06-20-2001, 10:02 PM
GRUMPY
YOU PUT THAT,I'LL CALL IT STUFF*** ON A NEW GASKET...I SAW A POST THAT SOMEONE PUT THAT STUFF**** ON A DIFF COVER......... I DON'T GET IT..I ONLY USE TACK TO HOLD A GASKET...IF THE COVER IS TRUE AND CLEAN AND IT WAS NOT LEAKING BEFORE YOU REPLACED THE GASKET...WHY USE IT????I KNOW YOUR GOING TO SAY THEY TELL YOU TO USE IT...I JUST NEVER USE IT.....I'M TALKING ON A GASKET...NOW!!!!!.. PS MY GASKETS DON'T LEAK!!!!!
[ July 30, 2002, 02:22 PM: Message edited by: GEMOBX/77/401 ]
06-20-2001, 10:21 PM
.....WHAT'S TACK ????
06-20-2001, 10:33 PM
GRUMPY
HI!!!THERE ROB...TACK,,IT COMES IN A SPRAY CAN...RED GLUE TYPE STUFF....SPRAY ON THE GASKET SO IT STAYS IN PLACE WHEN YOU PUT THE PART ON....ME... I USE 3M SPRAY GLUE...... IT NO MOVE!!! THE IDEA IS TO KEEP THE HOLES LINED UP!!!!!...GARY... HAVE A NICE DAY!!!
06-20-2001, 10:40 PM
you tell em gary i don't like to use that stuff anyway just on the end seals on intakes and thats only cause the little rubber strips ALWAYS seems to ooozzzzzzz there way out espescally theback one
"If a jeep can't take you there, maybe you should think twice about going" visit the C.O.R.E. homepage
06-20-2001, 10:49 PM
GRUMPY
I KNOW WERE AND WHAT YOU MEAN.. I CAN UNDERSTAND THAT..IRONROAD.......GARY..
06-21-2001, 01:20 AM
I AGREE WITH YOU GARY.
EVERYTHING I HAVE READ & HEARD, INCLUDING AN EMPLOYEE OF FEL-PRO, SEZ TO ONLY USE AN ADHESIVE TO HOLD GASKETS IN PLACE. I CAN NOT IMAGINE WHY USE IT ON A DIF COVER, BUT I SAW A MECHANIC USE THE SPRAY VERSION TO DO JUST THAT LAST WEEK. HE BELEIVED IT WOULD HELP SEAL OVER ANY IMPERFECTIONS. BUT, AS YOU HAVE INDICATED, THAT IS NOT WHAT THAT STUFF DOES.
IT WAS VERY GOOD (BRUSH-ON STYLE) TO HOLD THE OIL PAN GASKET TO THE BLOCK WHEN I WAS INSTALLING MY OIL PAN.
360 727auto-trany, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
06-21-2001, 02:54 AM
GRUMPY
NOGRAIN....HI!!.....10-4 ON THE BRUSH TYPE...I JUST SPARY THE GASKET LET IT SET... THEN STICK IT ON....GARY
06-21-2001, 03:10 AM
dry gaskets were meant to be used dry. if not, the stuff would come with, or on the gasket.
tucsonrick
69'wag (mostly stock)
06-21-2001, 03:51 AM
Jeep Idiot
THE SILLY PUTTY IS THE MOST OVER AND MISUSED STUFF IN THE AUTO REPAIR WORLD. I EITHER USE SPRAY TACK OR BRUSH ON FORM A GASKET IF SOMETHING MORE IS NEEDED. THE FUNNIEST ONE I EVER SAW WAS THE GUY THAT REBUILT HIS BEETLE MOTOR USING RED RTV AND WONDERED WHY THE MAINS RATTLED. HE HAD AT LEAST .020" CLEARENCE ON THAT SUCKER DUE TO THE THICKNESS OF THE RTV BETWEEN THE CASE HALVES. HE BROUGHT IT IN CUZ HE COULD NOT FIGURE WHY HE HAD NO OIL PRESSURE AND A LOUD KNOCK. I USE LOCKTITE GASKET ON VW'S.
65 wag. 360/edelbrock rb4/t400/20 t-case/4:10 d27/d44 broken power lok/onboard air/onboard 110v power(no inverter)/1999 Lincoln t.c.leather buckets/Lincoln ctr console/winch/33x12.50/tunes/water proof door pads
soon to have new motor/d44frt/d60r(4:10)welded diff/custom bumpers
see ya in da mud
06-21-2001, 05:38 AM
GRUMPY
MR.RICK AND MR BOB...RIGHT ON!....... BUT!!!........... THE GUY AT THE AUTO PARTS****...""OH!! SIR, YOU'LL "NEED" A TUBE OF THIS FOR YOUR GASKETS"".....I DO ??.... GIVE ME A TUBE THEN!!!.......GARY
06-21-2001, 01:55 PM
I used to goop the stuff on everything I bolted together. That is, until I had to DISASSEMBLE those parts later, and clean all that gasket-goo off!
Now I spend the time on cleaning and flattening the mating-surfaces, and installing the gasket dry. If the surfaces are clean and straight, no leaks. And if I have to disassemble the parts later, I can usually re-use the gasket.
Bob Barry<UL TYPE=SQUARE>* '78 Cherokee 4-door
* '88 Grand Wagoneer[/list] http://studentweb.providence.edu/~rbarry/wheels/
06-21-2001, 02:28 PM
GRUMPY
MR BARRY..I'M NOT KNOCKING THAT STUFF..BUT I REMEMBER ONE TIME I USED SOME ON MY HEADERS...YOU KNOW THE KIND THAT LEAK>>>>>THEY WERE DRIVING ME CRAZY THEY KEEP BLOWING OUT,SO I PUT DOUBLE GASKETS ON AND A TUBE OF COPPER HIGH TEMP STUFF...IT STOP THEM FROM LEAKING...IT WORKED GOOD THERE!!!....
[ July 30, 2002, 02:24 PM: Message edited by: GEMOBX/77/401 ]
06-21-2001, 02:57 PM
Shade Tree Shaman
rtv sealant is the greatest for drainlines in the house. i like gaskets, making them is a craft ive worked at for years. i gotta waterpump rtv'ed to the original motor to my 88 wag. that pump does'nt need bolts  if the mating surfaces are flat ...
'88 gwag,pure stock
07-30-2002, 08:19 AM
GRUMPY
WHAT'S OLD IS NEW..FROM LAST YEAR [img]smile.gif[/img]
