Old 07-14-2003, 02:39 PM
brent's Avatar
brent brent is offline
When my a/c is on, this beast still gets way too hot. I never want to go through another summer like this.
In theory, I shouldn't have a problem. Of all the posts in all the months, I'm on top of 95% of the important things. I've been working off your posts and suggestions like crazy. I even went down to a 13lb cap and 180 thermo and new rad hoses this weekend. DIDN'T COOL THE SNARLING BEAST ONE DEGREE!!
Things that are suspect:
1) I have no fan clutch (yet)
2) Water pump is stock
3) I think I'm gonna buy an oil cooler this weekend
Other than that, you can't nail me on anything cooling-related (shroud and fan distance/coolant mix/hoses/sending unit/radiator itself/etc etc etc).
Still-----I have no faith that addressing any of the remaing three issues will keep my truck cool.
Disgusted, Brent
79 J10 360-T18-D20 D44's 31X10.5 Edel 1406 w/R4B, speed
-despite thousands invested, 360 in putrid death dance-
"Buy the Ticket, Take the Ride."
Old 07-14-2003, 03:04 PM
If you have no fan clutch what are you running?
I was assured by my hot rod neighbor that a 6 blade flex fan would pull... SO MUCH MORE AIR...
Well, been fooled before but it ani't true this time, at 32% less blade area it don't add up.
7 blade fan, HD clutch (had/owned all this to start) is way better air flow.
Old 07-14-2003, 03:08 PM
Michael's Avatar
Michael Michael is offline
If no fan clutch then.....no cool
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 07-14-2003, 03:09 PM
What theory brought you to the conclusion that a 13 lb Radiator Cap was the was to go?
Old 07-14-2003, 03:16 PM
brent's Avatar
13lb cap--read here that lowering the lbs would help a degree or two, that's all.
No fan clutch--overall consensus from reading is that it might be worth a couple of degrees but couldn't possibly be the ROOT OF ALL EVIL, could it?
And I have a 6-blade, metal, fairly new fan, with the PO's shim still in place keeping it half-in/half-out the shroud.
Fan clutch the key to 10-15 degree drop?
Old 07-14-2003, 03:21 PM
BIGYELLOW78J10 BIGYELLOW78J10 is offline
The area of the blade is not everything, the angle matters too. But I am not about to replace my stock fan, thouhg my clutch has seen better days.
Is there anyway to test a cool fan on a non running engine?
What are you running for coolant? When was the last time you flushed your cooling system?
And define too hot? In the red, or cooking you slowly, overcoming the A/C and making your fingers plump like hot dogs?
Even with a new radiator, there is always a chance something random got in tand blocks a passage or 10.
good luck,
Daniel
78 J-10 Rumblin Wreck 2v 360 V-8 Qtrac TH400 Stock down to the rust Highway speed in about an Hour
85 J-20 4v 360 V-8 Transplant w/ 30k Fresh Rebuilt 727 and a working 208!!! A/C might even work one day!
Old 07-14-2003, 03:37 PM
brent's Avatar
Runnin normal Prestone, 50/50. Flushed block and rad three months ago.
"Too hot" is coming around the bend to the red, close enough to make me nervous, and over halfway past the green. Add another length when idling at a Sonic waiting for a malt.
If we can say the red zone="4'oclock" and startup temp is at the 8oclock then when it's hot its averaging 6:30 to 7 oclock if this makes any sense at all.
That little exhausted shimmy it does when idling worries the bejeezus out of me.
Old 07-14-2003, 05:21 PM
Super Moderator
Ph.D. in FSJ
guess this aint the las post on cooling now is it?
Trust me..... these cooling posts will be archived....
Todd
www.ttsfabworks.com
Old 07-14-2003, 11:31 PM
FSJ Radiators and Cooling
Cooling seems to get a lot of attention, so here is the deal.
First an experiment…
Take a pot and put some tap water in it and bring up the heat until steam bubbles begin to form on the bottom of the pot. This will approximate the exhaust water-cooling passages on the AMC motors. Take a big spoon and stir the water so that it flows in CW or CCW rotation, and get it flowing very slowly at first. Note the results. Now stir faster, note the results as the water continues to rotate in the pot. Now take the spoon and swirl in the opposite direction of the water flow just enough to prevent the water from rotating in the pot. Note the reaction. Do this over and over and note the results. Some conclusions should be forming, namely that the flow of water over the surface of the pot, inhibits steam bubbles from forming. This is important for quite a few reasons, namely that once steam bubbles begin to form, they isolate the metal surface which in turn gets hotter, and water as strange as it may seem, is a better heat transfer medium than steam.
