Old 04-20-2003, 11:20 AM
BIG BAD JON BIG BAD JON is offline
4-Wheel Drive Junky
Ive got this idea on how to lift my rear suspension. Im using a mount similar to Todds on the front hanger of the rear spring, but the rear hanger, Im wanting to take a different approach. I was thinking of using a post mount on the back, attatching an extended shackle, and mounting my springs to the shackle. Would it work?
FSJ-Less...
Old 04-21-2003, 12:14 PM
Damage, Inc. Damage, Inc. is offline
I can't see why it wouldn't. Any particular reason for this approach?
74 Cherokee
Old 04-21-2003, 12:34 PM
tomd's Avatar
tomd tomd is offline
i'm having a hard time visualizing, maybe explain a little more?
71 J-4000 on a 76 Cherokee chassis with homemade flatbed
360/Th400/PT QT/3.07 D44s
Old 04-21-2003, 11:49 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
Can someone clearly explain the difference in Post Mount and Box Mount to me? I'm a little in the dark.....
BJ's Off-Road
ryan@bjsoffroad.com
Old 04-22-2003, 01:12 AM
The Anti-Chrysler's Avatar
The Anti-Chrysler The Anti-Chrysler is offline
Disciple of A.M.C.
It's just like it sounds. On post mount, the spring shackle mounts directly to a stud, or bolt if you will, mounted to the side of the frame that points outward. It is what was used on earlier FSJ's.
A box mount is a three sided enclosure, with a bottom, that has a hole on each side, and is the width of the shackle plus bushings, and the mounting bolt goes through one "ear" of the box mount, through the shackle, and through the other "ear" of the box mount. It is what was used on later to end FSJ's.
[img]smile.gif[/img]
Jason Davis
'82 J-10 Laredo, 360, T-177, 4" Rusty's
'85 J-10 (parts)
'09 Pontiac G8 GT Sport, '97 Sierra (Vortec 454), '98 Silverado Z71 (5.7 Vortec)
