Old 04-06-2020, 04:16 PM
offthebeatenpath's Avatar
offthebeatenpath offthebeatenpath is offline
Post mount leaf spring options
I've got my '65 J200 w/the 230 Tornado (currently in pieces), so naturally I'm thinking about the suspension I've gone down a whole bunch of rabbit trails, and here's what I've found:
The only "off the shelf" suspension option is Hell's Creek. Not a bad option, it's just expensive - $1400 or so.
Deaver won't return my emails.
Some suggest getting springs re-arched. The closest place to me that would do it (4 hours away) quoted me $750 an axle. Plus bushings.
Some say bastard pack/helper springs/add-a-leaf/blocks/air bags. All have some potential, but also each have their own drawbacks. And most of those are anectdotal or skeptical at best.
Okay, hold my beer and watch this..... Here's what I'm thinking.
Here's the dimensions of the springs, as found in this thread (here):
1962-69 trucks use:
22 x 22 x 2 inch front springs with 7/8 inch post mounts and 9/16 inch shackle bushings
26 x 26 x 2 1/2 inch rear springs with a 7/8 post mount and 9/16 shackle bushings.
Then, found in this chart (here) you can see that front springs from a 76-86 CJ match the dimensions of the fronts for early Gladiators:
22 1/16" x 22 1/16" x 2" @920lb rating (for 6 leaf pack)
And that the rear leaf springs from a 73-87 Cheby C10 2WD match the dimensions of the rears for early Gladiators:
26 x 26 x 2.5" @ 1290lb rating (other options also)
If, then, so......
You found a place that had the correct bushings (some require brass, some don't), assuming the bushings that come in the springs are wrong, that could be pressed into place, like this:
http://www.stengelbros.com/leaf-spri...ring-bushings/
Couldn't you theoretically have a proper set of new leaf springs for a post mount suspension equipped truck for close to $500?????? ($100/ wheel, plus bushings & labor)
Now, I know there's still a few variables. Specifically spring rate. And what the height/arch of the springs are.
But I think this could work.
Help me out here, am I onto something? What says you?
Old 04-07-2020, 09:12 AM
There's a guy on FSJ.net that just documented converting the Post mount to a system similar to the '76 and later FSJs. Using available brackets and springs.
https://www.fsjnetwork.com/forum/vie...p?f=12&t=18528
Old 04-08-2020, 08:13 PM
That’s a pretty cool set up, but I’m not looking at going that far- he changed all the spring and shackle mounts, all four brakes, swapped axles, changed from SOA to SUA. I’m just talking about springs
Old 04-09-2020, 08:38 AM
It may work or it may not?
As you said height is an unknown.
Also spring eye sizing may make finding correct post mount style bushing(s) difficult?
Old 04-09-2020, 02:51 PM
Heep-J4000's Avatar
Make your bushings on a lathe from some nylon bar.
Did that for the front leaf springs of my 73 j4000
Old 05-14-2020, 10:28 AM
I found the rear posts I torched off a J4000 if anyone needs them.
Leaf Spring Pin Broken berettaguy General FSJ Tech 11 12-01-2012 04:22 PM
J10 spring mount q's... grand_wag_85 General FSJ Tech 4 04-10-2006 01:13 PM
What is a post mount spring? 1987WAGGY General FSJ Tech 3 02-25-2005 01:16 AM
Rear leaf spring mount question Loki General FSJ Tech 2 07-11-2004 01:18 PM
Anybody Try This Lift for pre-'75 Wags? Kimbrough General FSJ Tech 10 01-21-2002 07:24 AM
