10-21-2015, 02:44 PM
AMC360 Build w/343 Pistons
This post is about a simple rebuild on a late model low compression 360 to get the most bang for the buck. The idea is to use off the shelf 343 flat top pistons to boost the compression ratio along with an inexpensive cam, intake and carb. The goal is to maximize the compression ratio but to keep it below the magical number of 10.0:1 to be able to run on regular old pump gas.
The first thing I did was go through some measurements and calculations to figure out what the compression ratio will be. The engine I am working with is a 1978 (and latter) 360 with 8.3:1 compression and late model bridge-rocker heads. I measured the heads along with a couple of earlier model heads to get the data.
According to the information I can find and have backed up with measurements, here is the list of 360/401 cylinder heads per years and their respective combustion chamber sizes.
51cc - 1970 & early 1971 #3196291C
58cc – 1971 through 1974 #3212993, #3213948, #3220502
60cc – 1975 through 1977 #3220503
63cc – 1978 and up.
Here are some photos of the combusction chambers.
I checked the cc's on the heads that I am going to use which checked out at 62/63cc.
The next thing I did was measure the dish and valve reliefs in the pistons.
The replacement dished 360 piston measured at 23cc and the valve reliefs in the 343 piston measured 6cc total. The compression height (centerline of pin to top of piston) is 0.001" difference so, it is a wash.
Once I measured everything, I plugged it all in to Diamond Pistons's Compression Ratio Calculator and liked the bottom line!
10-21-2015, 03:01 PM
1st Chair, Cowbell
I enjoy getting the engine building technical info from your threads.
10-21-2015, 10:54 PM
x2
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
10-22-2015, 06:28 AM
Thanks! I try.
10-22-2015, 06:00 PM
X3 on the tech info...
Originally I was thinking of using AMC 343 4v pistons in my 360... But changed my mind and stroked it to a 406 instead. Would have been about $1000 cheaper.
Were the 343's bolt in? Did you have to clearance anything?
1974 Jeep J20, gladiator grill, 6BTA JWAC cummins, Modified He351, 4in exhaust to 5in stack, nv4500/ford np205, 14b kingpin axle, 14b rear axle, 4.56 gears, 37x12.50r16.5 Military tires.
Future mods:
G56 6 speed with dual disk clutch
He351/s475 compound turbos
Vintage air AC and Heat underdash combo unit
40x13.50r17 tires on 17x10 wheels
10-22-2015, 06:23 PM
Shakes hands with danger
Interesting stuff. What are you using for head gaskets?
10-22-2015, 07:16 PM
Are you using stock 707 con rods?
10-22-2015, 08:13 PM
I am using head gaskets from a Engine-Pro kit mainly because I have a couple of sets. A few years ago I bought a couple sets of every gasket set made for AMC engines which is basically 3. Engine-Pro, Victor, and Fel-Pro. By the way, Fel-Pro is the best and most complete. This is a picture of the Engine-Pro gasket. It is a little thicker than the Fel-Pro but the inside diameter is smaller. This gasket will not work for a 401 like the fel-Pro does.
10-22-2015, 08:19 PM
Yep! Reconditioned of coarse. This is just a basic rebuild With a cheap low-end torque cam and a Performer Intake. Bumping the compression ratio with 343 pistons is a bonus. It doesn't add costs to a normal rebuild.
10-22-2015, 11:11 PM
Originally Posted by SC/397
I am using head gaskets from a Engine-Pro kit ... It is a little thicker than the Fel-Pro but the inside diameter is smaller. This gasket will not work for a 401 like the fel-Pro does.
Thanks. Wow, .058 is really thick. Nobody makes a thinner gasket with a bore appropriate for a 343/360 piston?
I guess you could deck the block down to get the piston .015"-.020" above the deck at TDC...
EDIT: I did find something. Looks like Cometic has MLS head gaskets with a 4.140 bore and thicknesses down to .027".
http://www.shopengineparts.com/parts...l=360+V8+70-91
10-23-2015, 05:58 AM
Yea, Cometic and Budget Build normally don't go together very well.
I went through the numbers using a Fel-Pro gasket which crushes to about .043", works out about the same compression ratio because the I.D. is 4.3" vs the 4.13" on the Engine Pro gasket. This engine will never know the .015" difference in quench. It would obviously be much worse with the dished replacement piston.
10-23-2015, 06:06 AM
How far below deck are the Pistons?
10-23-2015, 06:45 AM
1st Chair, Cowbell
.02" it says on the chart.
HA! I answered a technical question from Ristow!
Winning!
10-23-2015, 06:48 AM
It is the same as a normal rebuild at .020" but with flat-top pistons.
10-23-2015, 11:32 AM
i thought the 343 had a lower compression height?
10-23-2015, 11:33 AM
oh,lol....none of those charts above showed up on my iphone.
10-23-2015, 01:17 PM
They do by 0.001".
I measured the 360 dished pistion at 1.586" and the 343 piston at 1.585".
10-23-2015, 06:17 PM
That is interesting. And that was an OEM 360 piston or aftermarket replacement? I've seen OEM described at 1.601 (IIRC) and 28cc dish. Thanks for giving us some real hands-on measurements to counter the wealth of internet rumor.
10-24-2015, 10:44 AM
We're did you get the pistons?
79 Cherokee wt
AMC high compression 401
t18 4speed
74 Cherokee nt plow
360 th400
10-24-2015, 11:29 AM
343 has a shorter stroke and shorter block deck than 360 which is why I asked about the rods. I can't recall what they used in the 343 originally but I don't think it was 707s. I considered using 290 pistons in my 304 to run it on LPG.
Thread Tools |
Display Modes |