When the pot was stirred faster, it took longer for the steam bubbles to form, right?
Faster water flows will inhibit steam bubbles from forming, all other things being equal. The flow of water rushing over the surface area of the pot or the interior of the engine, wipes away the hot spots, if you will.
Adding to that mix, if you pressurize the water, it raises the boiling temperature of the water there by reducing steam bubble generation.
Another observation that I have been prone to notice is that the larger the surface area of a particular radiator the more BTU’s of heat it will be able to transfer from coolant as it passes through, all other things being equal.
The system is designed to operate in a closed loop fashion, with the water pump being fed by the outlet of the radiator. The water pump sends the water flowing through the block, past the head gaskets through the cylinder heads, cooling off the exhaust ports and combustion chambers, while the heads are routing the coolant past the intake manifolds to the thermostat.
The upper radiator hose sends whatever coolant the thermostat and water pump can manage to deliver to the inlet of the radiator, which acts as a heat exchanger to transfer excessive heat to the atmosphere, through the airflow of ambient air flowing through the radiator cooling fins.
You need at least 1 square inch of radiator surface area per cubic inch of motor, I have an AMC-360 probably bored at .030 over, and my radiator is 425 square inches.
I also have about 16 louvered fins per linear inch on that radiator, which allows enough airflow to cross ventilate the 4 staggered rows of vertical oblong tubes that dissipate the heat that the coolant is carrying. There is a point where the density of fins per linear inch of radiator will begin to restrict air flow through the radiator, especially at highway speeds as the air dam builds up in front of the vehicle. I have observed that my radiator can cool as much as 40 degrees from the intake to the outlet.
For the increasing coolant flow, I have a FlowKooler mechanical water pump mated to an Evans modified Robert Shaw thermostat, rated at 180 degrees. Opening the radiator cap, and starting the engine and running her until the thermostat opens up reveals that there is quite a lot of water being moved by the impeller blades of the pump.
It flies past the radiator cap orifice. There is a plate that is attached to the back of the impeller blades, which improves low speed water flow, and at high speeds, reduces impeller blade cavitations. Keep in mind that even the highest flowing water pump and associated high flow thermostat can only move as much coolant thru the closed loop systems as the closed loop systems restrictions allow.
I use a 20-23 lb rated radiator cap to further pressurize the coolant to raise the boiling temperature. The reason that a thermostat is important is that it keeps the vehicle within the design parameters, as internal combustion engines all have a preferred operating zone in terms of engine temperatures. It also helps provide backpressure on the impeller blades, thus helping to prevent cavitations, a very nasty occurrence.
Now this may not work for you, as the cooling system is a closed loop system, the rated pressure of your radiator (or water pump seepage qoutient, or radiator hose, etc...) may not be able to withstand the added working pressure that the 20-23 lb. Radiator cap may impose. Let the buyer beware.
Finally, since pure water is superior to any antifreeze on the market, I use it to more efficiently transfer the heat from the engine to the radiator.
Since pure distilled water will soon rust in the system, anti-corrosion additives are needed, and since the water pump likes some lubrication, I use Water Wetter and Preston Anti-Corrosion and Lubricant for pure water systems.
Other things to consider are the tendencies of antifreeze additives to de-compose thus adding solvent solids to the coolant mix, dissolved calcium in tap waters are a bother, as are the mineral contents of tap water in some locations.
Not changing and flushing out all of these solids on a regular basis, creates problems. The disolved solids seek the lowest portion of the system that they can locate and reside at, in many cases this leads to build ups being massed just inside the lowest portion of the radiator and available to be sucked in after being jogged loose by traversing rough terrain, therby being fed directly to the impeller blades of the water pump.
Just go out and look at the water jacket of that ole block lying around to see the effects of crud and scale build up.
So keep in mind that in most cases we are attacking the weakest link in the cooling system, and whatever improvements made, may very well reveal the next weakest link in that chain.
