Old 07-30-2003, 12:04 PM
Kris's Avatar
Kris Kris is offline
Hi all...
Ive been wondering about the width of different axles offered in FSJ's.
Seems like a good thing to know since these axles seem to be popular for swaps into other (smaller) jeeps, as well as sammies, yotas and the like. Not to mention putting WT axles into NT Wagons...
I searched the forums and came up with alot of references to "Track Width" but no measurments of wheel mounting surface to wheel mounting surface (brake to brake).
The track width can differ between two identical axles as rim backspace and rim width can change the track width.
I measured the rear d44 on my 89' and it came out to 58.5". The d35 in my 87' yj is 60.5".
I measured the front d44 some time ago but lost the measurments, I think it was about 59.75.
I measured all of these with 2 straight edges and a tape measure.
So, in the interest of putting together an accurate database of axle widths, would those of you with different models and years of FSJ be willing to grab a friend, measure your axles and post your findings here with the year and model ?
Thanks in advance, and happy measuring...
kris.
89 Waggy
Save the Hammers<--Click it!
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally Posted by JeepinPete
-If it wasn't for bad luck, you wouldn't have any luck at all-
Old 07-30-2003, 02:57 PM
Just so folks do not have to look too far, here is the link...
http://www.ttsfabworks.com/tech/WMS.html
...it's just a work in progress.
Kris,
I sure respect your ambition and desire on this adventure, I'll support it the best I can, with as many axles as I can.
I have searched as you have, gotten the same vague info, looked at other web sites, we (as the IFSJA Collective) still do not have this in print, at least not anyplace I can find.
Here are the problems I have found with this search.
A) Track Width, means very little, depends on wheel backspacing and tire/rim size.
B) Where folks measure from. It would be nice if we had WMS to WMS numbers. I believe, some of our members have measured off the rotors in front and not the actual wheel mounting surface.
You have stated all that above (sorry to be redundant), and I'll get some bad responses from members that I have asked these same questions to.
They claim it's "in the archives", it's not, not accuratly, to say the least.
So let's get the ball rolling, straight edges across the wheel mounting surface only. Any axle that can be type and year verified is a winner, others can be just listed as sketchy/nonverified
1970 Wagoneer - Front NT Dana 27 = 59" (stock drum brakes)
1970 Wagoneer - Rear NT 2Piece Dana 44 = 59" (stock drum brakes)
1976 Wagoneer - Front NT Dana 44 = 61" (stock disc brakes)
Later Scout 2 - Rear Dana 44 = 58" (nonverified)
I have 9 more axles I can measure and add over the next 3-4 weeks. 1985 NT Wag (both), 1979 WT Chero (rear), 1972 J2000 (both), Mid 70's J20 (both), Early 70's Commando (front).
Kris, if you'll help keep the ball rolling I'll start pulling down info into a spreadsheet.
We can chop this into verified and nonverified info for clarity.
Thanks,
Tad
[ December 21, 2004, 02:33 PM: Message edited by: tadsal ]
Old 07-30-2003, 10:23 PM
2ndtimearround's Avatar
2ndtimearround 2ndtimearround is offline
Thumbs up
Excellent idea.
http://www.jeeptech.com has some of the info that you are looking for.
Try this link:
http://www.jeeptech.com/convaxle/d44f.html
Under each axle type is listed their width (spring pad to spring pad) in typical Jeep applications.
I hope this helps
Lawrence
[ July 31, 2003, 04:24 AM: Message edited by: 2ndtimearround ]
Lawrence
  • 92 YJ -- Mean Green Starter, 4x4 Posi-lok, Tuffy Overhead Console, 2 meter ham radio, CB, Borla Cat Back Exhaust
  • 86 FSJ -- NOS Gas Tank Skid Plate, TFI Upgrade with Accel Super Coil
Old 07-30-2003, 10:57 PM
2ndtimearround,
Not knocking that site but that is some of the very same info that's been posted here before. I seriously question the accuracy of the data on that site, and they openly state that...
"The accuracy of the dimensions is not guaranteed, get out your tape measure".
It was a nice attempt on their part but their grid only contains 2 of the 8 blocks of information they presented, the rest is blank. I don't think spring pad distance is a big deal anyway, they can be easily changed, whereas the WMS can not.
