at 60 deg. This is way freaking cheaper than the $1200 CDN I've been quoted in the last little while, and they can't guarntee it holding up.
Would it be worth it to shim the front axle? I have 8 deg shims but I've been haring that that is a no-no. Thought I know a guy that had them in and it drove fine on the highway @ 70MPH.
The shafts at Arizona Driveline would be the Bad Boy Jr CV with long splines and the rear having a CV. The complete setup would run me about $800 US opposed to a local shop that can only lengthen mine for $650 US and tell me how to grind out the CV to make it droop more.
Think that is a good deal?
04-08-2006, 05:03 AM
if you go CV on the rear, the you need to rotate the pinion angle up to match the driveshaft angle (theroetically at least) i dont think you have an angular problem at all in back.
i think 15 degrees is fine for the stock CV, if it isn't then change it
my big question is if the front driveshaft will be turning when you are on the highway
full time t-case? driveplates or lockouts?
that's what we need to know next.
peace,
Dave
04-09-2006, 03:27 PM
The t-case is a part time case and I have lockouts.
The angel finder on the frame is sitting at 2.5 deg and the rear t-case output is sitting at 87.5 deg.
04-10-2006, 01:38 AM
just looked at sticky note again, and then had to check first post..
i was wrong on front shaft details... (i was looking at the 26 and 30 and thinking, good... but they are not numbers that go together... the 15 and the 26 do... not so good..)
how did the shaft wind up at 15, and the diff at 26?? how hard will it be to get them closer??
good thing it is part time...
drive it and see what the rear is like, we can tackle the front later....
peace,
Dave
04-10-2006, 01:42 AM
The stock front shaft isnt a CV, its a double carden joint, and doesnt have near the operating angle of a CV.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
04-10-2006, 04:11 AM
yes, technically the name is double cardan joint, however, i dont really feel like typing it out each time. the resulting output is constant velocity, even though a ball type CV joint has a greater operating angle.
peace,
Dave
04-10-2006, 05:41 AM
Jeep Doctor
Front Diff 15 deg
Front T-case 30 deg
Rear Diff 12 deg
Is this normal?
How can your front and rear transfer-case outputs be at different angles??? Unless you bent your transfer-case, the angle of the rear output should be the opposite of the angle of the front output. So, if your rear output points 12º down from horizontal, your front output is going to have to point 12º UP from horizontal.
You are using a magnetic angle-finder flush to a surface perpendicular to the yokes, right?
04-10-2006, 05:50 AM
peace,
Dave
Its not a consant velocity though, the input and output of the joint rotate at different speeds.
Bob: I believe he is measuring the drive shaft angle in relation to the t-case. So the angles should be different, as the shafts are different lengths.
04-10-2006, 07:03 AM
well, i don't think there is any way to say 'yes a double cardan joint has the input and output at the same speed' without having this thread turn into another 'have you ever seen an SOA' thread...
so i will allow you to believe that they rotate at different speeds..
peace,
Dave
04-10-2006, 02:31 PM
Yeah Bob, I have the angles that the u-joints will be working at.
The angles that the pinions are at:
Front axle: 9 deg up
Front of t-case: 5 deg up
Rear of t-case: 5 deg down
Rear axle: 6 deg up
And as I stated before potential tube slope angles; front 26 deg and rear 19 deg.
Sorry about the confusion.
04-11-2006, 07:05 AM
OK.... 5 deg at tcase Rr (dn) and 6 deg at Rr Pinion (up) is good.... however... 19 degrees for the driveshaft is not good...
exceeds dana's recommendations by about 4 times..
the front of 26 means your included angle between the t-case and the driveshaft up front is like 31 degrees... that has to be way near the limits... if not out of the limits for the double Cardan on your truck..
i sure wish the pinion and t-case were in that 12 neighborhood from before...
big lift = big $$$ at some point...
peace
Dave
[ April 11, 2006, 01:06 PM: Message edited by: rustywagoneers_com ]
04-11-2006, 11:26 AM
If I use that Bad Boy Jr CV 40 deg operating angle and 60 deg max, would that take care of the front issue?
Again thanks Dave for all the input!!
04-12-2006, 04:09 AM
yep, that is a 'twin-ball and centering plate style double cardan joint' (sec 3.2.4 of the SAE manual AE-7) high angle driveline and a few others are making / using them.. i still think you are gonna hafta rotate the rear up to match (nearly match) the driveshaft angle and run a CV at that end also (double Cardan)
looks like that is an entirely welded assembly from what i can see... welded yoke to flange.. and the centering plate is in a welded housing too.. SAE considers them to be a low-speed device, but for front i am sure you would be fine.. the rear should probably be more normal..
back to the front.. you could probably use that joint at one end, and the stock double Cardan at the t-case and just remember not to leave the front locked on the highway.. no more messing with angles...
the rear... well... you could drive it and see how fast you can go before it gets shaky.. but remember, forces rise at the square of RPM... so going from 1000 to 2000 is double the speed, but 4 times the destructive force... so be dang careful.
peace,
Dave
