Old 09-08-2003, 01:31 AM
Merc69's Avatar
Merc69 Merc69 is offline
Question
With the costs and headaches trying to find a Ford Dana 60 front end I have been thinking of converting to a passenger-side drop and use the front end out of a Chevy. I have had better luck finding the military axle combos in my area.
So I have the 727 transmission and a 208 t-case. Someone is telling me that by using the t-case out of the military doner I can use the back half to eliminate the SYE and then use other various parts from my 208 to make it fit the 727.
What headaches am I setting myself up for.
Thanks
Old 09-08-2003, 01:38 AM
Crazy_Jeepman's Avatar
Super Moderator
Sloppy Shifter
I looked into this and I am going to do the same thing, KINDA. From what I learned the parts between all NP208's are interchangable. I plan on swapping in a TH400 Trans and Keep the Jeep NP208, but use the TailShaft from a Chevy TH400 that was in front of a NP208, and swap the Input Gear on the Jeep 208 from a Chevy NP 208 that was behind the Chevy TH400. From what I have looked at so far none of this mix n match is a big deal............But then that usually is how all nightmares start!!!!
Old 09-08-2003, 01:47 AM
Will Morris Will Morris is offline
Well, it's not quite that easy. I checked into this option a while back and although the Jeep version is heavy duty with 32 spline outputs and a fixed yoke, the front ouput is on the driverside as opposed to the Chevy passanger side. Another member looked at both cases and found that by using the back half of the Jeep case, you would have to flip it upside down which presented a problem because one of the oiling holes no longer lined up. He then suggested I use a Dodge NP208 for slip yoke elimination, since the Dodge NP208s are fixed yoke passanger side drop. Since you're running a TF727 instead of a TH400 like me, you should just run the Dodge NP208. I wouldn't think you would need an adapter since it's the same case, but the input spline count may be different. Hope this helps.
Will
'78 Cherokee NT in GA
'79 J10 Golden Eagle in UT
Old 09-08-2003, 01:25 PM
scotty's Avatar
scotty scotty is offline
all youve got to do is swap in the jeep 23 spline input gear,and the jeep output shaft and rear housing. AFAIK,youwont have to use the whole rear half of the jeep case.
nother option would be to use a dodge 205,wich will also have the round pattern and 23 spline input. much stronger than the 208,IMO,and twinstickable [img]smile.gif[/img]
the other thing to consider is the fact that the transfer case will now occupy approximately the same location as the catalytic convertor,so youll need to reroute exhaust.
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 09-09-2003, 04:35 PM
Max Power's Avatar
Max Power Max Power is offline
y'all are crazy! square peg-round hole situation, it can be done, but why not get a round peg??
______________________________________
Cheers,
Robert
www.rbk3.com/fsj
1980 Jeep Cherokee Laredo WT 360/727/208
1980 MBZ Euro 300D 4-speed manual - Oil Squeezer
1984 MBZ Euro 300D 5-speed manual - Oil Squeezer
Old 09-09-2003, 11:32 PM
Merc69's Avatar
Scotty...what catalytic converter
It appears way to much to do this in a practical manner. I guess the search for the elusive Ford Dana 60 continues [img]smile.gif[/img]
Old 09-09-2003, 11:57 PM
scotty's Avatar
Talking
here is a pic of a d300 in my 85 GW,showing the flexi-pipe fromthe factory headpipe to the factory muffler. cat is not neccessary for 'wheelin
round hole,square peg? ive never been sorry i swapped out my driver side diff. swapping in a chebby 60 is not going to be any more work than swapping in a ford 60.
scotty
85 grand wagoneer
38" TSL SXs
Old 09-10-2003, 01:43 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
To swap the passenger drop in the exhaust manifolds will probably also have to be swapped as I believe the changed when the drop did to allow clearance for the drive shaft.
Olympic 4x4 in WA recently had a bunch of Ford high pinion D60s for $1,500.
