Closed Thread
Old 07-18-2005, 03:43 PM
Bombadier's Avatar
Bombadier Bombadier is offline
Post How to Search IFSJA Effectively
Credits: Tahnka
How to search IFSJA more efficiently and effectively. Drop kick the forum search out the door.
I was just using this method to search ifsja forums and thought hey, perhaps someone else had not thought of this; so I thought I would post this just in case. These methods are, in my opinion, far superior to using the forum search and return far better results.
Instead of using the forum search, jump out to http://www.google.com
Type in your normal search times like "tfi upgrade" and then here's the trick, at the end of your search append: site:igfsja.org. So here's an example of what I would type in to Google:
"tfi upgrade" site:ifsja.org
And here's an example of what that search will return: example
This search returns over 4,000 pages that are ONLY on ifsja.org with the phrase "tfi upgrade" in it.
Of course, most of those results will not contain what you want, so let's talk about optimizing the search.
Surrounding multiple words with double quotes causes Google to search on it as a phrase. So searching on merely, tfi upgrade, will find any page with both of those words on the page in any order. But searching with "tfi upgrade" (note the double quotes) will return pages that have those two words in that exact order, IE a phrase.
Using the plus and minus symbols can really help trim down the results. I often work my search results from four thousand down to less than 20. When you add a plus symbol in front of a word or phrase, you're instructing Google to show preference to listings that contain that word. When you put a minus symbol in front of the word, you're telling Google to not show listings with that word.
You may notice that the search results from the example above return some weird results. The problem is that many people have put the words "tfi upgrade" in their signatures; so you're getting any post with their signature in it. In the first search result the post is titled "Tow Rig Needed". When you click into that result you'll see that the user "rustywag" put "tfi upgrade" in his signature. So you can remove any search results with the word "rustywag" in them by using the minus symbol in your search terms like this:
"tfi upgrade" -rustywag site:ifsja.org
That eliminates 220 search results!
So as you search on things you must continuously research and refine your results using those Google "operators" until you get down to a group of things that are close to what you're looking for. If you really want to know what plugs to use in your TFI upgrade, try adding "spark plugs" to your search:
"tfi upgrade" -rustywag +"spark plugs" site:ifsja.org
You can chain as many operators as you want so try:
"tfi upgrade" -rustywag +"spark plugs" -blazer -springs -icecreamtruckorwhatever site:ifsja.org
Now here's a trick for just searching the page titles. Because the discussion forums plug the post title into the page title; this trick works great. Google uses an operator named "intitle" that will allow you to limit your search results to the titles of pages. "Intitle" must prepend your search terms, for example:
intitle:"tfi upgrade" site:ifsja.org
That returns 36 pages, or so, and the search results ignore the body of the messages; so you strip out all of the signature lines and casual mentions of the topic that may not be the intent of the forum post.
You can even show only pages with the word "dizzy", anywhere on the page, that have titles with the phrase "tfi upgrade" it in using this:
dizzy intitle:"tfi upgrade" site:ifsja.org
If you only want to find forum posts with "these words" in the title, then using the "intitle:" operator is the BEST!
Here's a link to Googles cheat sheet on how to use their most common operators: http://www.google.com/help/cheatsheet.html
Don't forget that using the above methods, you're searching the ENTIRE ifsja.org website, not just the forums; so this method will return the tech-articles as well.
Why do I carry a gun? Because a whole cop would be too heavy.
Originally posted by 2MANY4X'S2FIX:
I just want her to suck, squeeze, bang, and blow as reliably as the rest of the fleet. Is that too much too ask?
"Gilgamesh"
1981 Cherokee Laredo W/T
Like MountainBiking?
Visit the Land of Off-Topic
Old 07-18-2005, 03:46 PM
JeepFreak JeepFreak is offline
Great post. Thanks for the tips.
[ July 18, 2005, 09:47 PM: Message edited by: JeepFreak ]
Old 07-18-2005, 03:50 PM
brent's Avatar
brent brent is offline
Interesting. Will be hard to break old internet search habits, but the + and - parts I may start using right away just to eliminate the excess. Thanks for the info.
Brent
79 J10 360-T18-D20 D44's 31X10.5 Edel 1406 w/R4B, speed
-despite thousands invested, 360 in putrid death dance-
"Buy the Ticket, Take the Ride."
