Old 12-12-2002, 02:43 PM
TEX's Avatar
TEX TEX is offline
Angry
I tried to do a shackle flip today on my 73' J10. It didn't work I don't know what I did wrong so if anyone (Stuka esp.) could give me some step by step instructions I would be very greatful.
Thanks
TEX
In the Process of buying another J10. 77 long bed, 401, 400, QT.
Old 12-12-2002, 03:08 PM
Stuka's Avatar
Stuka Stuka is offline
hrm...what part about it didnt work?
Basically you unbolt the rear eye of the spring from the shackle, then tturn the shackle so it faces down (takes some force to do this). Then you bolt the spring back up to the shackle.
When done it should look like this image:
EDIT: Oh, your brake line wont be long enough. It will need to either have adrop bracket, or just bend the steel line down so you have some slack. This is what I did...sure it issnt 100% correct..but I havent had any problems yet.
[ December 12, 2002, 10:12 PM: Message edited by: Stuka ]
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 12-13-2002, 01:38 PM
TEX's Avatar
TEX TEX is offline
Ok. Do you unbolt the spring from the axles first? How is the truck supposed to jacked up? I really don't get it.
Anymore info?
Thanks
TEX
Old 12-13-2002, 01:46 PM
Stuka's Avatar
ahh ok....
you need to support the weight of the truck on blocks or stands of some sort. You have to support the frame. The axle needs to be un-bolted from the springs yes. Remove tires of course.
What I did is have 2 jacks under the axle, took tires off, then lowered truck down onto these big pine rounders i have, that are about 25" tall, onto the back of the frame.
Then I unbolted the u-bolts, but kep the 2 jacks under the axle to support it (they are rolling floor jacks) Then once the axle is free, lower it down. Then un-bolt the rear eye of the leaf spring from the shackle. Then rotate the shackle, you will need to use some force to do this.
Then bolt the springs back to the shackles. With the shackles pointed down. Then bolt the axle back up.
Oh yes...as stated in the above post...you will need to lengthen your brake line, or unbolt it and bend the steel line down.
Old 12-13-2002, 01:51 PM
TEX's Avatar
TEX TEX is offline
Thank you greatly! I really appreciate the help on this. The break lines are shot. The previous owner busted a Ubolt and drove it anyway breaking the break lines, shocks and the other ubolt. I have break lines, shocks and 4" front leaves coming from Rusty's pretty quick here.
Thanks Again!!!!
TEX
Old 12-13-2002, 01:53 PM
Stuka's Avatar
Make sure you get new u-bolts for the back. Factory they are 1/2 inch. You can convert to 9/16 tho. But you have to drill out the plate that they bolt to. Not a big deal, just get it straight.
Old 12-13-2002, 01:57 PM
TEX's Avatar
TEX TEX is offline
Already ordered!
Thanks
TEX
