Old 03-11-2005, 07:38 AM
Symer Salient's Avatar
Symer Salient Symer Salient is offline
Question
Hi Guys,
I know this may be a stupid question that may've been answered somewhere on this site, only, I can't find it. I'd asked a few questions earlier this week regarding squealing drivetrain and received no responses. I suspect the question was overly loaded and I will keep this question simple.
My '77 Wag came with A/C (not currently functioning, but soon I will replace its bad parts (compressor, etc.). My confusion come from the two sets of controls. On the thr left side of the gauge panel is your standard a/c-heat-fan-defrost controls. On the lower dashboard, below and under the steering column, are two pull typ buttons with air flow symbols on them. Under the dash is a black plastic vent system that runs the full underside of the dashboard. There are vents on this piece and another two knobs. One is a fan control knob and the other, I assume, is temperature control.
What are the actual functions of these two sets of knobs? Should there be two sets? Are either my gauge panel or underdash vent system, up(down)grades from different Wagoneer years?
Any insight would be appreciated.
Thanks,
Eric
1977 Wagoneer \'Siouxsie FireSnake'\ AMC 401 C.I.D.\ Stock Setup - [Currently on the DL]
Old 03-11-2005, 07:50 AM
The 2 dash knobs with the air symbols are the pull controls for the very rare dual choke option...just kidding. [img]smile.gif[/img]
They operate the fresh air vents located on the drive and pass side kick panels near the floor.
-Geoff Hill
Old 03-11-2005, 07:52 AM
Cool. Thanks Joe. That's exactly what I needed to know. I love this site!
Old 03-11-2005, 07:55 AM
You know what, Joe? Someone tried to tell that those for for the choke. Funny.
Old 03-11-2005, 07:56 AM
Thanks 'Anti-riced'!.
Old 03-11-2005, 08:19 AM
Pman's Avatar
Pman Pman is offline
Those knobs are actually Cessna 150 throttle controls.
The two A/C controls work as follows:
The one on the right is the temp. Clockwise is cooler, Counterclockwise warmer
The one on the left is the fan control. It should have a P/C (pre-cool) notch as the first position while turning clockwise, then after that notch, continuing to turn clockwise, it's high to low fan on a rheostat mechanism.
Pearsall Smith
82 Wagoneer Limited (Cracker)-360 c.i.d.,Rusty's 4" Lift, Rancho RS9000x Shocks, TFI Upgrade, BFG 31" All Terrains
88 Wrangler Laredo (Tubbles)-258 c.i.d.,32" BF Goodrich Mud Terrains,3.5" lift, 8000lb. Warn Winch, Aussie Locker (Front)
81 CJ 5 (Lulu)-304-T150-D20
Old 03-11-2005, 08:21 AM
Thanks Pman