Old 07-19-2005, 01:32 AM
scantar's Avatar
scantar scantar is offline
Excellent info! Thanks!
Steve
Old 07-19-2005, 08:24 AM
Bob AZ Bob AZ is offline
Great post, thanks. I keep a MS Word document on my desktop named Jeep fixes for anything I think I might need later. I just highlight the text, and use 'paste special' 'unformatted text' to keep the graphics out and save memory and ink when I eventually print it out
Old 07-19-2005, 02:06 PM
turtlejoe's Avatar
turtlejoe turtlejoe is offline
Cool
Great information. Too bad we can't make a sticky to keep it at the top of some of the topic areas.
Thanks!!
Kerry - Raised by Jeep
"Got Altitude?"
"Trigger"
'78 Cherokee Chief WT 33X12.50 BFG A/T's, 15X8 Rockcrawlers, 4" BDS lift, TFI, NOS QT, TH400
"Sherman"
1993 4.0L Grand Cherokee, 44HD rear, 4:10's
"Roxie"
2004 Rubicon
"Moose"
2000 Ford Expedition XLT with 4.6L
Old 07-19-2005, 03:37 PM
Bombadier's Avatar
And that's why I'm.....
BTT
[img]smile.gif[/img]
Once again, thanks to Tahnka, he had the patience to sit down an make the original post.
"Gilgamesh"
Old 07-20-2005, 05:37 AM
Bombadier's Avatar
A lot of people probably ignore Stickys at other bulletin boards, but oh well....
BTT
"Gilgamesh"
Old 07-24-2005, 12:28 AM
Bombadier's Avatar
BTT
"Gilgamesh"
Old 08-05-2005, 12:40 AM
Bombadier's Avatar
BTT
"Gilgamesh"
Old 08-05-2005, 06:30 AM
Justin Kerns's Avatar
Justin Kerns Justin Kerns is offline
Very cool - and BTT!
Justin
79 Cherokee S 360, TH400, QT
Old 08-05-2005, 11:06 AM
Tahnka Tahnka is offline
Original Post: http://www.ifsja.org/ubb/ultimatebb....=030930#000000
Hehe I just added a google search bar to the Georgia Full Size Jeep forums that by default, searches IFSJA.org. Check it out at http://gfsj.org/forums.
Or, um, Googles actually, oh well...muahahahahaha
[ August 05, 2005, 05:09 PM: Message edited by: Tahnka ]
Christopher
My DD: '84 Gwag
Georgia Full Size Jeep Club
Effectively Search IFSJA
--Wheel Stock
Old 11-23-2005, 05:19 PM
Bombadier's Avatar
Young & Old.... Noobs and farts....
BTT
"Gilgamesh"
Old 11-23-2005, 11:36 PM
nsanebiker's Avatar
nsanebiker nsanebiker is offline
Save this in your favorites and you will always get to it.
IFSJA Search
just make sure you hit the radio button for IFSJA.
Enjoy
James
1973 J4000 Custom Cab: 360/T18
My DD: DOZERCON
2012 Jeep Wrangler Rubicon Unlimited
Old 11-24-2005, 01:40 AM
Rob z's Avatar
Rob z Rob z is offline
Sweet!
89 Grand Rottweiler shuttle
Old 01-07-2006, 03:06 AM
pb's Avatar
pb pb is offline
bump
Paul
1975 Wagoneer DD
Old 01-09-2006, 02:31 AM
nograin's Avatar
nograin nograin is offline
Lightbulb
Nice. And don't forget this one for Old threads. Can't remember who set this up, but it works well.
IFSJA Subject Keyword Search
'85 Grand Wagoneer
360 727auto-trany, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 01-04-2007, 02:33 PM
jeepstrapped's Avatar
jeepstrapped jeepstrapped is offline
bump
Just because I am using it and it is handy.
Back in Grad School again
78 chero, new old 401
green waggy
79 chero parts
Old 01-04-2007, 02:36 PM
scantar's Avatar
Originally Posted by jeepstrapped
bump
The mods should sticky this doggone thing 'cause it IS really useful info.
Old 01-04-2007, 02:38 PM
It comes in especially handy for searching for small words like
gmail
For some reason the forum search returns almost everything but the thread I was looking for
green waggy
79 chero parts
Closed Thread