So some of us end up chasing one thing after another and get frustrated in the process. So, if you read through this and decide to fix her up, and go out and buy that 23 lb Radiator cap that I am so fond of touting, you may just find out how good that ole water pump really is, it may start leaking, creating steam pockets, harming your engine, and reducing coolant levels in the system, not to mention what might happen to the head gaskets.
Speaking of gaskets, be careful of silicon, any excess gasket material that finds its way into the coolant, will not help the situation at all.
To properly troubleshoot overheating and cooling issues, we must not rely on urban legends; facts work nicely here as in any troubleshooting endeavors.
In order to troubleshoot, we need data that is confirmable, and repeatable.
So, measuring the temperature of the incoming coolant to the radiator, and measuring the out flowing temperature from the radiator is required, in order to collect data and determine what is really happening in the system. The temperature gauge in the vehicle is simply not good enough.
Thermocouples are an idea choice as most multimeters allow thermocouple inputs.
Most of us have access to thermocouples, and the small interfaces that allow two thermocouples to be placed in the radiator inlet and outlet tubes can be had for a very reasonable price.
Now, getting back to the radiator and the design parameters of operation…
On my FSJ, this equates to a 180 degree Evans modified Robert Shaw thermostat, with a set point of 180 degrees. My inlet water temperature to the radiator when at 100 degrees ambient temperature is normally about 195 degrees, and at the outlet of the radiator it is about 155-165 degrees, during normal engine operations.
A 20 inch 7-blade, 2 ľ inch pitch fan from a Dodge 400/440 with a Heavy Duty Fan Clutch is indeed helpful, but we need a fan shroud in order to insure that all of the air being drawn by the fan is pulled through the radiator and not from underneath the vehicle.
A custom fan shroud may just be the ticket here, with a felt gasket to seal that shroud to the back of the radiator surface. Any self respecting sheet metal shop can fabricate a fan shroud out of stainless steel. Have them bend a rectangle to fit up against the radiator core, insuring that it can be sealed up against the radiator with a felt gasket and it engages the fan by at least ˝ of the blade depth.
Now a circle cut out to enclose 1/2 of the fan blade thickness can be brazed on the rectangle to finish the shroud, making sure that the edges are sanded to remove burrs and sharp edges.
Fabricate tabs to mount to the radiator mounting points. Just insure that there is enough space between the blade tips and the shroud so that flexing of the engine on the motor mounts and flex of the chassis over terrain will not cause a problem with mechanical interference between the blades and the shroud. Give it at least a 1/2 inch berth.
The radiator should drop the temperature of the coolant by about 20-30 degrees when the coolant flows through the radiator, at a minimum. This is the difference between the inlet temperature and the outlet temperature of the radiator.
A radiator that does not cool by 20-30 degrees either is not getting enough airflow, or the coolant is not efficient enough to keep up with the heat load.
Several issues to address here. A lot of folks run 50/50 mixtures of coolant to water. Not the best idea in the Summer, as the stronger the solution of antifreeze to water mixture ratio becomes, the less efficient the coolant becomes as a heat transfer medium.
As mentioned earlier, we should be striving to optimize the efficiency of the system, and another tool we have at our disposal is the physical properties of water, it is simply a better medium for heat transfer that antifreeze.
Any addition of antifreeze begins to degrade the heat transfer qualities of water. So, if you are positive that during the summer months, that the vehicle will not be subjected to sub freezing temperatures, then why not optimize the efficiency of the system by substituting distilled water.
Why distilled water? Well, tap water will contain minerals, and dissolved solids, and chemicals and lime and all sorts of bad things for the engine. So just use distilled water.
But using distilled water only as your coolant will soon result in rust and provides no lubrication to the water pump, which desperately needs lubrication. So use Preston’s Anti-Corrosion and Lubricant or even perhaps some Water Wetter.
You may hear that by doing this we have lowered the boiling point of the coolant enough that disaster will now strike. This is another reason for the suggested 20-23 lb. Radiator cap, to increase the pressure in the system to raise the boiling point of the coolant to an acceptable level.
An additional benefit is that this further pressurizes the system so that impeller blade cavitations are not an issue. Replace the stock water cooler with a Miloden or Flowkooler to take that out of the equation, the higher flow through the closed loop system is worth the expenditure.
So, a 4-row staggered core, 16-louvered fins per inch of linear radiator with a surface area of 1 square inch per cubic inch of motor with an additional 20% engineering overhead for those tough heating days.
