His and Hers LS Swap Double Build
  • His-N-Hers Woodies
    • Apr 13, 2018
    • 109
    Next on the list...cross member
      • Apr 13, 2018
      • 109
      Fuel pump with level sending unit. Hoping this works. If not I may look for another sender and put another hole in the tanks.
        • Apr 13, 2018
        • 109
        Water pump drilled for steam lines.
          • Apr 13, 2018
          • 109
          Jeep oil sending units adapted to LS block
            • Apr 13, 2018
            • 109
            Evaporator is out until I can get hoses made. Ordered the fittings this morning.
              • Apr 13, 2018
              • 109
              Actually got fuel pumping! One step closer
                • Apr 13, 2018
                • 109
                Got lucky with the cross member! There was another set of mounting holes in the frame for it that lined up with the 4L60E. The driveline angle is close but may need some tweaking.
                  • Apr 13, 2018
                  • 109
                  OK...things are starting to come together. The A/C is installed. New condenser, evaporator (for an '85 model, the one for an 89 didn't fit) and hoses crimped at Napa. Hopefully everything will gel with the LS compressor.
                    • Apr 13, 2018
                    • 109
                    Just about done with the wiring
                      • Apr 13, 2018
                      • 109
                      241C transfer case in. Going to attempt to use the stock shifter.
                        • Apr 13, 2018
                        • 109
                        #41
                        Opened up the rear diff but haven't started on it yet. Ordered G2 3.54:1 gears for it.
                          • Apr 13, 2018
                          • 109
                          #42
                          I have a mental map of how I will cobble together some old parts to make a drive shaft.
                            • Apr 13, 2018
                            • 109
                            #43
                            Any idea what to do with this thing (DOESN'T RUN) ? Are there desireable parts (headers, brackets, etc) or should it go to the scrap pile?
                            • rang-a-stang
                              • Oct 31, 2016
                              • 5512
                              #44
                              Timing covers always sell, Dizzy might get you a few bucks. Carbs are hit/miss (sometimes they go for $80, sometimes you can't give them away). The Evap cannistor would probably sell. I would put an ad up in the classified section saying you are parting it out and put a day that you are going to call the scrapper to come pick it up. I bet people will hit you up with some wanted items. I would say, at a minimum, pull the timing cover/oil pump. I MIGHT be interested in the Sanden A/C pump and brackets.
                              Chuck McTruck 71 J4000
                              (Chuck McTruck Build Thread)
                              00 Baby Cherokee
                                • Apr 13, 2018
                                • 109
                                #45
                                OK, here we go...
                                Radiator support back in place. Can't even tell I butchered it!
