Old 03-20-2018, 09:53 PM
flatlander58 flatlander58 is offline
Ammerter be gone-wiring question?
Ok, so I just found a number of wiring hacks from PO that almost burned my Jeep up. As such, I have decided to re-do much of the wiring on my wagoneer in an attempt to improve safety. Part of my mods will include ammeter delete. I will replace it with a voltmeter due to the improved fire resistance. I also plan on running a 4 ga (or bigger depending on what I have available already) wire from the alternator “bat” post directly to the constant side of the starter solenoid.
That brings me to my question.
When doing this, should I keep the yellow 10 ga wire with the fusible link that would now supply my voltmeter and then link the old ammeter red wire to the same post on the voltmeter in order to feed the factory splice that was downstream of the ammeter and the delete the red 10 ga wire that used to run from the splice to the “bat” post on the alternator?
Or
Delete that entire yellow wire w/ fusible link and run directly a wire from the constant post on the starter solenoid to the splices and then tap a wire from the splice to the voltmeter?
Lastly, should any of this be run thru a circuit breaker or fuse? I have a spare marine 100A and 150A breaker I could add to this system somewhere, but where to put it.
I know this mod has been done (as I’ve read a number of posts) but I don’t see anything specific about which wires to keep/delete. I also am planning on keeping the stock alternator for now, but will likely upgrade to a bigger one in the future, so whatever I do now I would like to have it future proof (as much as possible).
Thanks for any help.
-Andy Stutz-
'79 Wag
Specs:
360 w/ alum intake & 4bbl Carter, TFI conversion, TH400, Cable Shifted Part Time QT w/ 16%OD, 6" BJs all spring, 35" Goodyear MTs, Custom Front Pre-runner style winch bumper w/ M8000, Ford Taurus electric fan, Rear Mini-spool.
Coming Soon: New floors, FITech EFI with G surge tank, MSD box
Old 03-21-2018, 12:09 AM
PlasticBoob's Avatar
All Makes Combined
I'm going off of memory here, but I believe you keep the main red wire that goes through the bulkhead to the "Big Splice" under the dash. This is a welded junction that was wrapped in duct tape from the factory, IIRC, and feeds everything else. Keeping the yellow wire instead is backwards and inelegant.
At the end of the red wire, solder on a fusible link. You DO NOT want a fuse in there, because the vehicle will be instantly disabled by small surges or very brief large loads that are pulled by turning on a bunch of power-hungry devices all at once.
So yes, delete the yellow wire completely, and move the red wire from the alternator BAT terminal over to the "always hot" solenoid post with a fusible link as close to it as practical.
One more tip - a resettable heavy duty circuit breaker between the alternator BAT terminal and the battery or solenoid is recommended.
Rob
Click for video
[b][size=2]
Old 03-21-2018, 06:37 AM
Thank you for the response. I am just wondering why I get rid of the yellow that already has a fusible link only to put one into the red wire? Is it inelegant to just keep the yellow wire because the voltmeter would essentially tap into in the line feeding the splice? Also, the duct tape over all the splices under the dash is factory!?!
I get the slow vs quick part of a fusible link vs a fuse, but where does a resettable breaker fall (fast or slow)? I’m thinking I could install a 150A breaker between alternator bat post and starter hot post like you recommend, and then install the 100A breaker in the red power feed to the splice under dash and delete the yellow wire, unless anyone sees any issue with that plan. I just like the idea of a resettable breaker instead of a fusible link because if something shorts, I could fix the issue and just reset the breaker and I’m back on the road/trail, but still protected. If a breaker pops too fast though, will go with the link because I don’t want to be resetting it all the time (and thinking I have a short when I don’t).
Thank you again for the help guys/gals.
-Andy Stutz-
'79 Wag
Specs:
Old 03-21-2018, 08:18 AM
Additionally, if I delete the yellow wire with the fusible link, should I tap the red (sensing?) wire from the alternator 2-wire connector into the 10 ga red wire (previously attached to the alternator bat post) that would be feeding the splice (currently the small red wire from the alternator splices into the yellow wire) or should that alternator sensing wire tap in elsewhere?
-Andy Stutz-
'79 Wag
Specs:
Old 03-21-2018, 08:59 AM
I think you're on the wrong track if you delete the yellow wire. I made a drawing showing before and after -
I did this from memory and the wiring diagram, but I have bypassed my '82 in this manner. Is this clear? Splices B and K are shown in the wiring diagram. I left the original fusible link and re-purposed the red 10 ga wire by unplugging it from the bulkhead connector, inserting a second fusible link, and connecting to the battery terminal of the solenoid. I think I abandoned-in-place the red wire from splice B to the bulkhead connector, and only removed the wire from the bulkhead connector under the hood. The 14 ga wire in the "before" drawing is the original fusible link, and it's not changed. The sense and excite wires to the alternator are not changed.
