Old 09-11-2000, 04:52 PM
trogers
Posts: n/a
Question
I just replaced the transmission in my 88 GW and now the 4WD indicator stays lit even when the switch is set to 2WD.I manually moved the (vacuum?) lever on the transfer case and the indicator went off but after driving a bit it's back on.Is this a vacuum problem or did I connect something incorrectly? Thanks again!
Tom
'88 Grand Wagoneer
"Family Truckster"
Old 09-12-2000, 02:28 AM
Baker Baker is offline
Smile
Maybe both--you hooked up the vac lines wrong?
Old 09-12-2000, 03:07 AM
trogers
Posts: n/a
Talking
My defroster does not work either so I'M sure I've crossed something or did not connect a hose. Where does the small hose from beneath the vacuum ball thingy go? I think I connected it to the air filter housing.
Tom
'88 Grand Wagoneer
"Family Truckster"
Old 09-12-2000, 04:42 AM
ClarkGriswald's Avatar
ClarkGriswald ClarkGriswald is offline
Wink
The vac ball and associated systems like defrost valve and 4wheel selector should be hooked up to manifold vacuum source.. a nipple coming right out of the intake manifold..
88 Grand Wagoneer
D44's front\rear
Warn 20990 Lockouts
AMC 360
TF 727
NP 229 (Funky)
Custom Hacking Via S.P.A. (Standard Polish Archetecture)
Wink
I have no idea as to the vacuum routing on an '88 (mine's an '84 w/disco front axle), but that can't be right.
Old 09-12-2000, 05:15 AM
trogers
Posts: n/a
Wink
Thanks everyone,I plan to look deeper into it tonight. Could having the hoses connected incorrectly cause any damage?
Tom
'88 Grand Wagoneer
"Family Truckster"
Old 09-12-2000, 06:21 AM
trogers
Posts: n/a
Question
Also, which hose connects to the air breather?
Tom
'88 Grand Wagoneer
AMC 360
4v Edelbrock
Edelbrock Manifold
"Family Truckster"
