Go Back   International Full Size Jeep Association > Tire Kickin' > Specialty FSJ Tech > Fuel Injection
Old 01-07-2005, 04:24 AM
MartyG MartyG is offline
I'm swapping my original '87 2.5L (TBI)motor out of my Wrangler and replacing it with a '95 2.5L (fuel inj.) Can I keep my original fuel pump? Will it put out enough pressure for the new engine?
Thanks in advance.
Marty
bigmarty@pacbell.net
Old 01-07-2005, 04:50 AM
brad_fsj10's Avatar
brad_fsj10 brad_fsj10 is offline
??? What's TBI, what's fuel injection?
Truthfully - the fuel pump in your 87 is over 15 years old if it is original. Replace it.
You may get more info on a "little Jeep" website.
[ January 07, 2005, 11:51 AM: Message edited by: brad_fsj10 ]
Brad Smith
86 J10 "Barney"
360/727/208
D44/AMC 20/3.31s
past rigs -
79 Chief
80 J10
Old 01-07-2005, 05:23 AM
millertime millertime is offline
You need to check the flow requirements of the EFI system your putting on. Most mechanical fuel pumps designed for a carbe'd application dont have enough pressure output to handle EFI. I think stock PSI is 3-5psi and If I remember right lots of EFI systems run at least 20psi.
Edelbrock Torker Intake <br />Edelbrock 650cfm Carb<br />4in BJ\'S lift<br />76 J-20,360,T-18/D20, d44 frnt, D60 rear.<br />TFI<br />cs-144 alt <br />Alum rad w/electric fan
Old 01-07-2005, 07:00 AM
gwinn's Avatar
gwinn gwinn is offline
South West Chapter Mod
Most likely your TBI had an electic fuel pump that kept a constant 15psi. Your newer fuel injection may require a higher constant pressure even as high as 30psi if it's multi-port. Check out the specs, but you may need to upgrade.
1983 Cherokee Laredo "Gus"
Old 01-07-2005, 07:15 AM
The Anti-Chrysler The Anti-Chrysler is offline
Disciple of A.M.C.
Yeah, and MFI also uses special fuel line designed for over 25psi. Yes, you will definitely need a new fuel pump, along with a new computer and wiring harness from the newer motor. Are you sure the '87 motor isn't MFI? I thought all the 2.5L motors in the wranglers had MFI like the 4.0L six. In that case, the '95 would be very similar.
If you're going to all this trouble, why not swap in the six???
Oh, and for reference, TBI means throttle body fuel injection. They would both be fuel injected motors, just of a different type. TBI is a low pressure system.
[ January 07, 2005, 02:16 PM: Message edited by: The Anti-Chrysler ]
Jason Davis
'82 J-10 Laredo, 360, T-177, 4" Rusty's
'85 J-10 (parts)
'09 Pontiac G8 GT Sport, '97 Sierra (Vortec 454), '98 Silverado Z71 (5.7 Vortec)
Old 01-07-2005, 07:47 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
I have TBI in my Blazer and when I changed out the (fuel)filter I had just run it so the fuel pissed out from the fuel pump side until the presure dropped, so I'm guessing that you're stock fuel pump wouldn't work with the 3-5PSI.
The stock pumps are easy to replace though.
Old 01-07-2005, 10:55 AM
JeepsAndGuns's Avatar
Nope, wranglers from 87-90 had throttle body injected 2.5's. Then in 91 when they started putting in 4.0's they switched the 2.5's to multi port that the 4.0's use.
