Old 08-09-2019, 04:18 PM
BamaWagoneer BamaWagoneer is offline
A/C Rattling Sound
The A/C on my 88 Wagoneer makes as best as I can describe a rattling sound when turned on. I can't hear it from inside only from the outside.
Works great otherwise. Blows really well and gets cold. Riding in the vehicle you would never think anything was wrong.
From the outside, the sound is coming from somewhere on the driver's side maybe but honestly I'm not sure if I ever walked to the other side to listen.
Any ideas?
Old 08-09-2019, 08:16 PM
Wild guess would be the AC clutch.
Old 08-10-2019, 09:09 AM
The York compressor are noisey. If its abnormally noisey, it may be low on oil or is failing.
GW has developed some sort of rattling noise from the engine or trans that I can't id DanHS General FSJ Tech 14 12-05-2009 10:17 PM
A/C wiring DanHS General FSJ Tech 3 06-25-2006 01:11 AM
A/C to non A/C (heat only) bowtieman55 General FSJ Tech 16 06-13-2006 09:45 PM
A/C glitches Ridgbak General FSJ Tech 5 05-23-2003 04:02 PM
A/C Compressor or clutch making rattling noise Coley General FSJ Tech 10 05-18-2001 10:53 AM
