Who could've guessed this was coming...
I got all my stuff in the mail by Saturday. I finally picked up some U-bolts local to me, and got started on this process yesterday.
As some(most?)... of you know, my wagon had some saggy springs in the back that weren't in the best of shape. When I put the 44044 lift springs on the front, I didn't have anything for the back and since it needed shocks all around, I cheated and got air shocks. That's held it up better, but not exactly where I'd like it. I also didn't like the idea of all the pressure being on my shock mounts. Luckily, they have been fine for the 3/4 year that its been set up.
So, I finally (through the help and guidance of some members) picked up a set of 2" full length "add a leafs" to lift it up. I'm no where near ready to do full springs back there, so the main leafs have to stay in place.
So, as a start i pulled the wagon into the garage and took a few pics to compare height before/after shock air down, and compare once i get the spring packs all back together and set up.
air shocks full
air shocks empty
hmm, not sagging as much anymore...
Well, got it all lifted up, took off the wheels and then disconnected the bottom of the shocks. Just letting them hang for now.
Well, I wasn't surprised about this next part. The U-bolts are so rusted that there is no point messing with the nuts. The threads were all mangled and rusted. So, I cut the U-bolts at the bottom. Took a bit, but no big deal... other than the loud surprising BANG when they finally snap after being cut most of the way through. and all the rust/road/grime dust that follows
Then I had to take one of the air hammers (with chisel attachment) and hammer the U-bolts off the spring mounting pads. They were rusted to the pads and took some doing to get them loosened so I could spin the remaining half's of each u bolt to get it out of there.
DONE
Oh YEA!,
I was happy to find that my main leaves were solid on each side. No breaks, no cracks, no nothing!
Not done yet though. Now I had to get the old center bolts out. Well, tried working at one of the nuts, but it rounded over due to them being just as rusty as everything else. So, I ground the nuts down. First side went all right. Knocked the rest of the nut off and hammered the pin through the pack and got them all apart. Had a hell of a scare on the other side though.
Forgot to take a pic of this,,. Anyone here seen a grinding wheel on a 4.5" grinder explode?! Yea, that happened when I was doing the other side's center pin. It must have had a little damage and snagged just right on the nut I was grinding and BANG, clunk clunk clunk clunk. Good thing I had a death grip on the grinder and was wearing safety equipment. I did have a chunk go through the glove on my right hand but luckily it just cut off a small piece of skin. Nothing major. Holy though...
Well, here's some results:
Next, will be going to the other building for some wire wheeling and paint.
air shocks full
air shocks empty
DONE
Oh YEA!,