Old 07-31-2003, 04:22 AM
Kris's Avatar
Thanks Tad,
I will have a pair of early 80's (I think 82') j-10 axles here in a week or two.
They are d44f/m20r and I dont know if they are the same as the 82' Cherokee (RB/RBY go check... )
I will also re-measure my 89's front axle by this weekend.
Any help here is appreciated.
We all have these vehicles so we are the best resource for this info.
[img]smile.gif[/img]
kris.
89 Waggy
Old 07-31-2003, 04:24 AM
Good point Tad!
I have an 81 D44 Front and 89 D44 Rear both setting in the shop now, on the floor. Let me know what you want measured.
Lawrence
Lawrence
Old 07-31-2003, 04:31 AM
Kris's Avatar
Lawrence...
Measure from the wheel mounting surface, with the brakes installed. This is the surface with the studs.
It is best to do it with two people unless you have a way to clamp a straight edge (I use a 2ft level) to one of the brakes.
Then measure across the axle to another straight edge, dont let the measureing tape hang up on any part of the axle.
When measuring the front, it is best to have the tie-rod installed. If not then try to keep the the hubs pointing straight ahead.
BTW, can you measure in inches...
Thanks for your help.
kris.
Old 07-31-2003, 04:59 AM
LOL, you bet Kris, I was looking at that 59.4" thing about a year ago and thinking
This sounds like a very long over due project.
Thanks
Old 08-03-2003, 04:26 AM
Kris's Avatar
I dont want this to get lost...
How many WideTrack and j-truck owners do we have here that own tape measures... ?
BTT
kris.
Old 08-03-2003, 05:07 AM
mcinfantry mcinfantry is offline
dana 60 from a m1008 is 69"
corp 14 bolt same truck is 67"
1942 Dodge WC53 (replaced my m715)
under the knife!
4bt, 4l80e, nv241
d60/14b 4.88gears w/ arb's
michelin 1100x16xl's
Old 08-03-2003, 05:09 AM
dana 60 front from m715 is 72.5
dana 70 from same is 72
under the knife!
4bt, 4l80e, nv241
Old 08-03-2003, 06:34 AM
Kris:
On the D44 Rear from an 87 GW = 59".
This is wheel mounting surface to wheel mount surface.
The front D44's ball joints are too bad to get an accurate measurment. Sorry.
Lawrence
Lawrence
Old 08-03-2003, 07:27 AM
Kris,
I have a spreadsheet going now.
Is that dana35 a front axle?
Edit: checking how well the spreadsheet will copy and paste into this.
2ndtimearround Dana 44 GW 1987 FSJ NT Rear 59" 6 on 5 1/2 Aug 03
Dave Dana 44 HD 1976 Chevy Front 69 1/2" 8 on 6 1/2 Aug 03
Dave Dana 44 1979 FSJ NT Front 61 1/2" 6 on 5 1/2 Aug 03
Dave Dana 44 1979 FSJ NT Rear 57 3/4" 6 on 5 1/2 Aug 03
Dave Ford 10 1/4" 1988 Ford Rear 64 3/4" ??? Aug 03
Kris Dana 44 Hi Pinion 1977 F 150 Front 66" 5 on 5 1/2 Aug 03
Kris Dana 35 YJ 1987 YJ ??? 60 1/2" ??? July 03
Kris Dana 44 GW 1989 FSJ NT Rear 58 1/2" 6 on 5 1/2 July 03
Kris Dana 44 GW 1989 FSJ NT Front 59 3/4" 6 on 5 1/2 Non-Verified
mcinfantry Dana 60 M17 1967 M17 Front 72 1/2" 6 on 7 1/4 Aug 03
mcinfantry Dana 70 M17 1967 M17 Rear 72" 6 on 7 1/4 Aug 03
mcinfantry Dana 60 M1008 1986 Mil Chevy 1 Ton Front 69" 8 on 6 1/2 Aug 03
