Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Customer Corner: (Vendor product discussions)
Old 09-28-2017, 09:43 AM
cameronb1988GW cameronb1988GW is offline
Headlight Relay Harness
I had paid for a headlight harness with relays for my 88 Grand Wagoneer. Unfortunately, Serehill has passed away. His product was known for its excellent quality. Does anyone know of another high-quality source for a headlight harness? Thanks in advance.
Old 09-30-2017, 12:51 PM
mathman's Avatar
mathman mathman is offline
I had bought two from Serehill, one had a couple of wires come loose - should be an easy fix. If you're interested in that one, just give me your address in a Private Message and I'll send it on to you, no charge.
David
'78 J-10; '78 J-20 8400GVW
'79 Cherokee
'50 Willys (not Willy's) 4WD Pickup
Old 10-06-2017, 05:13 AM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
You're a good man, Mathman... That's a good thing, Rick would be proud.
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 10-08-2017, 12:31 PM
mathman's Avatar
Here's a few pictures:
The first picture is what the connector should look like - you'll want to refer to this one to make sure you get the three wires in the correct slot:
The second picture of the overall harness - but the connector with the wonky wire is disconnected from the harness (I had pulled all three spades to make it easier to fix the loose wire but I never got to it) and the spade that had the wire loose.
The third picture is of the three wires that go into the loose connector.
The last picture is of the connector and the spade that had come off in shipping to me.
It took me a little longer to get in the shop and find everything - I should have it in the mail to you by Tuesday (Oct 10).
David
'79 Cherokee
Old 10-17-2017, 10:04 PM
Received, and a token of thanks is in the mail. I can't wait to swap out those old headlights and protect my truck.
Old 10-21-2017, 08:40 PM
mathman's Avatar
Thanks - it's appreciated! Good luck with the lights!
David
'79 Cherokee
Old 12-04-2017, 01:15 AM
661warwagon 661warwagon is offline
I too would like to know if there are any good aftermarket replacements.
Old 02-09-2018, 08:29 PM
nograin's Avatar
nograin nograin is offline
Guys -
What's the status on these?
Is Rick's son going to be making them?
Would it be helpful if I posted the dimensions and so forth so people can make there own?
Should I ask a fellow who makes similar ones for Mopars if he'ld be interested in making them for FSJs?
The one I bought can serve as a model.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 02-15-2018, 09:52 AM
TPICherokee's Avatar
It sounds like Rick's son won't be making these (saw on another post).
If someone can get us a harness, we can send it out and have them remade and would sell them as Serehill headlight harnesses.
If anyone can help, let us know.
BJ's Off-Road
Old 03-16-2018, 04:52 PM
44BZ's Avatar
44BZ 44BZ is offline
BJ's Off-Road
That would be cool and props for giving credit where credit is due. Hopefully someone can come up with a set to share. I have one installed in my J2000, but would buy another for my CJ2a.
Old 03-16-2018, 05:02 PM
Kaiserjeeps's Avatar
Guys they are super easy to make your own. Get two 40 amp relays, use the old headlight wires to signal the relays, run two heavy 10 or 12 gauge fused wires (one for low beam, one for high beam, keep them separate for safety) from the battery for power to the bulbs and ground the relay. Swap in high heat ceramic plugs for the bulb connections, That is it. You can buy the stuff from Susquehanna motor sports and I believe they even sell the assembly pre done. It is not hard. Just a little time consuming.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's and a 7
Custom Relay'd headlight harnesses. 217 sold so far. serehill Homegrown Vendors: (Members who produce FSJ related items) 313 09-20-2017 10:09 PM
New Headlight wiring harness is awesome deckroid General FSJ Discussion 7 02-17-2017 09:42 PM
Headlight Relay Harness tomd General FSJ Discussion 23 12-06-2012 02:00 AM
Headlight Upgrade. H4 and Relays Mahamotorworks General FSJ Tech 3 12-09-2007 12:18 AM
Wiring old style (early 60s) headlight buckets into new style wiring harness jode General FSJ Tech 3 06-25-2007 10:11 PM
