Old 04-05-2019, 09:11 AM
Originally Posted by jcisworthy
I adapt LS mini shaft rockers to AMC bridge heads. They have a 1.7 rocker ratio
Any more info on this? Be interested in seeing this.
Old 04-05-2019, 10:14 AM
jcisworthy jcisworthy is offline
Not right now.
Takes some modification to the LS shaft stand, additional clearance on the pushrod slots and pushrods but nothing major.
Old 04-05-2019, 04:58 PM
Not right now.
Found your thread on AMC forum...looks like stockers are an option as well.
Who knew!
Old 04-06-2019, 03:54 AM
I have a 401 engine in Australia with factory LS rockers, stands, and Comp Cams trunion upgrade.
That setup is not adjustable, similar to the factory bridge rockers. That engine made 531 hp and it in a left hand drive, very nice, 68 or 69 Javelin.
Old 04-06-2019, 06:59 AM
I moved these to a new thread. Pretty cool that you found this.
On a stock 360 the LS rockers would give ~.0266 additional lift.
A poor man's cam swap kinda.
Local yard charges 2.30/ea for rocker arms so ~$40 set.
But I have seen stock sets for sale too for cheap on CL.
Some new pushrods obviously needed as well.
Would a stock or mild cam like "RV" cam need the pushrod holes slotted?
Old 04-06-2019, 12:16 PM
I do not remember having to slot the pushrod holes with the stock LS rocker setup but it was about five years ago when I built that engine
Trunion upgrade is not needed to about .600 lift with the factory LS rocker as well.
Swap out the 8mm bolts with 5/16 cap screws, cut the LS stand in four sections and mount one pair per intake/exhaust. I think the factory LS may even work with a stock length pushrod. Geometry was pretty close as a bolt on if I remember correctly. I do not remember having to shim the rocker stands but again, I can be wrong, it all has to be checked as well as preload on the lifers.
The mini shafts I use now are / seem like, a T&D copy and they require additional clearance and pushrod length. They have a different installed height than the factory setup and they are adjustable.
Old 04-06-2019, 03:11 PM
I may give this a try be cool to get the little extra lift w/o swapping the cam!
Pretty cool you discovered this! I applaud your outside the box thinking.
Do you recall if they cleared stock valve covers?
Old 04-06-2019, 07:31 PM
or purchase a set of roller rockers designed for the motor?
Old 04-06-2019, 07:41 PM
Uh they are rollers and cheap.
A set of AMC 1.7 rollers not so much and a HUGE waste of money on a stock engine.
https://www.summitracing.com/parts/c...merican-motors
https://www.summitracing.com/parts/s...merican-motors
All $400+ stock LS rockers can be bought dirt cheap.
Old 04-07-2019, 04:45 PM
They clear stock valve covers.
Make sure you have enough distance to coil bind before doing anything. If the extra lift ends up in coil bind you will have issues.
Should have enough but it needs to be checked.
Factory LS rockers are very strong. They are also lighter over the valve compared to aftermarket rockers.
Old 04-07-2019, 10:46 PM
You are talking about trying to get tiny amounts of horsepower in your stock motors. It all seems to be a bit of a waste of time and funds. you will have to replace pushrods, may have to have machine work done and may have to replace valve springs? Again for what, to say I have roller rockers on my stock motor?
Old 04-08-2019, 07:09 AM
For same reasons folks install EFI, headers, etc. I like to modify things.
It is more about the added lift than having rollers.
Old 04-08-2019, 08:01 AM
Cecil14's Avatar
Cecil14 Cecil14 is offline
There isn't exactly anything practical about having one of these vehicles in the first place. What does it matter if someone sticks to the "most practical" build on a motor? It's pretty laughable that this is a question in the first place. We're all here because we're crazy, no two ways about it.
aa
Old 04-08-2019, 10:41 AM
I see a huge benefit to this idea!
If I am in the market to rebuild a mid 70's to early 90's 360 (or even just do the heads) with bridged rockers, then this would be right up my alley because its a cheap/reliable "upgrade".
When I pulled my 401 apart the studs, fulcrums, and rockers all had wear on them and needed to be replaced. So instead of paying $180 for a set of replacement rockers and another $30 for the studs, this option would give a rebuilder a cheaper route AND the benefit of a more stable valve train. The extra lift is nice but shaft mounted rockers is awesome. If someone were to do a warmed up engine rebuild and this idea works, why would you NOT do this?
Old 04-08-2019, 11:48 AM
as a fellow gearhead....sitting around talking about the time you bought new rockers for your engine and bolted them in is boring.
id rather sit around and talk about stuff like this. oddly enough,the why of it all rarely comes up .
Old 04-08-2019, 06:01 PM
Didn't you find/use 1.7 stamped rockers on a few engines? Thinking they are no longer available IIRC as well.
Old 04-08-2019, 07:52 PM
yeah,from jim miller. they were his now gone "econo series" and they were some nice rockers. go look in my 401 thread for pics. they had a big fulcrum,and you would set them at mid lift on the cam,and the top of the rocker would be 90 degrees from the stud when the installed height and pushrod length were correct.
he told me 90 bucks as i recall,came with poly locks. i shoulda bought every set he had,he was cleaning his shop out for a move. met my truck down in florida and handed them to my driver.
edit...it was 60 bucks. http://www.ifsja.org/forums/vb/showp...4&postcount=79
worked real nice with the performer grind cam.
http://www.mid-lift.com/PVS-PF.htm
Old 04-08-2019, 08:03 PM
I have a 360 in the garage I can use to mock up a set.
We shall see what things look like.
It is my opinion that it has many pros...and few if any cons.
Old 04-09-2019, 01:52 AM
You can get the rockers with trunion upgrade without stands on ebay for about 150 delivered I believe.
I recommend the trunion upgrade and stands are available from GM relatively cheap. It has been a while but I think they are 15-20 dollars each
Stands are on ebay cheap also
Old 04-09-2019, 11:23 AM
pickledtoast pickledtoast is offline
I am planning on running LS1 rockers after my cam is broken in. I made new stands as the factory LS stand places the shafts too high. Milling the stand surface on the head is an option, but the $15 worth of bar stock and my free time was better. Plus I can run the factory 1.6 ratios for break in.
Difference between the LS1 and AMC pushrod cup is ~.040. LS is lower. I will know if there is an extra .040 worth of compression in the hydraulic lifter after I get this damn engine together.
I can't seem to upload photos here. Too new?
https://scontent-lga3-1.xx.fbcdn.net...&oe=5D361A 7C
https://scontent-lga3-1.xx.fbcdn.net...&oe=5D023A 47
roller rockers o stamped? yossarian19 General FSJ Tech 3 05-23-2017 02:29 PM
AMC 360 Heads with Comp Cams Magnum Rockers Road Hammer Street & Performance 4 10-08-2015 02:19 PM
For those of you with roller rockers...have a question 78 Arizona Chief General FSJ Tech 26 12-11-2007 10:51 AM
Scorpion roller rockers on 401 baybilly General FSJ Tech 10 03-14-2007 07:26 AM
Who has experience with AMC roller rockers? TexasJ10 General FSJ Tech 7 08-16-2004 07:14 AM
