Go Back   International Full Size Jeep Association > Tech Archives > Topic Of The Month
Old 04-23-2003, 04:58 AM
Not sure how this is going to post coming from a spreadsheet into the forum.
Also found while going thru this I am missing a great many reciepts for stuff. Oh well, too late now.
Axle Seals (2) 914802 2 piece rear dana 44
Brake Drums Front (2) 23077D2307 6616197 (11x2)
Brake Hold Down Cup Kit H1132-2 11x2 Drum Brakes
Brake Hold Down Spring Kit H1157-2 11x2 Drum Brakes
Brake Hoses (3) (for 4-6" lift) 914455 11x2 Drum Brakes same Front & Rear
Brake Pin Kit H1105-2 11x2 Drum Brakes
Brake Shoes (2 sets) 228PG PG Plus Shoes 6691281
Carb Kit 2-5550 NIE for RP 2GV (not original)
Condenser Nascar Sel G120A 6774897
Dana 20 Seal Kit 92300 Dana 20
Dist Cap & Rotor Accel 8120 6398010
Front Hub Seals (2) 2115977121559 6428395
Front Springs (rearch) RB-71 & RB-85 R&R and extra main leaf added
Fuel Fill Hose (Bellowsflex) 57910-175 (1 3/4") 24" leaves a bit left over
Fuel Vent Hose (Flex-loc #250) 338412300 6' leaves a bit left over
Ign Wire Set MS2219 6027650 Buick 350
Master Cyl (Reman) 10-1292 A-1 6345235
O/P Set Felpro OS13397C-1/82768 6058697
Oil Filter K&N HP-203 6678429
Pinion Seal 998092K 2 piece rear dana 44
Points Nascar Sel A120V 6774822
Rear Springs (Triangle/Chevy) 22-403 Jeep bushings need to be installed
Shackle Bolt Nuts 9/16-18 GR8 AMLocknut Zinc
Shackle Bolts Front (6) 9/16-18 x 4 GR8 Cap SCR Zinc
Shackle Bushings RB-131 For rear chevy shackles
Shocks (4) Rancho 5126 Front ok, Rear too long
Spark Plugs Champion 3025 6893309
Spring Bushings Rear RB-87 To replace chevey bushings
Valve Cover Gaskets Felpro VS12869R 6076988
Wheel Cyl Rear 2018290 6109052
Wheel Cyl Rear 2018298 6019078
Wheel Cylinder Front WC37132 8323909
Wheel Cylinder Front WC37133 8323917
Windshield Gasket WCR643 Fits all FSJ's
EDIT
Well, it posted better than I thought it would. I'm not going to deal with the tabs and columns.
Note: I may have transposed some part #'s and the Vendor #'s over time so I included both where I could find them with what I think is the part # first.
[ May 08, 2003, 10:20 AM: Message edited by: Sitting Bull ]
