Old 02-02-2020, 02:18 PM
hstovall1 hstovall1 is offline
Fuel pump dying?
My 1991 Grand Wagoneer has trouble starting after it has sat idle for a few days. The engine turns over for a long long time before it catches. Not getting fuel. I
Old 02-02-2020, 02:22 PM
your power valve is probably leaking all the fuel into the intake and draining the fuel bowl. then it has to crank a while to fill the bowl back up.
Old 02-10-2020, 12:25 PM
So is that a carb rebuild?
Old 02-11-2020, 06:35 AM
that or a new power valve. the "new" valves in the typical over the counter rebuild kits are not very good. often very old stock.
holley power valves are too short on the threaded end for the motorcraft carbs.
i use Quick Fuel single stage power valves in these carbs. they have a longer thread on them. 6.5 to 8.5 range.
Old 02-17-2020, 08:05 AM
Also, these AMCs are notorious for having all the fuel evaporate due to hot intake/ engine compartment. Does your carb have the 1/2" insulator under it? Electric fuel pump will minimize this issue and help with vapor lock [with a fuel return line].
Carter Fuel Pump Install my experience KdkGrizz General FSJ Tech 5 07-29-2016 05:21 AM
42 Gallon Suburban Fuel Tank Installation (With more Pics!!!) Wagoneerlover General FSJ Tech 42 09-14-2010 08:34 PM
NO FUEL ....Bad fuel pump gear? thecountmc General FSJ Tech 5 02-01-2010 12:22 PM
I guess it's getting hot.... Belteshazzar General FSJ Tech 3 04-22-2009 10:02 PM
Upgrades/Tweaks to Improve MPG prayforsurf General FSJ Tech 33 01-04-2007 10:39 PM
