01-28-2002, 04:02 PM
does anybody make floorpan replacements?i need some for one of my cherokkes,if not whats the best fix?
89 grand wagoneer stock daily driver. 78 cherokee chief w/t 401 trail jeep project. 87 grand wagoneer, for sale
01-29-2002, 12:38 AM
Perfesser of Jeepology
No one makes any repair/replacement panels that I know of. Your best bet is to get some 22 gauge sheet metal and weld in your own panels.
Take the time to do the prep work, cut out the rusted areas, and mig-weld new panels in place. After that, I'd coat the new panels with POR-15, or Durabak, to keep the problem from happening again.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
01-29-2002, 01:26 AM
<blockquote>quote:</font><hr>Originally posted by Lindel:
........<hr></blockquote>
Is 22 guage sheetmetal thick enough?? I gotta do the same thing for my 71 and was sondering what size metal to use.
DON <br /><a href=\"http://www.Gladi8r.com\" target=\"_blank\"><b>Website</b></a><br /><br />1988 GW 360<br />Edelbrock Intake & 1406<br />TF727/Dana 300<br /><br />1971 J-4500,Rhino Grille<br />A work in progress  <br />Soon to be:<br />500 Caddy |Th400 | 205<br />DANA 44/60 (3:73)<br /><br /><b>\"They that can give up essential liberty to obtain a little<br />temporary safety, deserve neither liberty nor safety.\" </b> Ben Franklin
01-29-2002, 02:25 AM
22 guage seems a little thin but proably easier to work with. I had the cab off my J20 so it was easy for me to bolt on 1/8 aluminum over the holes using small bolts. I then coated it all over with fibered roof coating. Turned out real nice.
01-29-2002, 03:07 AM
I plan on having my cab off also and was planning on sandblasting the entire cab inside and out. I have a mig welder and was thinking more along the 16 guage size. Is that too thick for floorpans??
01-29-2002, 03:28 AM
16 gauge will work very well. I have used 18 gauge, but I like 16 better. It's a little harder to form up, but sturdier.
01-29-2002, 04:14 AM
Jeep Idiot
The best material for Jeep floor pans is old chevy hoods. They are cheap and easy to find.
65 wag. with a bunch of stuff done and more happening.<br /><br />\"If the local junkyard calls you for Jeep parts, you might be a redneck\".... and yes they do!
01-29-2002, 04:18 AM
I've been cutting rust from my wifes GW floors and rockers. I took a piece of the floor to the local metal shop and he mic'ed it out as being 16 gauge. It's a bit tough to shape, hard on cut-off blades, but it's solid. Fred Flintstone always comes to mind when I think of the Ch*vy hood solution.
84 GW<br />Driveline is Ford 351/C6 combo.<br />New paint, carpet, stereo. Rhino grille, etc.<br /><br /><a href=\"http://home.earthlink.net/~getoverit/index.html\" target=\"_blank\">My Site</a>
01-29-2002, 08:40 AM
Their is a guy that sells floor pans. Unfortunately I have the contact info at work and I won't be back until the 11 of Feb. Email me a reminder and I'll dig it up. Also have info on J truck bedsies.
87 J20<br />360, Dana 60<br />Factory Sportbar<br />Smittybilt Pushbar<br />Pre-runner bed mount tire holder<br />Rhino grill<br />TFI Upgrade<br />\"Heavy Metal\"<br />DON\'T CRUSH EM, RESTORE EM!
01-29-2002, 10:48 AM
Hey HeavyMetal,
I would be interested in those floor pans as well if you could post something in the tech section when you get the Info I check it everday(faitfully) Thanks alot Craig
91 GW 360/727 Black cherry metallic, maroon interior, getting a restoration
82 CJ8 Scrambler-awaiting something to be done
83 CJ8 Scrambler-Wifes Toy 258/4spd, 4" lift, 35" tires,
01-29-2002, 10:55 AM
I'd also be interested about those floorpans. I was going to use 16 gauge.
Talk with ya soon Heavy Metal.
J-trucks with Brows RULE!!!
01-29-2002, 12:05 PM
I would be interested in the bed sides.
01-29-2002, 12:09 PM
HeavyMetal,
Send that floor pan info, I mean I teach welding, I have a ton of 16 gauge laying around, I even have a CNC plama cutter and I still would rather have an exact fit floor panel(s). Thanks
01-29-2002, 12:28 PM
Ya'll got it, I'll run in tomarrow and post the info
01-29-2002, 01:09 PM
You might check out body shops that work on street rods.... thats where i got some made for 40 a side and he even rolled the bead that was in it.used 18 ga
2-J20s<br />76 J20 360/T18/D20/373 75 King Cab J20 360/400/D20/373 ONE is not enough<br />TWO is deep in the pocket
01-30-2002, 06:09 AM
For all that all that are interested in the floor pans and bedsides check out my post in the General msg form under Replacement bedsides and floor pans. Hope this helps
01-30-2002, 09:14 AM
tadsal, access to a plasma cutter  We may need to talk
P.J.
'74 J10, Soon SBC/700R4/208 on 35's
'90 Wagoneer/Klune/208/SOA w/Custom Spring Hangers/HP D44 Alloy USA Axles/14 Bolt/Locked F&R/37" MTRs on H2 Rims/BJ's Bumpers/Custom Rock Sliders/Tad Rack...
01-30-2002, 01:07 PM
heavy metel,what is msg?isnt there a link somebody could post?
01-30-2002, 01:10 PM
never mind ,just saw new post in general discution.
01-30-2002, 01:24 PM
I just did mine and used 16 gauge. It is really and easier to weld on than the thinner stuff. My Wag now sounds really solid when slamming the doors.
Luckily I had a friend who was able to cut the panel to shape and all I had to do was bend it and drill holes. It took some time, but I think it came out ok. Not great, but not bad for a first timer.
It really sounds weird to start the engine, it is soooo quiet with metal between me and the starter. Although now I noticed that the muffler is tapping against the frame. I gotta fix that this weekend because it is one of the last major noises.