An Evans modified Robert Shaw 180-degree thermostat, Flowkooler or Miloden Water Pump, and a 20-23 lb pressure rated radiator cap get us the hardware to get us started.
With a flush out of the water jackets inside the engine to remove all that scale and gunk… lots of gunk there guaranteed..., and using distilled water with Preston Anti-Corrosion/Lubricant and/or Water Wetter, to prevent the distilled water from forming rust and corrosion, we have our heat transfer medium all in order.
The coolant flows through the radiator faster so it has less time to shed it's heat, BUT it also flows through the block at the same rate, and therefore does not absorb AS MUCH heat...bottom line is that the engine runs cooler.
Added turbulence from the high flow water pump and high flow thermostat scrubs off vaporization areas around exhaust ports and prevents steam bubbles from forming. Thus adding to the efficiency of the system.
The radiator also has more cores and more rows thus removing additional restrictiion to the coolant flow rates.
Now we can move on to the subject of diagnosing cooling issues.
Again, we need to get those thermocouples mounted on the radiators. Infrared hand held temperature meters are also available.
When the inlet temperature is generally around 190 degrees and the return outlet temperature is 165-175 degrees or lower depending upon ambient air temperatures, then we can pretty much agree that the rig is operating per the design parameters that were set by the good folks at AMC at the beginning of the odyssey.
When the inlet temperature is about 220-plus degrees, and the outlet temperature is pretty close to air temperature, we can theorize that very little water is flowing through the radiator, but what is flowing through is being stripped of its heat per design parameters, otherwise the outlet temperature of the radiator would be raised substantially, right?
So, some possibilities are the thermostat is not opening fully, to allow the heated block water to transition to the radiator or the water pump is no longer operational and there is not enough coolant flowing through the system. This is bad, and fairly easy to troubleshoot. The hoses on the vehicle will give some indication, the top hose is extremely hot, and the lower hose is not near as hot, but does not seem to be full of coolant and it is feeling rather feeling. This indicates that not enough water is being returned to the block, causing the lower radiator hose to collapse in some cases
Now, if the inlet temperature or the temperature gauge is spiking and cools down when the engine rpm’s pick up (as a recent post suggests), then we have a condition that leads me to believe that excessive heat is being generated, when the engine rpm’s pick up, the problem is reduced.
This would seem to indicate that revving the engine has some beneficial effects. If the temperature change were immediate, then we would suspect that low coolant levels or low pressure in the system is allowing heated steam to form and influence the temperature sender or thermocouples.
There is a possible leak in the system, so when the vehicle is stopped and the hood is opened while the engine is still running, one may carefully release the pressure on the radiator cap, no sudden pressure release and you have found your problem, most likely a worn out radiator cap.
Since the coolant level is not at the desired level or pressure, steam my form and be trapped at the top portion of the closed loop system, generally in the thermostat housing and hose area along with the top portion of the radiator, all of these areas will be super hot. This will degrade the seal on the radiator cap and test the integrity of the radiator.
OK, another situation might be that the inlet temperature is high again, 220 degrees or so, and the outlet temperature is also very high. So we might suspect that the heat transfer of the coolant is not keeping up with the demands of the system. What might cause this to happen can be one of several distasteful options.
One is that the radiator must be capable of handling the heat load, again we go back to the basic design theory that 1 square inch of radiator surface area is needed for every cubic inch of engine, with at least a 20% overhead, this translates to at least a 25-inch wide radiator with 17 inches height minimum, with the right design parameters of 3 to 4 cores with the right amount of fins per linear inch. The ideal behind a 4-staggered core is that the cores are not subjected to the heating that is stripped off by the 1st or 2nd row. Also, the extra rows increase the volumn of coolant available, thus aiding in cooling. Another benefit of adding rows, is that increased fin area is provided further assisting the heat transfer process. Finally, the added tubes provide for additional flow, thus increasing the flow rate of the coolant thru the closed loop system.
Two, there must be enough coolant flow to circulate through the system in order to transfer enough heat to keep up with the heat load. As long as we have the high output water pumps and the high flow thermostats, this probably can be ignored.
Three might be that we have enough radiator and enough coolant and that the coolant is flowing efficiently enough to keep up with the heat loads, but there is not enough air flow across the radiator to scrub sufficient heat to keep up with the heat load.
