Old 10-28-2016, 05:21 PM
SC/397's Avatar
SC/397 SC/397 is offline
Originally Posted by Nikkormat
What do you expect the power output of this motor to be? Will it clear 400hp? 6250 RPM rev limiter capable? If it's not what would you change to make it rev to 6250? I'm looking to embarrass some more imports in the new wagon.
With the relatively small cam and the Performer intake manifold my guess would be about 350hp at 5000 rpm. It should have plenty of low end grunt thought, which is the goal with this one.
To clear 400 hp you need a bigger cam and better intake and bigger carb.
Page 3 shows dyno results for a 9.5 compression ratio 401 with a Isky 280HL cam, Torker intake and 750 Holley which made 380hp at 5200 rpm.
http://rebsamcandjeep.proboards.com/...no-time?page=3
If you want your peak horsepower at 6250 just go with a bigger cam, Torker intake and bigger carb.
Old 10-28-2016, 05:29 PM
itselliot's Avatar
Originally Posted by highspdlife0224
Hey! I think I recognize that motor!
I imagine you just might.......lol
Keep looking for those parts!................
hpschrot@hotmail.com
616 four 03 44 0 five
Old 10-28-2016, 05:31 PM
itselliot's Avatar
What CFM are we looking at?
Old 10-31-2016, 06:06 AM
SC/397's Avatar
600/650 cfm. I wouldn't go much bigger unless you change to a Air Gap or Torker intake manifold.
Old 01-10-2017, 09:46 AM
SC/397's Avatar
The block looks a little better now.
Old 01-10-2017, 02:12 PM
cma's Avatar
cma cma is offline
Looks so nice!!!
Markus!
Picture story:
Old 01-25-2017, 05:21 PM
any updates?
Old 01-26-2017, 07:31 AM
SC/397's Avatar
http://www.ifsja.org/forums/vb/showt...55#post1662655
Yep, I finished up the 401 for my Mate in England last night so now, I can move on to this one... Here is the never ending list that takes up all of my spare time. Wish I could work on something for ME one of these days.
8: 70 390: Pile of parts. Build to order. At the Machine Shop
56. 426Stroker: Crank is done. Build to order
62: Rick's429. Parts in house, ready for machining
63. Ambo383stroker: Ready to clean and assemble
71. javtwotone 383 stroker: Back in que..
73. CastPiston401crossram: Need to install intake
74. RR290: bone stock 290 for ’66 Rogue Convert. Needs disassembled
75. BStuts390: Ready to clean and assemble
76. BMathis401: On hold.
77. itselliot401: Ready to clean and assemble
78. cma360: Ready to clean and assemble
79. MS304: Tear down, inspect, fix, rebuild.
80. DBX11360: 360 for a J10. At the Machine Shop
81. MM390: Warmed over 390 for a Javelin. At the Machine Shop
82. RR360: Re-ring, new bearings, timing set, valve job
??. 383 Stroker
??. 401 Forged Pistons
??. 70 390 +.040 Forged Piston
??. 70 390 cast piston
Old 02-16-2017, 09:56 PM
SC/397's Avatar
Spent 3 hours on the block tonight getting the threads chased and the outside of the block cleaned with one coat of primer and one coat of paint. Now I can clean the inside and start the assembly process.
Bare Block
Zinc Primer
Base coat of paint
Old 02-16-2017, 10:47 PM
cma's Avatar
cma cma is offline
so nice job!
Markus!
Picture story:
Old 02-22-2017, 06:52 AM
SC/397's Avatar
Progress: I got the short block assembled last night. Nice shinny parts!
The timing gear wasn't too bad. Didn't have to move the slot over much to line up with the can oil hole.
Old 02-22-2017, 10:37 AM
Is that the later AMC blue?
-Jonny B.
1979 Cherokee Golden Eagle - 4" lift, 33x12.5x15
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 02-22-2017, 11:02 AM
SC/397's Avatar
No, it is just a base coat of Torque"N"Teal. I will spray a couple of coats of AMC Blue after I get it put together.
https://www.summitracing.com/parts/shw-de1643
Old 02-22-2017, 12:01 PM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
Watching intently, waiting to get a 401, hopefully in June.... Love your builds..
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 03-03-2017, 07:45 AM
SC/397's Avatar
Worked on the Timing Cover and Oil Pump Cover last night. The timing cover had water in it at one time so I carefully got the corrosion cleaned out and lapped the gasket surface.
I ran a tap through all of the threaded holes to make sure that everything goes together well.
Oil Pump Cover: Started with 80 grit wrapped around a file and spent about 10 min to get it to this level.
Spent another 10 min with 150 grit and got it to this level.
Spent another 5 min with 320 and got it to this level. At this point, it is probably as good as the factory finish. Up until now I sand in a cross-hatch motion. The key is to keep it as flat as possible.
Finally with the use of WD40 or Liquid Wrench, I wet-lap the surface with 400 or 500 grit sandpaper. I lap it in a circular motion.
Old 03-03-2017, 11:25 PM
Beautiful work.
I'd ask how much one of your 401's costs, but you know the saying, if I have to ask...
I appreciate the craftsmanship you are putting into this. Thanks for sharing!
Old 03-04-2017, 06:56 AM
SC/397's Avatar
This is not my full time job so, it's cheaper than you think! That is why I am always busy.
Old 03-04-2017, 12:06 PM
cma's Avatar
cma cma is offline
Great professional work!
Markus!
Picture story:
Old 03-06-2017, 08:18 AM
SC/397's Avatar
Thanks! I try..
1/4"-20 x 3/8" nut and bolt to replace the plastic button that the factory puts on. I use Loctite on the threads.
I make sure I have all the right bolts for the water pump and timing cover before I bolt things together. This is where I find out that I am out of 1/4" lockwashers and have to make a trip to town..
I make sure that the water pump impeller doesn't scrub the timing cover without a gasket in place. I install the water pump to the cover first then, the cover to the block.
With the timing cover in place and the gasket trimmed where it meets the block it is time to install the oil pick up screen.
I spin the pick up screen on until it is tight and it will clear the oil pan with no gasket in place.
Old 03-06-2017, 09:34 AM
That water pump impeller rub is a real buzzkill. Pretty common as well, it has gotten me once. Now I check before everytime like you!
1994 Caprice wagon
Stroker 304 Project Build Greg Taylor General FSJ Discussion 204 03-31-2015 08:06 PM
Time to Build - 1969 Wagoneer Arizona EnigmaticEngineer Off-Road FSJ Tech 26 02-13-2010 09:02 AM
AMC 304 V8 Stroker Build - 327 V8 ! Greg Taylor General FSJ Tech 5 02-14-2008 06:55 AM
NEWBIE BUILD UP DARWIN General FSJ Discussion 42 04-24-2007 11:42 PM
