11-01-2001, 03:26 PM
I'm considering using the 4l80e trans and np241 T-case from a '94 1ton chev Behind a mild 454 in my 82 J10. It's part time, aluminum case and is chain driven. Low range is 2.72:1
If anyone has info, I'd like to hear pros and cons as to this case, I'm mainly concerned with durability and adaptability to my application..
<a href=\"http://members.lycos.co.uk/kookykrispy/2js.JPG\" target=\"_blank\">http://members.lycos.co.uk/kookykrispy/2js.JPG</a><br /><a href=\"http://members.lycos.co.uk/kookykrispy/driveoncar.JPG\" target=\"_blank\">http://members.lycos.co.uk/kookykrispy/driveoncar.JPG</a>
11-01-2001, 04:08 PM
Traveler
That should do the trick for you. It a strong tcase and will take some serious power. I think MEPCO makes a 4:1 low range kit for it too. GM had two versions one for the IFS and the other for the solid axle. The other thing to check is the speedo connection, there are two one is a mechanical and the other is electronic. The only improvement I can think of is the NGV261, it's a super HD version of the NP 241 and has a magnesium case instead of aluminum.
[ November 01, 2001: Message edited by: 64Trvlr ]
41 MB<br />46 CJ-2A 307,T90,D18,27,44,4:27\'S<br />64 Traveler, 350,sm465,np205,44\'s w/4:88\'s, spool, 34X9.50 TSL\'s,3\" factory lift, Line-x interior, PS, Dual Optima\'s, custom overhead console,Warn XD900i,custom bumpers<br /><a href=\"http://images.andale.com/f2/116/106/4651773/1009696569938_64trvlrconsolegrp.JPG\" target=\"_blank\">Overhead C
STOLEN! Dana 300 Twin Stick
11-02-2001, 04:53 AM
Finally a topic I can sink my teeth into! 241 is a decent case.. except one thing. Get a slip yoke Eliminator kit for it. Slip yokes on 4x4's SUCK period. It's almost as embarassing as dropping a coil spring on the trail.
241's are basically slip yoked versions of 208's if you think about it.
Hrm... my old sig is broken.. new to follow soon.
11-02-2001, 11:56 AM
the 241 was driver's side output for IFS, so I passed, I did however pick up the rebuilt 4L80e
today to go behind my 454
11-02-2001, 01:01 PM
y wont drivers side output work for u in ur 82?
Ken's:
1966 Super Wagoneer
350SBC. 2BBl. Th700R4. NP-208. Detroits. 4.27s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
(Soon to be TBI)
1975 Custom Wagoneer
350SBC. TBI. Th400 FT-QT. Opens. 3.54s. 3core. PS,PB,AC,CC,CD.
(Soon to be TH700R4)
11-02-2001, 01:05 PM
It ain't stock no more! I'm swapping in a 5.88 geared D60 front and D70 rear from a 67 m715. Pumpkin's on the pass side.
11-02-2001, 01:09 PM
well u cood use a dodge 242, it has P side front. or the d300 or the np205.
Ken's:
1966 Super Wagoneer
(Soon to be TBI)
