MSD Fuel Injection ........
  • Sunbeam Fanatic
    • Dec 19, 2009
    • 62
    ......... has anyone used it on an AMC V8?
    1979 Cherokee Chief 2 door
    Original RHD for the UK market
    AMC401 - GM4L60E (uprated)
  • babywag
    • Jun 08, 2005
    • 10288
    Yes.
    You can read about his install here.
    • acct21
      • May 20, 2014
      • 735
      I didn't go through all 20+ pages, but from the looks of it he spent 2+ years getting it to run right?
      • babywag
        • Jun 08, 2005
        • 10288
        If you read whole thread you can see it could have been resolved quicker.
        He worked on it sporadically and IIRC the big issue was bad ignition system.
        GM style HEI??
        Seems switching to a duraspark resolved most issues?
        • LosAlamosFSJ
          • May 28, 2019
          • 10
          Just Finished Installing MSD Ignition/Atomic EFI
          I put an Edelbrock Performer 4bbl manifold on, then bolted in the MSD HEI and Atomic throttle body. I did a fuel return system to avoid spending more money and time installing the pump in the tank. I live in an area where there is no emissions testing so I deleted the EGR and the eliminated the cat-back system by removing the tubing from the catalytic converter to the exhaust manifold and welding up all the ports. In doing so, I decluttered the top of the engine and still have the vacuum I need for the transmission, transfer case and brake booster. First run last night was pretty good, the transmission shifts where it should and the engine is nice and smooth. Start up was easy even when cold. The only things I ran into that I had to really work out were modifying the throttle cable bracket to get the ball socket closer to the ball stud on the TBI and welding up ports on the cat-back system. The fuel pump is incredibly noisy so I'm going to build an aluminum box for it with some sound mat inside. I'll also re-mount the pump to the frame using rubber isolators.
