Old 06-15-2017, 04:40 PM
jcisworthy jcisworthy is offline
401 on dyno
AMC 401
511 HP / 500 TQ
Heads
• “Street Ported” factory iron with competition valve job
• 270 CFM @ .550 intake, 190 CFM exhaust @ .550
• Stainless steel 2.055/1.625 11/32 stem valves
• 7/16 screw in chrome molly studs and guide plates
• Bronze guides with positive viton metal clad seals
• Dual valve springs with machined 10* machined locks and retainers, spring seat locators
• Resurfaced plus intake and exhaust mounting surfaces milled
• Cometic head gaskets
Block
• Painted base coat clear coat AMC P44A Caravelle Blue
• Bored and torque plate honed .030 to 4.195 final bore, 9.5:1 compression
• Line Honed with ARP main studs
• Decked
• Oil drain backs modified for better flow
• Main oil feed enlarged for more volume
Crank
• Factory AMC 401 turned .010/.010
• External Balanced
Rods
• Full floating Molnar with ARP 2000 bolts
Pistons
• Wiseco ProTru pistons with Hasting moly rings, spiral locks
Oiling System
• Ported and enlarged Factory AMC passages in timing cover / filter adapter
• Drilled and taped pressure bypass valve spring retainer cap screw with bolt installed for adjustable oil pressure
• New pump gears and spring
• New stock replacement oil pan
Dampener
• New professional products
Flex Plate
• New SFI approved
Ignition System
• Pertronix III conversion installed in factory point style
• Fully reconditioned with locked timing set at 34* BTDC
• New brass contact cap, rotor
• New 7mm wires
• New NGK spark plugs
Carburetor
• Holley HP annular discharge mechanical secondary
Intake
• Ported Edelbrock Torker
Cam, Lifters, Timing Chain. Rocker Arms, Pushrods
• Custom ground Bullet Cams solid flat tappet with Johnson Hylift EDM lifters
• 260/274 advertised, 234/244 @ .050 duration, hot lash .016
• .3600/.3380 lobe lift, .576/.541 gross valve lift
• 110 LSA, intake lobe degreed to 106
• 1.6 stainless steel roller rockers
• Double roller
• New cam gear
• Pushrods, 5/16 chrome moly .080 wall thickness
Video Links
https://youtu.be/TtUIvH2uGEY
https://youtu.be/uPlqJYE1ZFk
https://youtu.be/JgNhowXCykQ
Old 06-15-2017, 04:43 PM
Link to dyno sheet
http://theamcforum.com/forum/401-on-...opic87986.html
Old 06-15-2017, 05:32 PM
awesomeness!
Old 06-15-2017, 06:08 PM
GET IN MY BELL EH! er... I mean
GET IN MY CHERO KEH!
Who did the head work?
79 Cherokee Chief
Old 06-15-2017, 07:39 PM
mattmopar440's Avatar
Holy power batman 1hp per Cubic inch and I would be happy but 500 hp
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 06-16-2017, 09:33 AM
Dont know if it is ok to say it here but the engine is for sale if anyone is interested.
Old 06-16-2017, 09:45 AM
Fine to mention, but you should also list it in the for sale section for more visibility.
Old 06-16-2017, 06:18 PM
SC/397's Avatar
SC/397 SC/397 is offline
Nice! Gotta love a Torker and a nice cam
Old 06-17-2017, 07:18 AM
Thank you. The torker has always worked well for me.
An air gap would probalby work for this application also but I had two torkers so I used one.
Old 06-04-2018, 08:28 PM
Jeepyz Jeepyz is offline
That's great. nice one!
Old 06-10-2018, 06:37 AM
Thanks
The engine went a best of 10.60 in an AMX that weighs 3000 lbs, I believe, with driver in it
It was killer air and a tail wind also. Runs 10.8-10.9 typically
AMX is a drag car only
Old 09-25-2018, 09:25 PM
Jpzyr Jpzyr is offline
Cool!
Rebuilt 401 Cam Break In and Dyno Runs crazydog General FSJ Tech 15 07-22-2010 10:29 PM
finally got my 401 back... dyno results midmichfsj General FSJ Discussion 18 01-26-2009 10:08 AM
Desktop Dyno for my 401 Combo? flyusmc General FSJ Discussion 22 10-15-2008 03:52 PM
The 401 revisited Elliott General FSJ Tech 20 12-14-2003 12:41 PM
401 misconceptions Ranger General FSJ Tech 14 12-07-2003 05:38 PM