Old 03-21-2018, 09:26 AM
IMO the fusible link is perfectly appropriate here - no need for a fuse. It's not supposed to be readily replaceable. Instead it's meant to protect the car from burning up in case of a catastrophe like a wreck.
I doubt that you need as heavy a wire as a #4. Most generic battery cables are #4 wire. I would burn that bridge when I came to it by using the existing 10 ga wire until I was ready to upgrade the alternator. That's fine for any 10SI you might have, especially considering the short length and exposed routing of the wire.
Old 03-21-2018, 11:03 AM
Thanks for the diagram tgreese. I think that what you did was what I originally was thinking (except your “new splice” between red and yellow under the dash would be the + post of my voltmeter, with the other voltmeter post going to ground). I think I may still do the 150A resettable breaker between the alternator and battery (where you say to add the fusible link). I may reconsider the 4 ga. I may do 8 ga instead. I would like that to be a bit bigger than 10 ga since it will be carrying full alternator charging load to the battery (true only 63 Amps now, but in the future may be over 100A with a new alternator). I guess I will leave the original fusible link in the yellow wire instead or a breaker though, at least for now. If the link didn’t blow when carrying the alternator load, I suppose it isn’t likely to blow under the new configuration unless a significant short were to occur. Thanks again for all the help guys.
-Andy Stutz-
'79 Wag
Specs:
Old 03-21-2018, 11:25 AM
All Makes Combined
My TSM lists the red wire as the "battery feed - unfused alternator output" whereas the yellow wire is only listed as the "bulkhead to ammeter negative." In the stock configuration, if the ammeter breaks in a certain way, no battery power is able to make it to the Big Splice from the yellow wire at all, and the Jeep completely dies. I've experienced this in a friend's truck. Keeping the yellow wire (#55 on my wiring diagram) and using it to feed the entire cab is inelegant because the "flow" of electricity should be first to the Big Splice (#12, unfused alternator output), which is red. When charging, the Big Splice feeds EVERYTHING inside the truck; when charging, power was meant to flow from the alternator to the Big Splice, and then trickle out through the yellow wire to charge the battery. The yellow wire, at least on my '74, carries the charge delivered from the Big Splice from the ammeter to the battery, and supplies the Big Splice "backwards" during periods of no charge or discharge. If you think about it, it makes no sense that the yellow wire is protected, but the red one is not. This is why we have the meltdown/fire in the first place. Maybe there is no size fusible link that can protect the red wire during large charges?
So in order to keep the yellow wire, you need to either leave the cab-end connected to the same post as the red wire on the ammeter, or solder them together, and now you're still running an old (and potentially corroded/beat up) fusible link, and you also now have a mustard-and-ketchup frankenstein main feed wire. That's less than acceptable to me, but it will work. I just think it's better to have a brand new fusible link soldered onto a feed wire that is the same color as the wires supplying the rest of the truck from the Big Splice.
I was advised by Joe Guilbeau, the resident electrical genius here back in the day, to do it this way. It's been working great for over 15 years with no issues.
Here's a diagram of the flow of charge. When you use the yellow wire as a feed, during charging you reverse all of this. That doesn't make any sense to me, especially having to have a main feed wire that now has two different colors. It's not wrong, and it will work, but just doesn't seem very clean or logical.
See above. You can plug the voltmeter in wherever you want, but I would put it as far "down the line" as possible - the closer the voltmeter feed is to the cab input wire (yellow or red), the higher it will read. I prefer tapping it into circuits far removed from the feed, so it reads a little low (theoretically). In practice, it doesn't really matter that much.
What do you think this is, a Toyota? lol
The breaker is fast, just like a fuse, except that you can reset it quickly and reuse it.
This would work, but I don't like it because every time it pops, the car will INSTANTLY die and leave you wherever you are. A fusible link will allow you to potentially notice that something is wrong and get off the road before it blows. Also, if you are having issues large enough to pop the breaker, simply resetting it won't stop it from instantly tripping again. As TGreese said, definitely stick with a fusible link.
Rob
Click for video
[b][size=2]
Old 03-21-2018, 04:05 PM
nograin's Avatar
nograin nograin is offline
You guys have it basically right. I think those are good explanations.
The charge circuit (yellow wire with ammeter) was not supposed to be subjected to large charge loads for any length of time. But its large enough to handle them for brief periods, as well as emergency driving with the alternator dead or weak.
The fusible link should be sized to protect the smallest wire between the battery and fusebox or ground, whichever comes first. They protect against a battery short to ground. Lets say its a fully charged battery rated at 550 cca. Think what that means if there's a short downstream. Yup. that's a lot of power thats going to seek ground given a chance.
