Old 02-02-2020, 02:50 PM
maybeadinosaur maybeadinosaur is offline
Door lock and unlock
Hi friends!
88 GW - Driver door switch will engage the LOCK feature for all doors, but it won't UNLOCK.
Passenger door switch will UNLOCK all the doors, but it won't LOCK! :P
I've cleaned the contacts on the drivers side, some time ago, but no change. Maybe I wasn't thorough enough.
What are your thoughts?
Old 02-04-2020, 11:29 AM
Originally Posted by maybeadinosaur
Hi friends!
Did you take apart the switch down to the springs and copper? Probably was t thorough enough.
Old 02-07-2020, 06:42 PM
I don't recall - I got down to where the wires slide on their tiny little posts and I cleaned those to a degree. But it sounds like I need to do it again.
Old 02-09-2020, 06:54 PM
MrN2OBelvedere MrN2OBelvedere is offline
Yeah, that's not far enough. You have to completely pull the switch internal mechanicals apart. There's little prongs that are bent in keeping it all together. You pry these back and the halves of the switch will come apart. I almost guarantee you will find this switch all gunked up. I certainly did. Clean up all the contacts and switches in all four doors.
best towing option for boat with J10? Unlock hubs? EL Grande Honcho General FSJ Discussion 5 03-18-2013 02:24 PM
90-91 Remote door unlock Key fob red mistress General FSJ Tech 8 06-30-2010 05:41 PM
Can't unlock my doors from outside using the key NYK General FSJ Tech 5 12-12-2009 04:00 PM
How to unlock your FSJ if you are locked out grandwag89 General FSJ Discussion 16 07-25-2009 07:59 PM
Locks Hard To Unlock...... swclemons General FSJ Tech 5 12-14-2000 02:55 AM
