Old 02-02-2003, 03:21 PM
Go3Team Go3Team is offline
Buddy of mine has a 85 or 86 GW with the Selec
Trac. He told me that something in the transfer case went and blew a hole in it, and said he pulled the chain out. I am guessing the chain broke, and may have caused some major damage. From what I have researched I am guessing its a NP228 or 229. Are these hard to find? He mentioned that his uncle usually throws them away and puts a GM T/C in. My friend said he'd give the GW to me but I guess I want to know what I am looking at before hand. TIA.
[ February 02, 2003, 10:22 PM: Message edited by: Go3Team ]
International 9400 - Cummins N14 @ 370/435, Eaton Fuller M10, 3.70\'s <br />2000 Chevrolet Camaro Z28 - LS1 V8 @ 317.1 rwhp 346 rwtq, A4, 3.73\'s, 12.72@108mph<br />-New To Stable-<br />1985 Jeep Grand Wagoneer 360,TF727,NP229 Not stock for long
Old 02-02-2003, 03:27 PM
The 229 is ok till it breaks. Then it gets expensive. I would just put a np208 in it. You'll need a 208 from another FSJ though. A GM 208 is the wrong side drop.
-Geoff Hill
Old 02-03-2003, 01:13 AM
Are the 208s hard to find? Will they bolt right up? Thanks.
Old 02-03-2003, 01:19 AM
There is or was a couple on ebay recently. It's pretty much a bolt up except I think(?) you'll also need the front drive shaft from the donor. Look for a 208 from a 1980 and up Wag, Chero or J-10 truck. The 208's in the J-20's have a different input shaft.
-Geoff Hill
Old 02-03-2003, 02:23 AM
timmirvin timmirvin is offline
Go3Team.....did I read that correctly?? Your buddy is going to give you the GW because the TC is TU? Man that's great!!!!
\'88 GW...<b>Harley</b><br />Truck Avenger, Performer Intake, TFI, Dual Exhaust, 31x10.50 Goodyear MTR\'s, 15x10 American Racing, Planned: Mossy Oak Camo Clad instead of wood grain!!! Daily Driver<br /><br />\'82 Wag......<b>Sherman</b><br />360/727/NP208/AMC20r/D44f, TFI, Dual Exhaust, 15x10s with 31x10.50s, Homemade 4\" lift, Lincoln Locked Front & Rear...Hunting Vehicle<br /><br />Several Parts Wags<br /><br />Experience is something you don\'t get until right after you need it...
Old 02-03-2003, 02:51 AM
clavin001 clavin001 is offline
I have a 229 that will be taking out this weekend that I would sell. I haven't had any trouble with it, I just picked-up an 82 J-10 with t176 and np 208 and would just rather have the 208.
79 J10 258cid 3spd D20<br />78 Chief 360cid TH400 QT<br />84 J10 Laredo 360cid 727 NP229<br />82 J10 258cid T176 NP208
Old 02-03-2003, 04:39 AM
dnixon dnixon is offline
If you go with the 208 you will need to get the rear driveshaft. The rear is 5" shorter then the 229. If you plan on driving the on the street in 4wd keep with the 229 (although the parts that break in them are much more expensive then the 208) but if you will be just using the 4wd offroad I would make the change now to the 208.. thats what I did/am doing
All It Takes Is Money.
I'm the reason why you can only have Jeeps for Avatars. You're welcome.
Old 02-03-2003, 11:10 AM
Oh yeah, I always love free.
Old 02-03-2003, 11:12 AM
How much?
Where in PA are you located? I live in VA and I am always in PA on business in one place or another.
Another question, would a 208 from a Dodge work?
I ran across a website that said a DOdge 208 "would probably" work in a Jeep.
Old 02-04-2003, 05:13 AM
TTT
Old 02-04-2003, 08:44 AM
Go3team, $150 and its yours.
Old 02-04-2003, 10:14 AM
Sounds like a good deal, what part of PA are you in?
Old 02-04-2003, 11:48 AM
mechanic58's Avatar
mechanic58 mechanic58 is offline
If your search for a good 208 is fruitless or your buddy doesn't want to mess with the trouble of putting a different type of transfer case in, I have a good working 229 from an 89' model GW. I check my email daily, just put TRANSFER CASE in the subject line.
Matt Workman<br />mechanic58@hotmail.com
Old 02-05-2003, 12:33 AM
Go3Team, I sent you an e-mail.
What type of diesel motor can I put in my 83 chief selec trac 83 chif Diesel Swaps 10 06-04-2006 10:55 PM
Selec Trac Question dwrestle General FSJ Tech 5 11-16-2005 01:19 PM
86 Pioneer Selec Trac NP 229 same as other NP 229's referred to? ANxjJeeper General FSJ Tech 23 01-02-2005 10:42 AM
Selec Trac ........228/229 cammobus General FSJ Tech 1 04-05-2004 03:48 AM
selec trac vacuum actuation problem. Dustinlib General FSJ Tech 1 12-07-2001 12:19 AM
