Old 06-19-2016, 10:47 AM
Tte531 Tte531 is offline
Noob!
Hydroboost Spacer Needed?
1983 Wagoneer 360
Ok im sorry if this is a repeat from somewhere deep in the library of knowledge but I cant find it and i promise ive tried....
I have a 1994 HB unit from an Astro. I have measured the rod length on the VacBooster and the HB unit and both rods are of the same length. Why then is an additional 1" spacer needed? If the rod length was longer then I would understand the spacer but mine appears to be the same from the back of the unit plate to the tip of the rod.
Am i looking at this wrong? Thanks for any help!
Old 06-19-2016, 12:43 PM
77Deepj20 77Deepj20 is offline
Is the purpose of the spacer to adapt the bolt patterns of the different vehicles?
1977 j20. Dana 60's, 4:10's Chrysler 360/np435/NWF blackbox/np203
Hummer military 24 bolt wheels and 37" mt/r's.
Old 06-19-2016, 04:09 PM
Noob!
Ok so that was a bad one on my part... That piston in the HB was just coincidentally at the same position as the one on my Vac Boost. so never mind...
But I have another question... Is there a pin that goes from the Hydoboost to the MC? like there is one that goes from the Vac Booster to the MC.. Or is there a piston in the HB that pushes the MC.
Thanks
Old 06-20-2016, 01:10 PM
Noob!
Ok looks like there should be a rod. THis is the information i dont find when putting together your own unit.
Has anyone made their own HB to MC push rod?
Old 06-20-2016, 03:29 PM
Been a looooong time since I converted, but IIRC I just re-used the stock pushrod? It nothing special just a round metal dowel w/ smoothed ends.
Could easily be made from round bar stock & grinder.
Old 06-20-2016, 05:21 PM
68glad's Avatar
68glad 68glad is offline
The spacer is needed to accommodate the longer rod of the astro unit that attaches to the brake pedal
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
Old 06-20-2016, 06:11 PM
serehill serehill is offline
Gone,Never Forgotten.
well
Contact this guy Via the mail system on Ebay or look him up on this forum as Elliot. No one knows more about Jeep & Hydroboost than this guy he will have the knowledge & all parts you'll need to get this done. He's a Great guy.
http://www.ebay.com/itm/Jeep-CJ7-8-Y...VgQi 8qU1c4Xg
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
hydroboost help needed.. 78J-10 General FSJ Tech 3 07-26-2010 06:51 AM
Motorcraft 4300 4bbl spacer issue djongeward General FSJ Tech 0 06-24-2008 04:48 PM
327 Vig Carb Spacer and Gasket Help 66 K-Wag General FSJ Tech 3 04-29-2008 09:57 AM
Carb spacer Wagoncrzy General FSJ Tech 3 01-05-2008 08:34 PM
Carb spacer aerocorey General FSJ Tech 4 08-17-2007 08:34 PM
