Old 06-25-2003, 02:31 PM
FratWagon86 FratWagon86 is offline
Angry
My wag is leaking tons of coolant but my hood wont open is there any trick to getting it open when the latch int the cab won't work. Whem I pull it nothing happens it is like it is not even hooked up. I have tried pushing on the hood to see if it clicks and I also trid pulling the latch with someone lifting on the hood put it wont open.
1986 GW <br />4\'\' Skyjacker <br />33x12.5 Super Swamper<br />4.56 Front & Rear<br />Rebuilt 360 with Edelbrock Carb & Intake Manifold Summit Cam MSD Distrubtor and Offraod 6 Heddman Headers Mean Green Starter and Alternator
Old 06-25-2003, 02:37 PM
brielly's Avatar
brielly brielly is offline
You need a long screw driver or straight edge to pop the latch under the hood. You should be able to see the latch( use a flashlight if necessary) Just give it a push and it should open. I had to do this all the time on my 81.
For Sale Custom built reproduction Rhino Grilles PM me for details or email rrielly2@comcast.net
1982 Cherokee Chief 258 6 cyl, T-5, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl, 4.0 Head, MPFI, t176 4 spd, np 208, Hydroboost Brakes msd 6a & blaster 2f coil, BFG 31/10.50/15 tires, BJ's 4" Lift *SOLD*
Old 06-25-2003, 04:16 PM
timmirvin timmirvin is offline
Yep, works for me!!!!
You will be pushing the tab that the cable pulls. Look between top of grill and hood. If you look closely you can see both sides of the tab. Might even want to pull up on hood as you do it.....
Good luck
\'88 GW...<b>Harley</b><br />Truck Avenger, Performer Intake, TFI, Dual Exhaust, 31x10.50 Goodyear MTR\'s, 15x10 American Racing, Planned: Mossy Oak Camo Clad instead of wood grain!!! Daily Driver<br /><br />\'82 Wag......<b>Sherman</b><br />360/727/NP208/AMC20r/D44f, TFI, Dual Exhaust, 15x10s with 31x10.50s, Homemade 4\" lift, Lincoln Locked Front & Rear...Hunting Vehicle<br /><br />Several Parts Wags<br /><br />Experience is something you don\'t get until right after you need it...
Old 06-26-2003, 07:24 AM
Thanks for the help
