Old 07-06-2017, 08:41 PM
Full Size Jeeper's Avatar
Full Size Jeeper Full Size Jeeper is online now
I did not think I was going to go this far, but I was only fifteen or twenty fasteners away from pulling the frame so why not. Need to pick up some jacks and blocks from my uncle tomorrow to get the back a bit higher. Should be able to pull the frame out Sunday if all goes well.
1978 Wagoneer
Mods:
Old 07-06-2017, 08:46 PM
Going to pressure wash the frame, POR 15 it and top coat it. Then put the frame back under it. Also need to replace some u-joints and check the brakes,this might take awhile.
1978 Wagoneer
Mods:
Old 07-06-2017, 08:48 PM
Had a lot of loose paint and undercoating on the frame. Scraped and sanded it then wiped it down with alcohol, used the recommended metal prep next. Washed the prep off after it reacted for thirty minutes and waited for it to dry. Only did the passenger side, hope to finished the driver side Saturday.
1978 Wagoneer
Mods:
Old 07-06-2017, 08:52 PM
1978 Wagoneer
Mods:
Old 07-06-2017, 08:59 PM
Rain,rain, and more rain. Tropical Storm Cindy is dumping lots of rain on us for a few days so the frame top coat is on hold for now. Did pick out a top coat for the frame from NAPA. A friend of mine used it and liked the results. It is kind of what you would see from the factory, which is what I wanted.
1978 Wagoneer
Mods:
Old 07-06-2017, 09:02 PM
Pulled the front axles to replace u-joints and a few other things. Waiting on a few parts from BJ's. Cleaned up and primed the housing.
1978 Wagoneer
Mods:
Old 07-06-2017, 09:05 PM
Decided to top coat the frame because the POR15 I used has no UV protection in it, and it will get a white haze over time. Sanded it with 320 and hit it with two coats of chassis black from NAPA. Very happy with it. Came out nice.
1978 Wagoneer
Mods:
Old 07-06-2017, 09:31 PM
Replaced u-joints and replaced some other parts on the front axle.
1978 Wagoneer
Mods:
Old 07-06-2017, 09:38 PM
1978 Wagoneer
Mods:
Old 07-06-2017, 09:42 PM
Built a body cart so I can wheel it in and out of the barn. Also wanted it safe when we start cutting out the floor pans.
1978 Wagoneer
Mods:
Old 07-06-2017, 09:44 PM
still hanging from the barn.
1978 Wagoneer
Mods:
Old 07-06-2017, 09:50 PM
1978 Wagoneer
Mods:
Old 07-07-2017, 08:59 PM
xabn82 xabn82 is offline
Heck yeah, looks good
Old 07-25-2017, 07:16 PM
Pulled the body out of the barn for the first time on the body cart. Rolled fine, but you need two people to keep it moving in the right direction with the four swivel wheels.
1978 Wagoneer
Mods:
Old 07-25-2017, 07:25 PM
Pressure washed the underside of the Wagoneer today. Just want to get all the dirt and grease off. Not worried about the undercoating. I think I want to use a product called Raptor. This is the before pic.
1978 Wagoneer
Mods:
Old 07-25-2017, 07:27 PM
1978 Wagoneer
Mods:
Old 07-25-2017, 07:31 PM
A few after pics.
1978 Wagoneer
Mods:
Old 07-25-2017, 07:32 PM
1978 Wagoneer
Mods:
Old 07-25-2017, 07:41 PM
I think it cleaned up pretty good.
1978 Wagoneer
Mods:
Old 07-26-2017, 01:34 PM
MJMadness MJMadness is offline
Is it just me, or do the Google Drive images not show?
I like what you're doing and want to follow along.
FrankenJeep (Turbo Wagoneer) build thread Ghinmi Street & Performance 230 10-04-2015 09:11 PM
How tall for a daily driver / mild off road Wagoneer lorenmjones General FSJ Discussion 18 09-11-2014 05:57 PM
Build thread - 3x Grand Wagoneer 89/90/91 sportsidedan General FSJ Discussion 22 09-03-2013 12:11 PM