Speaking of radiators, most of ours are older than 20 years; the tubes are made of stuff about 0.010 of an inch thick. The **** thing is held together by acid core solder, just how tuff do you think this stuff is? And lets face it; most of the engine heat is dissipated in exhaust anyway.
How about when the engine overheats and we turn on the Heater to assist in cooling. If this works you have increased the cooling fin surface area of the radiator and you have increased the airflow across those fins in the heater core, while simultaneously increasing the total amount of coolant available to shed BTU's.
Now, here is where some folks join in the fray with Heavy Duty Fan Clutches and Flex Fans and such.
Kind of makes you wonder if enough consideration was given to the other areas of the closed loop system.
That this solution has worked for so many is a testimony to the fact that the closed loop system probably worked when the vehicle was new, but being twenty to thirty years old. Bored over as most of our rigs are, and given the fact that the radiators most of us are using are probably not nearly new with some blocked passages, and the ole water pumps have impeller blades eaten by cavitations, and the thermostat we just put in last year was a bargain for $3.87 at the local auto parts store, and the coolant is probably more like 80% antifreeze to 20% tap water, which has resulted in coolant dissolved solids and minerals and calcium deposits throughout the system, it is no wonder that we spout off so about any kind of improvement at all.
So, adding that heavy-duty fan clutch gets just enough oomph to get us over the hump and is universally agreed upon as the Holy Grail of Cooling.
Well, it is not a bad idea, my ONLY problem with this solution is that if we address the engineering behind the Heavy Duty Fan Clutch we find that it is designed to prevent the fan from turning at the same rate of the water pump shaft.
This gives quieter operation (no howling) and perhaps better gas mileage. Also at higher speeds, the fan is slowed so as not to intefere with the air dam that has built up in front of the vehicle.
Which brings up another issue, air dams can build up so as to prevent some air entering the engine compartment, due to the height and flow rate of air underneath our rigs.
Once we put that into perspective, we realize that the fan clutch is in reality a boon, to those systems that have been designed and are in the middle of their operational parameters, so that the clutch can slip when additional airflow may not be needed, or additional air flow may be available when required, by having the clutch engage the fan and not allow it to slip as much.
Of note on fan clutches is that as the engine rpm rises, the bi-metallic spring on some models cools off and allows the clutch engage the fan more, resulting in a area of rpm range where it actually allows the system to heat further. Reducing the speed sometimes improves this situation.
I just wanted to throw some things out there to consider, before everyone just starts to tear into their rigs and throw parts at potential problems, plus share some of the things that I have observed along the way.
Old 07-15-2003, 12:20 AM
Wesdog's Avatar
Wesdog Wesdog is offline
76' Cherokee S Chief W/T 401/TH400/QT/D60FF/Rancho
77' Cherokee 360/T18A/D20/SoA/Full Cage
75' CJ5 304/T15/D20/Rancho
75' CJ5 401/TF727/D300/Rancho (project)
Old 07-15-2003, 12:28 AM
AJ Johnson AJ Johnson is offline
lmao........
1955 CJ5<br />1984 4Runner
Old 07-15-2003, 12:37 AM
Super Moderator
Ph.D. in FSJ
Originally posted by Wesdog:
OH YES!!!!! I FULL-HEARTEDLY AGREE!!!
GREAT!!!
Todd
www.ttsfabworks.com
Old 07-15-2003, 01:36 AM
Wesdog's Avatar
I can't add much to what Joe posted above. I gotta say Joe that you really laid it all out in a nicely organized and understandable post. Thanks for pointing out the interaction between the T-stat and providing a restriction/backpressure to the impeller to help prevent cavitation. I knew there was an interaction between the pump and t-stat but I have been having problems getting a clear picture in my mind about how a closed system fuctions with regard to pressure, flow and restrictions, I keep thinking in terms of the operation other types of systems such as the AC or Oiling systems and it is confusing. I also read somewhere about how the radiators tubes in the core are designed to create turbulence to help stir the cooling fluid as it passes through the core.
Here's a photo of the modified Robertshaw t-stat from the Stewert website. It shows one of the extra 3/8" holes you mentioned. Evans offers the same thing as you pointed out:
I like photos as they help people like me get a clear picture of what is being described.
Thanks for taking the time to put together that great post. Even after spending the last few years working on my cooling system I still have many things to learn and re-learn.
