Old 10-16-2005, 04:38 AM
Spectre's Avatar
Spectre Spectre is offline
Post Autodim mirror upgrade
"Does your mirror vibrate badly or flop around because the mount is worn? Has the dimming switch broken? Does it have a bad case of Ford Mirror Mange where the center looks like someone peeled off some old duct tape and left the residue? Well, upgrade to the NEW Gentex Autodim mirror!"
OK, hucksterism aside, this is a really easy, really cheap upgrade. My mirror had the first stages of Mirror Mange, and it was really annoying. That, and the long reach up to flip the switch (which eventually broke) really annoyed me. I was in the junkyard snagging parts for other beasts I own and decided to do some experimentation. Yup, you CAN install one in the FSJ, and it's easy.
1. Go to a junkyard and find a post-93 Chrysler LH car that has an autodimming mirror like that pictured above.
2. Look underneath the windshield mount. You'll find a single Phillips screw. Remove it.
3. Carefully slide the mirror up and back so that it slides off the windshield mount button. Disconnect the cable that leads from the car's headliner to the mirror.
4. Pull down the leading edge of the headliner and cut that same cable as far back as you can or disconnect it if the connector is within reach.
5. Buy the cable and mirror and go to your SJ.
6. Drop your front headliner.
7. Remove your mirror - it mounts up the same way with a similar screw.
8. Put the Gentex mirror on. You may need a longer screw to secure it, you may not. I didn't.
9. Wire up the mirror - dark blue/white wire goes to a switched ignition source, violet/black goes to the reverse switch (optional, not required), and black/light green goes to ground. What you could do is wire it in to the vanity mirror circuit and just remember to turn the mirror off when you get out of the car at night, or you could run wires appropriately.
That's it!
[ October 16, 2005, 07:16 PM: Message edited by: Spectre ]
"Battlewagon": 1986 Jeep Grand Wagoneer (w/ Tow Pack) - Urban Assault Wagon under construction - TFI, TBI, CS144, Aftermarket Sanden, Explorer Power Seats, 4" Lift, 16" AHI wheels and much much more; click here for a full list of modifications and gear, links to writeups/posts and more info.
Daily Driver: Modified 1987 Jaguar XJ6 Vanden Plas.
Old 10-16-2005, 12:10 PM
Walt's Avatar
Walt Walt is offline
or get one witht he compass too!
90 G Wag.- New Motor/Trans/TC...Soon to have TBI!: CS-144 Alt; Parallel Flow A/C Condenser; Read this BEFORE you install an HEI ignition module!
Old 10-16-2005, 12:27 PM
Spectre's Avatar
Yes, though if you get one with the compass *and* temp readout, you have to find the temp sensor and take it too, and get to have all the customary wiring fun.
They also make one with map lights built into the mirror. That unit hooks up the same.
Also, you do not want to use the GM versions of these mirrors - the mount is notably different.
Old 10-17-2005, 05:57 AM
MGrimm's Avatar
MGrimm MGrimm is offline
Where can this post be put permantly? It is great upgrade and will be lost if not put some permanent.
Do you have more pictures?
79 Wagoneer Custom, 360ci, Edlebrock Performer intake and carb, TFI ignition, AM/FM CASS/6 disc CD), 4" BJ's Lift, Pro Comp Shocks, TADRACK, Blue w/ blue interior and cold A/C
71 VW Super Beetle, work in progress, complete pan off resto.
Old 10-17-2005, 06:03 AM
Super Moderator
Ph.D. in FSJ
Take the post and submit it for a tech article ... never get lost that way...
Todd
www.ttsfabworks.com
Old 10-17-2005, 06:09 AM
crispyboy's Avatar
crispyboy crispyboy is offline
any idea of what chrylser automobiles had the autodim with map reading lights?
I've got my headliner down right now - good time to run some wires for future.
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 10-17-2005, 06:10 AM
Spectre's Avatar
I have a few more pictures, but they're not all that great. Its really just a mirror, not a whole lot to see there... It's how the mirror works that makes the difference.
If you would like some specific pictures, just ask.
Old 10-17-2005, 06:12 AM
Spectre's Avatar
13: Try any second-gen minivan that doesn't have the overhead console. They're rare, but they're out there. Also, try the Avenger/Sebring and the last LeBarons.
If you're willing to try to remove the factory mounting button from the windshield, you could try the autodim/reading lamp units from later Buicks; you'd have to use their windshield mount button, though.
[ October 17, 2005, 12:13 PM: Message edited by: Spectre ]
Old 10-17-2005, 06:13 AM
Spectre's Avatar
Who do you have to harass to do that? [img]smile.gif[/img]
Old 10-17-2005, 06:51 AM
Hud's Avatar
Hud Hud is offline
MGrimm, at the top of the page you can e-mail it to yourself and keep it that way!
88 Grand wagoneer, with a 85 AMC 360, no rust and a Razor Grill
02 TJ, 3.25 inch lift w/33's
78 CJ, 33's and a 304
68 Shasta 16' Travel Trailer (Restoring project)
"The way the rain comes down hard, that's the way I FEEL INSIDE!"
Old 10-27-2005, 03:38 AM
yipcanjo yipcanjo is offline
So you'll end up with a wire traveling from your mirror to the headliner? Why don't I see a wire in your pic?
: Jeepless...
Old 10-27-2005, 03:48 AM
Spectre's Avatar
Yup, you will have that wire. However, I don't have it in the pic because I don't have it permanently wired up yet - I'm still working on the headliner.
Old 10-27-2005, 04:56 AM
pb's Avatar
pb pb is offline
How wide is the mirror compared to the Wagoneer's original mirror?
Paul
1975 Wagoneer DD
Old 10-27-2005, 04:58 AM
Spectre's Avatar
It's about 2/3rds of an inch narrower and about 3/8" taller.
However, you don't lose anything by the unit being that size because most of the "missing" area on the original mirror showed either the rear pillar or the operator's face. You have just as much usable area as before - and the glass is much clearer than the original, too.
Old 10-27-2005, 05:40 AM
LRRH's Avatar
LRRH LRRH is offline
<-- I'm Unfair
Any of the Mods can do it, but then it gets moved to the archive forum and no one can respond to tell you what a good job you did. =)
email me in a week and I will move it there.
_LRRH_
64 J300 | 70 Wag (RIP) | 00 Chero
