Old 06-11-2019, 02:17 PM
J10 Bob J10 Bob is offline
Holley sniper EFI 727 kickdown
I have a 1983 J10 360/727 I just installed a Holley sniper EFI. I have a concern about the kickdown linkage. Holley tells me they only support GM transmissions (nice) The linkage on the sniper has two holes for the trans one for TH350 and one for 200R4/700R4. My concern is linkage travel. Do I need an adapter?
Old 06-11-2019, 06:53 PM
acct21's Avatar
acct21 acct21 is offline
No adapter required — I just used a 1/4” threaded stud/lock washer/nut combo from Summit. Used the hole that best approximated the hole on the 2150.
Downshifts perfectly; no issues at all. Didn’t have to adjust anything.
https://www.summitracing.com/parts/SUM-G1427
Old 06-11-2019, 09:22 PM
Talking Thank you
Thanks man the info you provided is just what I need to hear.
Old 06-12-2019, 02:03 PM
pickledtoast pickledtoast is offline
I'm actually taking a look at the same issue on mine this weekend. I initially set it to where it matched, but didn't really pay much attention to it. Now it shifts at ~3500 at WOT.
Old 06-14-2019, 04:44 PM
acct21's Avatar
It wasn't an exact match. One hole sets it a bit forward, and the other a bit further back of the throttle plate axis. I'll look and verify which one I used.
Old 06-30-2019, 08:13 PM
Achilles's Avatar
Achilles Achilles is offline
Can you post a picture of how it is set up on yours?
Life happens while you are making plans...............
Old 07-01-2019, 11:27 AM
that is your email? I can forward a pic I took at lunch to you.
Old 07-01-2019, 08:15 PM
Achilles's Avatar
Sent it via PM
Old 07-02-2019, 07:04 AM
Replied.
Old 07-06-2019, 06:51 PM
Achilles's Avatar
Thanks for all your help!!
Holley Projection or Howell EFI? Eugene 1 General FSJ Tech 31 10-30-2015 09:01 AM
Lokar kickdown on a 727 scoutjeep360 General FSJ Tech 1 04-16-2006 02:50 PM
Holley EFI Turnall General FSJ Tech 11 04-27-2005 08:21 AM
727 kickdown question ddjjeep General FSJ Tech 2 03-10-2005 10:37 AM
Is there a Holley Tranny Kickdown Bracket for FSJ? 88GW General FSJ Tech 2 05-10-2002 10:23 PM