Have you used a sacrificial anode in your system to help cut down on the effects of electrolysis? When using water as the cooling fluid this becomes a consideration I believe.
Wesdog
[ July 15, 2003, 07:40 AM: Message edited by: Wesdog ]
Old 07-15-2003, 01:42 AM
brent's Avatar
Add my unworthiness as well, and thanks. Something completely different to think about. That's one for the record books.
Gonna be an interesting weekend at least....THANKS
Old 07-15-2003, 02:08 AM
reddog reddog is offline
Your Jeep runs hot because you live in Tempe in the SUMMER!! It is very HOT there I hear...
Thats all I can add after Joe's post.
Kerry
[ July 15, 2003, 08:10 AM: Message edited by: reddog ]
87 GW<br />4\" Skyjacker system<br />TFI upgrade<br />360,727,NP229<br />it looks a little more like RiverBeast - and I\'m not dreaming!...<br />... just another 10 inches or so to go ...<br /><br />and NOW with an interesting bend to the body...
Old 07-15-2003, 02:49 AM
jeepjake
Posts: n/a
So..., why doesn't some enterprising person find a shop that needs some business right now, design a shroud and market one to the FSJ (and CJ) crowd for less than what's available?
Someone HAS to be out of work right now and have time to pursue this, someone else HAS to have a few $'s to help put into this enterprise? Anyone?...., anyone?..., Bueler????
Old 07-15-2003, 03:18 AM
Green Giant's Avatar
Green Giant Green Giant is offline
New $4 thermostat, coolant drain & refill(~50/50), and a $24 fan clutch fixed my cooling problem. Guess I didn't know any better.
Todd Moon
78 Cherokee Chief
78 Chief
66 J-3600
69 J-3500
67 CJ-5
67 J-100 w/BARN DOORS
48 CJ2-A
Proud member of Carolina Full Size Jeep Club
cfsjc.com
No part of this post, written or pictured, may be re-used by any individual or organization or publication without my express written permission.
(Thanks, Flint!)
Old 07-15-2003, 04:31 AM
letank's Avatar
letank letank is offline
very impressive Joe.
I believe, that you can even get a 21" 7 blades fan for the 440.....
I have been running distilled water / prestone 50/50 for more than 10 years.... so no one should worry about the slightly more acidic distilled water.... it does not dissolve the copper solder....
Michel
Michel
74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to Moab without a rebuilt? Status: debugging a few electricals.
85 Gwag, 210 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
my jeep aid images
http://picasaweb.google.com/jeepmr/FSJ
Old 07-15-2003, 05:05 AM
JAllenWAG JAllenWAG is offline
I started running hot after my rebuild and upgrades so I put in a cheap 180 t-stat and it didn't do anything. I put a mr. gasket performance 180 in and it runs about 15-20 degrees cooler now. The mr. gasket t-stat was only a few dollars more at advance auto.
Jason <br /><br />\'89 GW<br />360 bored .30 over<br />TF727/NP229/d44 front and rear<br />K&N filter<br />Flowmaster Exhaust<br />Edelbrock 3731 Intake<br />Edelbrock 1406 carb<br />Summit 8600 Cam<br />TFI Upgrade<br />Too bad it\'s sitting in the garage not running....<br /><br />2004 Toyota Tacoma V6 4X4<br />K&N filter<br />Borla Exhaust<br />I love the Wag but at 210000 miles it can\'t be my daily driver anymore!
Old 07-15-2003, 05:53 AM
Wage Wage is offline
Joe,
You da man! I have my rig at the radiaotor shop today. Having HD rad built, 180 High flow t-stat installed, and HD fan clutch. I will tackle larger fan blade and shroud after I fid\gure out how to pay for this!
Joe,
Thank you man!
Wage,<br /><br />Full Sizers Rule Man!<br />83 Grand Wagoneer Ltd. All stock...For Now!!!!!!!!!
Thoughts on cooling (50/50 vs Water vs WaterWetter) yipcanjo General FSJ Tech 33 08-07-2005 10:46 AM
Need more cooling. Chero77 General FSJ Tech 2 10-14-2003 11:18 AM
Am I too cool? waggin'ear General FSJ Tech 15 07-13-2003 05:22 PM
Help please Dan G General FSJ Tech 36 09-02-2002 08:47 AM
Cooling Problem... Rompn General FSJ Tech 9 10-17-2001 03:11 AM
