Old 10-28-2017, 10:59 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is online now
alternatives to OEM door panel clips
has anyone ever used a different,...
more user friendly clip for door panels
....or the rear side cargo panels on interior
so removal would not be so hard on the panels when prying out the clips
one member once suggested trying magnetic strips to hold
interior side cargo panels on instead of the clips,
i thought that was a good idea
any suggestions or tips appreciated.
dave in NC
Old 10-28-2017, 11:33 AM
velcro strips work well...
If the OEM metal clips have torn loose, even using the newer plastic ones is sketchy.
They sell some extreme velcro strips and backing is STICKY and separation is pretty difficult.
Very low risk of further damaging panels on removal.
Old 10-28-2017, 11:38 AM
kansasboy001's Avatar
kansasboy001 kansasboy001 is offline
Go to Lowes or your local hardware store and you can get trim screws in black or chrome. If you have black interior they blend in perfectly and are so much easier. You can always spray paint them for other interior colors too
Old 10-28-2017, 09:09 PM
SOLSAKS's Avatar
thanx for the two great ideas
from baby-wag and kansas-boy
now i have to choose which one to try,.....
maybe both, since i have a donor wagoneer to try them out on.
wish i could post photos,... putting finishing touches on the interior
and all the individual things coming together is easy on the eyes...
like all the polished rub strips on new carpet in cargo area and tailgate.
dave in NC
Old 10-30-2017, 08:00 PM
SOLSAKS's Avatar
trim screws worked best for me.
i could not make magnets, velcro, etc work.
did not use any factory panel clips at all.
thanx for the advice.
Old 10-31-2017, 08:22 AM
I glue the clip to the damaged panel with gorilla glue so they don't come off the cardboardish panel. It expands like foam so just a little drop. It reenforces the old material.
I use nylon prybars to remove clips from the metal. Works well.
Old 10-31-2017, 12:59 PM
SOLSAKS's Avatar
good idea to glue on the clips.
and nylon pry bars sound good too
i have used the expaaaaanding gorilla glue,....good stuff
thanx !
dave in NC
Old 11-01-2017, 11:35 AM
deckside deckside is offline
I've tried gluing mine but it is a PITA to line up just right and I end up mushing the clips. Im going to try velcro now.
1980 Wagoneer Limited "Prissyish"
Old 08-26-2019, 06:37 AM
Velcro ended up leaving too much of a gap, magnets didnt work either. Im thinking of making a template to get the clips to line up on holes properly then epoxy the clips to the backing board.
Old 08-28-2019, 01:30 AM
letank's Avatar
letank letank is offline
I have used small plastic insert similar to the license plate inserts , I trimmed the square end to fit the round holes .... the hardest part is the alignment of the screws with the new inserts, it works and make for easy removal and installation. Use screws with countersunk finish washer.
Michel
Old 08-28-2019, 04:04 PM
Im having a hard time envisioning it...wouldn't have a pic or two?
Old 08-28-2019, 07:22 PM
SlowGear's Avatar
SlowGear SlowGear is offline
For my cargo panel I wanted something that would release easier than the stock clips. I used a rubber grommet in the original hole and elevator bolts.
Attached to the panel:
Test mounting panel:
Completed:
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
Old 08-30-2019, 02:19 PM
Completed:
That is a clever setup, thanks for the pictures. Do you have specs or part numbers for the bolts and grommets by chance?
Old 09-08-2019, 10:56 AM
letank's Avatar
Here we go, the clip is the smaller version of the license plate clip
you will have to trim the inside square as pictured, the outside pointing ears are the corner that have to be trimmed with cutting pliers
and the result
Michel
88GW Disk brake anti-rattle clips mgmann General FSJ Tech 2 07-22-2011 07:10 PM
'72 GW stainless exterior trim clips Maryland Rick General FSJ Discussion 0 09-30-2010 07:24 PM
K8600 or other cam sound clips ? LS1Jeeper General FSJ Discussion 4 03-24-2009 05:31 AM
Replacing clips on tailgate regulator arms 83CherokeeLaredo General FSJ Tech 8 11-22-2006 10:25 AM
