Old 11-11-2002, 06:32 AM
esgraham esgraham is offline
Arrow
I have several leaks from my car right now. The transmission fluid is leaking, the radiator is leaking, and there could be more. The problem is that I park my car on the street and the street is starting to look like an auto shop floor. The car is running, and at this point I do not expect to fix these problems unitl spring. How can I keep the fluids off of the street? I can use a piece of carboard when its not raining or snowing, but does anyone have any better ideas?
Thanks.
1987 Grand Wagoneer<br />V8 360 5.9L
Old 11-11-2002, 07:32 AM
Cheap cat litter works pretty well.
Old 11-11-2002, 07:34 AM
Damage, Inc. Damage, Inc. is offline
At some shops I've been to they use these mats; they absorb the liquids VERY well and have a sticky-backing to adhere to the floor. Don't have a clue where to get them though!
74 Cherokee
Old 11-11-2002, 07:41 AM
CowKiller CowKiller is offline
FSJ Executioner
pig mats!
they are what we use at tech school.
heres one place that has themhttp://www.stratfords.com/spill/spill__80.html
heres anotherhttp://www.matthews.com.au/newpig/Haz_Mat_absorbents.htm
hope they help
they work great. and hold alot
Corey Zakeosian
2002 gmc 2500Hd duramax
2000 Ford f-550 work truck
1986 f350 6.9 diesel hp60 front, sterling 10.25 rear, 36x12.5 military wranglers. TOY!
NO JEEP
I am ready to meet my Maker. Wether my Maker is prepared for the great ordeal of meeting me is another matter
Old 11-11-2002, 09:25 AM
Geeeep's Avatar
Geeeep Geeeep is offline
I bought a aluminum drip pan at the local auto parts store like this www.partsamerica.com item # 11430
It's heavy enough that it doesn't blow away, and wipes up easy. Makes ID'ing those fluids easier.
Dave Pitts, located directly over the center of the earth!
GW - 87 GW 360/4bbl/727/208 Vinyl floor, manual windows, no woodgrain
Find someone to haul your Jeep here: YT Hauling Schedule
Old 11-11-2002, 09:45 AM
Bluesky4x4 Bluesky4x4 is offline
I use the same aluminum pan. On cleanup, I typically throw some oil dry on the pan after draining it to get the bulk of the residue then wipe it down. Works great. Walmart has big ones that will go from rail to rail (catches all the tranny fluid from my crossmember). Autozone has some smaller ones.
1982 Wagoneer Limited | 360 | TF727 | NP208 | D44/AMC20 | Project Stage<br />1983 Cherokee Chief | 360 | TF727 |NP208 (swap) | D44/AMC20 | Runner<br />1995 YJ | 2.5l | AX5 | NP231 | D30/D35 | 5\" lift | Onboard Air | Full Cage | 33\" Procomp MT<br />1995 XJ | 4.0l | AW4 | NP231 | 8 1/4/D30 | 4\" lift | 30\" Nonamers
Old 11-11-2002, 10:53 PM
The aluminum pan will be perfect. Thanks.
