Made up my own axle after bending a couple.....2 1/2" reciever hitch tube, .250 wall, 3/8 plate on each end, with corner gussets, drilled for dana 44 spindles. Used spindles and hubs from the same type rig, to get same bolt pattern, and run the same size on trailer and tow rig. Had everything on hand except the tube, and was able to do the welding myself (auto body tech).
Even if you have a local fabshop put it together, shouldn't run too much.
Never liked or trusted adapters.
3 x 5 not going to be real useful, IMO, but to each his own needs
