Old 04-25-2016, 04:44 PM
jcarlson jcarlson is offline
Noob!
Exhaust smell through heater
I've been fighting with a bad exhaust smell on my '83. The muffler needed re-welding and a tune-up helped a bit. However, I still get bad fumes when I run the heater. If I have the heat slider turned to cold it doesn't smell much. But when I have it set to hot, it smells in the cabin.
What should I be looking for and how should I track it down?
Old 04-25-2016, 04:59 PM
Likely have an Exhaust leak @ passenger manifold.
Should probably find and fix that.
Heater box under hood probably has a large hole in it.
Can fix with fiberglass, or rivet a sheetmetal patch over hole.
Old 04-26-2016, 01:02 AM
Shep 762 Shep 762 is offline
I had a pretty nasty exhaust smell that came in every way it could. It was the little flapper valve thingamabob on the passenger side exhaust manifold that had come apart as well as the cat being gutted out and a hole in the muffler... I replaced everything from exhaust port on the heads back
Old 04-26-2016, 06:50 AM
elskeptico's Avatar
elskeptico elskeptico is offline
The real culprit is likely the exhaust flange "donut" seals that sit just below the exhaust manifolds. That connection is held on by just two bolts, so it's nearly impossible in my experience to get them sealed properly.
1979 Cherokee Chief S, 360, TFI, Part-time conversion, rust
Old 04-26-2016, 10:06 AM
Noob!
Thanks for the help, I'll start at the exhaust manifold and move on to the heater box if that doesn't take care of it.
73 Heater Hose Tee's off to Engine Block???? The Grand Pooh-Bah General FSJ Tech 10 06-06-2013 07:09 AM
need new exhaust (note I have TBI) Wagoneerlover Fuel Injection 1 12-09-2008 07:42 AM
Exhaust Leak Mystery Tyork_tex1984 General FSJ Tech 12 10-16-2008 10:28 AM
Ugh! My Exhaust Fell Off! Dome General FSJ Tech 6 02-12-2002 06:54 PM
VERY STRONG EXHAUST SMELL? Duckman General FSJ Tech 18 12-16-2001 04:08 PM