mcinfantry Corp 14 Bolt M1008 1986 Mil Chevy 1 Ton Rear (single) 67" 8 on 6 1/2 Aug 03
Netbear/Elliott D70 Dually 1961 FC 170 Rear 66" ??? Aug 03
tadsal Dana 44 Scout II unknown Scout II Rear 58" 5 on 5 1/2 Non-Verified
tadsal Dana 27 Wag 1970 FSJ NT Front 59" 5 on 5 1/2 March 03
tadsal Dana 44 Wag 1970 FSJ NT Rear (2-piece) 57 1/2" 5 on 5 1/2 March 03
tadsal Dana 44 Wag 1976 FSJ NT Front 61" 6 on 5 1/2 March 03
tadsal Dana 44 1979 FSJ NT Rear 58 1/2" 6 on 5 1/2 Aug 03
tadsal Dana 44 1972 J 2000 Rear 67" 5 on 5 1/2 July 04
tadsal Dana 44 1972 J 2000 Front 67" 5 on 5 1/2 July 04
tadsal Corp 14 Bolt 1983 K 30 Rear 67" 8 on 6 1/2 July 04
tadsal Corp 14 Bolt 1979 K 30 Rear 67" 8 on 6 1/2 Dec 04
tadsal HD44 1977 J 20 Front 67" 8 on 6 1/2 July 04
tadsal HD44 1979 J 20 Front 67" 8 on 6 1/2 July 04
viscacha HD44 1986 J 20 Front 67 ¼” 8 on 6 1/2 June 04
viscacha D60 1986 J 20 Rear 67 ½” 8 on 6 1/2 June 04
viscacha D60 Hi Pinion 1979 F 350 Front 69 ¼” 8 on 6 1/2 June 04
Well, it does not paste very well, seems the UBB code does not accept tabs or columns, it can just get converted later I guess.
[ December 21, 2004, 04:38 AM: Message edited by: tadsal ]
Old 08-03-2003, 02:21 PM
JeepKahn JeepKahn is offline
I got the Honcho, and I'll pull the wheels and measure tomorrow...
\"Smoke\'m, They\'ll Stick\"<br /><br />Got Heat Problems???Want Free HP???<br />Check This Out!!!<br /><a href=\"http://www.ifsja.org/ubb/ultimatebb.php?ubb=get_topic;f=3;t=024412\" target=\"_blank\">http://www.ifsja.org/ubb/ultimatebb.php?ubb=get_topic;f=3;t=024412</a><br /><br />Jeremy Kahn Jeepkahn@yahoo.com<br />79 J10Honcho \"SickPuppy\"<br />360,Th400,D20,D44s@4.09,35x12.50s <br />Mobi-Arc on board welder<br /><br />Winston-Salem,NC<br /><br />!!!Will Weld for Gas!!!
Old 08-03-2003, 02:54 PM
oops the m1008 is a 1986 ,the dana 60 is a 8 lug
the 14 bolt is the same truck same lug
the m715 is 6lug on 7 1/4
under the knife!
4bt, 4l80e, nv241
Old 08-04-2003, 04:55 AM
Kris's Avatar
Thanks everyone...
OK, Im just bumping it back to the top...
And its post 400 for me...
kris.
Old 08-04-2003, 07:52 AM
Super Moderator
Ph.D. in FSJ
Kris,
You actually want me to work on RBY?!?!?! oh my!!! LMAO
I 'll see what I can do....
Todd
www.ttsfabworks.com
Old 08-04-2003, 04:11 PM
Just keeping it on the first page, guess we only have 4 members that own a tape.
Thanks,
Tad
Old 08-08-2003, 07:03 PM
Kris's Avatar
btt...
Yes Todd, get to work...
How's that blender doing ?
OK,
Its a weekend again...
Are we going to get out those measuring tapes, pull off those wheels and get to measuring ?
Hmmm.
You're gonna be working on it anyways, changing the oil and such, how about rotating the tires.
Thats a perfect time to measure the width of those axles...
Have a nice weekend everyone...
kris.
Old 08-08-2003, 07:16 PM
Midnightwagon Midnightwagon is offline
uhm soon as i get home ill measure my axles, both old and new. but im sure this lil project will be done by then but ill do it anyways cause i wanna know!!
Jeremy
my jeep has gone to that great big salvage yard in the sky
