Old 06-11-2002, 08:11 AM
coolguyinjeep coolguyinjeep is offline
Arrow
Hello. I was wondering what the lengths were for the springs on my 74 cherokee. i think Th backs are 56" but I want to be certain. I was also wondering if any other makes of springs (ie checy or ford) will fit? The reason being, the tallest non custon spring I have found was 6" lift from Rusty's and I have heard bad thing about them. Thanks for the help guys,
Mike
95 wrangler. Just got my project vehical, a 74 cherokee with 2-amc 401\'s, 2 th400 tranny\'s, and 3 quadra-trac t-cases. Future will be a tpi fuel injected 383, around 12\" lift and 38\" meats.
Old 06-11-2002, 09:44 AM
Can't help you on the spring length.. sorry.
I do have a question for you...look at the mounting of your rear spring packs... are they mounted on posts coming off the frame or enclosed in a box style mount?
Just curious...thanks
BTW... reading your sig tells me you will be posting alot of questions her shortly... Be glad to help answer some for you...
Todd
www.ttsfabworks.com
Old 06-11-2002, 09:57 AM
RamJetFSJ RamJetFSJ is offline
FYI, The springs from Rustys are only 4" lift springs with 2" blocks.
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
Old 06-11-2002, 11:06 AM
Arrow
Hello, I am the same guy that has been emailing you about your spring inversion kit. I do have the post setup but Will be changing that soon.
Thanks,
Mike
Old 06-11-2002, 12:02 PM
Gotcha!!!...
Todd
www.ttsfabworks.com
Old 06-11-2002, 12:23 PM
Stuka's Avatar
Stuka Stuka is offline
Rusty's kit will *NOT* work on the back of your rig. They springs will work on the front, but not the back.
I made this mistake...and I dont want others to do the same. What I had to do was do a shackle flip in the rear. The front springs are nice. I kept my 2" blocks in the rear...rear sits about 2" higher then the front. Should have gottenn 6" springs up front..but ohwell.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 06-11-2002, 03:25 PM
No one apears to be interested in this but, just for fun, I'll toss it out again.
Rear post mount, 3-4" lift, Chevy replacement springs by Triangle Springs, made in Mexico.
Here is the pic with part # and bar code, talk to a good spring shop, they can fix you up.
You will need the jeep bushings pressed into the replacement Chevy springs. It works, I like them, nice and stout.
Old 06-11-2002, 08:59 PM
So chevy springs will fit my cherokee front and rear?
Thanks
Old 06-12-2002, 05:53 AM
BigBadWag BigBadWag is offline
tadsal, How much did those springs set you back? What should I do/where should I go to get a similar set? Thanks. -Zach
<a href=\"http://daphreak45.tripod.com/jeep.html\" target=\"_blank\">My 1974 Jeep Wagoneer</a><br />-RIP-
Old 06-12-2002, 10:35 AM
How did you level out the back to compensate for the front soa?
Thanks,
Mike
Old 06-13-2002, 06:39 AM
Actually I didn't do the SOA, the previous owner did. All I can see that's used to lift the back is 3" blocks and MAYBE a set of springs with a slight lift over stock. The reason the Wag sits level now is because the front spring packs only have 2 leafs Apparently the PO just used less leafs with the spring over so as not to get much higher than the rear. This will be changing whenever porkchop produces his rear shackle flip kit Hopefully I'll buy his kit and then buy new springs for the front and end up sitting about 4" higher all around Seems like the shackle inversion is about the only way to compensate for the front SOA. -Zach
Old 06-13-2002, 09:03 AM
Pretty sure they only fit the rear of our post mounts, I have the chevy shackles with jeep bushings in them. I kept them on top of the post, below was too much lift (about 7" and would need a shim).
Mine were $321.02, both springs, 2 chevy shackles, 6 bushings, labor & tax. Any good spring shop should be able to set you up with these or make them. I've used Neil at Southwest Springs here in Tucson for several vehicles. Look for a shop that does big trucks and race cars (you know snoop around) these guys get very creative and have tons of X refrence books.
Be sure you take really good measurments before you take your springs off. With load & without load, eye to eye and depth of arch. I got myself in a heap trouble by not being very precise with the fronts.
I don't have SOA and probably won't, Sally will out live me and won't get in it if I lift it amymore.