If you look at the late model SJs ('86 - '91) with much of the main junction moved to the engine compartment, there's a bunch of fusible links. You can get some idea of wire sizing from those as well. The earlier design is simpler, but it has its limitations.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 03-21-2018, 07:49 PM
All Makes Combined
I think an alternator's rating is for the absolute maximum output possible, so it would probably be a better bet to install a circuit breaker that is in the same ballpark. For example, my CS130 alternator is (I believe) rated at 105 amps, and my circuit breaker is rated at 100 amps. Not a perfect match, but I haven't had it trip a single time in over 10 years.
Something like this: https://www.amazon.com/Bussmann-CB18.../dp/B00139FQSS
Rob
Click for video
[b][size=2]
Old 03-22-2018, 12:37 PM
This is a scrap from the 1976 CJ wiring diagram. A '75-up CJ with a 232 or 258 has the same equipment as we are trying to wire up for the Wagoneer: voltmeter and 10SI alternator. This diagram is how Jeep would wire up the Wagoneer in question.
Notice that this diagram has two fusible links, just like the diagram I posted above. The 10 ga wire 12C goes through the bulkhead connector and to a splice under the dash (splice "P"). You can look at the complete diagram here - http://oljeep.com/gw/76_tsm/Section22.pdf
I can't argue with Rob's wanting to have all the wiring the same color - it's all red here - but it seems a lot of effort for something that's never going to be seen. Plus, I think there's some value in keeping the wire color that's already present in the car. Make a good crimp, solder and use adhesive heat shrink for an excellent splice.
I also think nograin has a good point, that the fusible link is meant to prevent a catastrophe when the battery shorts to ground. The ammeter fire comes from high resistance in the ammeter and is driven by the alternator output.
I know you can get at least a 12 ga fusible link that will protect 8 ga wire. Larger sizes may be available.
Old 03-22-2018, 09:39 PM
nograin's Avatar
No!
The purpose of a fuse or breaker is to protect the weakest links in the circuit. They are sized based on the wiring or device drawing load.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 03-22-2018, 09:58 PM
nograin's Avatar
Yes. and yes and I agree with the rest of your post as well.
I drew up some diagrams to illustate how a fusible link works in an ammeter type system. Concept isn't really that different when the charging circuit is moved. So maybe that page will be helpful to all.
Also, for those with an ammeter, I put together a page about how the circuit works and what to do to avoid problems. Too many times here I've read about the fusible link being bypassed, trying to drive with the ammeter needle pegged, or 'just' adding a few electric accessories to the battery.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Last edited by PlasticBoob : 03-22-2018 at 11:34 PM. Reason: Edited for visibility
Old 03-22-2018, 11:33 PM
All Makes Combined
Originally Posted by nograin
No!
Gotcha, with some questions! Wouldn't you also take into account the maximum output of the alternator? Say you have a CS144 that puts out 140 amps max and all your wiring is spec'd properly. Then you pull a 110 amp load - a 100 amp BAT breaker would blow every time you pull that load, wouldn't it? Or does the battery help reduce it by discharging? So then you'd need a 140 amp breaker? I guess I am coming at it from a different angle?
Also, doesn't a breaker on the alternator BAT output prevent damage from an alternator that goes crazy and starts putting out huge amounts of amperage? Or is it there to prevent the alternator from being damaged by the rest of the system pulling a load from it that is beyond its rated output? Or both?
Rob
Click for video
[b][size=2]
Old 03-23-2018, 07:55 AM
nograin's Avatar
No. We don't care how big the source is. We can have a 700 CCA battery and we don't change our wiring.
yes.
You're asking the right questions because many of us have been misled here. See if this makes sense.
The current flows from the highest potential. When the engine is running, this is the alternator. Only time the battery will help is when the alternator's output is exceeded. This happens with accesories like a winch which have huge power demands, and the voltage gets pulled down when this the winch is running. Lets leave the winch and plow situations aside and go to how the potential works.
Batteries have between 11 Volt when low and 13+ Volts when fully charged.
Alternators should be running around 14 Volts, sometimes a little less, usually 14.2 to 14.8 V depending on temperature, rpm and the type of regulator.
When we measure 14.2 volts at the battery positive, that's system voltage. It's coming from the alternator. As soon as the engine is shut off, it drops to the high 13s, until the surface charge disapates and we see its fully charged voltage, say 12.8 Volts.
The only way to know if the battery is being charged while the alternator is running is with an ammeter. The voltage just tells us that the potential is there to do the job. Once the battery is recharged, no current flow to it. Internally it will never reach 14, but it will develop a surface charge that floats closer to 14+ Volts in the system when the alternator is running).
Alternator Output
Related to what you are trying to get at, the alternator's max output will be available at high rpm. The power output of interest to us (and most older automobiles) is from idle and just off idle. For us, electrical demands at idle are about the same as when at high rpm. Only the ingition system may have a little more power demand at higher rpm and load, and thats 2 to 4 amps more at most.
