Old 09-07-2019, 06:37 AM
'89_Wagon '89_Wagon is offline
Rear Mount Gas Tank Write Up, Wagoneer
Just completed a rear gas tank swap in my 89 Grand Wagoneer. This post is meant to document the process I went through.
Why did I do this? At half a tank, my Jeep would start to sputter, hesitate, or die while taking turns and accelerating out of a stop. It did this when carbed and fuel injected. I threw a new pickup tube and fuel pump at it and nothing changed. Later, I was running two fuel pumps and it was very noisy. Rust is also a concern in my area so the saddle tank setup would eventually become a problem.
Why this setup? This setup does not require any notching of the frame and the fuel level gauge seems to work well enough. The fuel pump design solves any fuel starvation issues when turning or steering. The nylon lines won’t rust or corrode and parts themselves are cheap. There’s also plenty of ground clearance and it moves the fuel tank to the spare tire area.
Why not this setup? The gas tank is smaller than stock…. 19 vs 20. For me, it felt like I doubled the size since I had to fill up at half a tank before. Pressing fittings onto nylon can be a pain without the proper tools. I gave it shot with simple tools and decided it wasn’t worth the frustration so I dropped a lot of money on the tool (I used KD tools kit). I’m happy I did since it saved me a ton of time. Obviously… no spare tire.
Does it work? Short answer, yes. I have no problems with fuel starvation, cold starts, and as mentioned before the fuel gauge is good enough. It’s also quiet. It can be heard priming when the ignition is turned on, but it’s muted. I can’t here it all when the engine is running.
Old 09-07-2019, 06:45 AM
Parts List
-97 S10 two-door Blazer gas tank
-96 S10 Blazer fuel pump. This fuel lever sender reads accurate enough.
-Fuel lines. I used 5/16 and 5/8 nylon fuel lines and quick disconnect fittings. I paid a lot for the installation tool but the peace of mind was worth it as well as the ease of installation. I didn't want to fight with other methods of pressing nylon fittings to the hose.
-Fuel filter. I used one with 5/8 quick disconnect ends. The one I purchased was for a Buick Roadmaster.
-Quick connect fuel fittings. Keeping with the theme I purchased straight and elbow quick disconnect fittings. Fuel supply uses 5/8 and return uses 5/16.
-At minimum, four 5/8 fittings are needed. 1 @Fuel pump, 2 @ fuel
filter and 1 @ TBI.
-At a minimum, three 5/16 fittings are needed. 1 @ TBI, 1 for fuel
return at pump and 1 for the fuel tank vent port.
-Fuel line mounting clamps.
-GM 6AN fittings to replace stock pods. Found these on Ebay from a vendor called dstrumpet. Saves much needed space at the TBI.
-6AN to QD fitting. These mount to the GM TB adapter fittings above.
-Tank straps
-Hky pucks. Cheap spacers.
-Rubber sheet, 1/8 thick an 3 inches wide. 10 feet was $16 on Amazon
-Double sided tape.
-Copper reducer 2” to 1”. Bough off Amazon.
-1 inch fill hose. 1 foot length
-2 inch fill hose. 1 foot length
-Over flow hose 5/8, 1 foot length
-Over flow hose 3/4, 1 foot length
-5/8 to 3/4 fuel line adapter for overflow hose
TBI fittings are optional. Barbed fitting can be pressed into the nylon hose and rubber lines can be ran from there.
Old 09-07-2019, 06:58 AM
More Pics to follow
[IMG]D [/IMG]
[IMG]D [/IMG]
[IMG]D [/IMG]
Old 09-07-2019, 08:44 AM
SJTD SJTD is offline
Looking forward to more pics with hope it doesn't stick down as far a most of these installations.
Sic friatur crustulum
Old 09-15-2019, 01:31 PM
Here are some more pics.
[IMG]Gas tank by [url=https://www.flickr.com/photos/93784013@N04/][/IMG]
Rear mount, looking up. The rear strap is bolted to the upper lip of the rear cross frame.
Rear mount XJ gas tank (LS Swap) write up His-N-Hers Woodies General FSJ Tech 3 06-07-2019 09:08 PM
Help mounting steel gas tank in 79 Wagonner dkmcgowan General FSJ Tech 9 11-17-2014 01:11 AM
What do I need to do to this rear gas tank? or should I go bronco? Dr. Marneaus General FSJ Tech 18 04-08-2014 04:08 PM
Fuel tank Swap Write Up (With Photos) Wagoneerlover General FSJ Tech 12 11-27-2011 09:48 PM
42 Gallon Suburban Fuel Tank Installation (With more Pics!!!) Wagoneerlover General FSJ Tech 42 09-14-2010 08:34 PM