Alternator output will only be what is asked of it. It never exceeds the demand. If its 14.5 volts and a 5 watt light bulb is attached, it will provide 5 watts at 14.5 volts. If there is a short to ground, both the battery and the alternator will discharge as much as the connections and wiring will allow. [That's close to what I illustrated on this page. Because the SI alternators are self feeding, we probably should make another diagram showing that situation.]
Alternators current output is limited by rpm and the current flowing through the primary windings. Remember, its basically just an electromagnet. The rotor winding is a spinning electromagnet. The current flowing through the rotor's windings is controlled by the voltage regulator. The output is the current induced in the non-moving windings. But if there is no demand, there is no current out. It has potential - 14.5 volts, but there is no flow.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 03-23-2018, 11:11 PM
All Makes Combined
Thanks for the explanation, it cleared up some things, but I still can't make the final leap...
Are there any situations where the alternator can go haywire and start overcharging and pumping out vast amounts of amperage? Say if the voltage regulator breaks? I had a situation with an original-style parts store voltage regulator that was overcharging, say near 16-17 volts. Was it also not putting out excessive amperage because the voltage shown was just potential? Maybe I do need an ammeter, eh? My temporary fix in that situation was to turn on the heater blower and some accessories to bring it back down to around 14 volts.
What would be the reason for putting a circuit breaker on the alternator's BAT output, in conjunction with a fusible link on the main feed wire to the cab (#12 or #55)? Is the breaker then redundant?
Rob
Click for video
[b][size=2]
Old 03-24-2018, 07:53 AM
nograin's Avatar
I can answer the first one quick. The other I have to look at the diagram so that will have to wait.
Yes, voltage regulators can fail in full field mode. That's fancy shorthand for saying the internal switch is closed (like putting a jumper across it). This allows as much electricity through the rotor windings as its wants. The output voltage will rise to whatever the alternator is capable. Some equipment will run better. Higher voltage means less current is needed for the same power. Other equipment will have problems as the high voltage can jump or break though air gaps and breakdown some components. The battery may try to accept more charging and inside may get hot, boiling off liquid.
I don't know about the circuitry in the SI regulator. Old school external ones are like the points types. Regulation is done by switching the power feed through resistance, no feed, and no resistance positions.
Good temporary 'fix'. The battery will draw more. Here's a link showing the charging voltage and current relationship in a series of photos (my jeep). I'll put a series of pictures somewhere more convenient soon or later. Notice when the battery was drawing more than I wanted, reducing the voltage also reduced the current.
https://www.forabodiesonly.com/mopar...ost-1971969715
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 03-25-2018, 07:12 AM
nograin's Avatar
Lets Looks at a factory system where something like that was done.
With wiring all distribution from the starter relay or solenoid, in 1986 the factory installed a fusible link between the alternator and the battery. This protects the alternator circuit from the battery.
Every wire coming off the distribution point is protected with a fusible link, greens or yellow in the diagram.
With the earlier wiring design, there is only one wire from the battery to the main distribution point. For that reason, only one fusible link was needed. A breaker or link on the alternator output might provide a little additional protection for the few seconds the motor kept running. And a breaker might kill the the motor faster or stop it when the ground fault was intermittant. If the short to ground makes good contact, all current will flow there as its the path of least resistance. That's why they assume the engine will stop and of course the alternator will too. Think back to the member who had a wire with bad insulation behind the dash. That's exactly what happened, engine stopped running. Being fused it was instant.
Then there was one with the mouse nest? I'm pretty it kept running only because the fusible link was replaced with a solid wire.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 03-30-2018, 06:38 AM
nograin's Avatar
Ammeter can be quite helpful.
A good moparts thread about that here.
The questions are whether its worth it to send it out for repair? is there a plow, winch or other items that will draw lots of current through the charging wires every time they are used?
I think the answers are: maybe if you really like to see whats going on. No unless you do something clever such as a relay and wire to directly charge the battery when accessories are used. No if the alternator struggles to keep up at idle with the A/C or othe equipment on.
Anyone with an '86 and later vehicle would have to add one that was calibrated for an external shunt. You have to really want one to go through that effort.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
78 Wag Alternator wiring Question j72440rallye General FSJ Tech 12 07-21-2014 04:21 PM
Wiring question..compat between 65 I6/68 V8 Gambler68 General FSJ Tech 0 11-20-2007 09:42 AM
TFI wiring question flatlander58 General FSJ Tech 4 10-23-2007 08:35 PM
Wiring Question Howard1964 General FSJ Tech 15 09-23-2007 09:54 AM
A Wiring question should be simple popeye44 General FSJ Tech 7 02-09-2004 03:15 AM
