Old 10-01-2015, 09:42 AM
Rich88's Avatar
Rich88 Rich88 is offline
Power steering got stupid
These days my Waggy use is restricted to occasional Home depot runs, and sits for months at a time between use.
Yesterday I fired her up for such a run and behold, the steering was very stiff. I checked the PS pump fluid level - was OK. No belt squealing either.
The power steering is not totally gone, but gone enough so that the wheels do not return to center when driving, which made for a very interesting white knuckle trip to/from Home depot. I hoped something would "clear up" from driving it, but t'was not to be.
The last time I used it, there was no problem at all.
Any ideas what's gone/shot/broke?
Old 10-01-2015, 10:02 AM
You running PS fluid or brake fluid? How long has it been since the fluid has been changed?
Old 10-01-2015, 10:30 AM
Rich88's Avatar
Brake fluid?! I think you might have been meant tranny fluid. Anyway, its been tranny fluid forever on all my past & present waggys. Never a problem. And never changed.
However, upon thinking about it, I'm guessing the pump is shot. If there were binding in the power steering unit itself, the belts would squeal against the resistance.
Old 10-01-2015, 10:50 AM
I've seen bad ball joints do that, believe it's called memory steer.
They freeze up/bind from extended periods of sitting/non-use.
Kind of like cruise control for steering.
Old 10-01-2015, 11:04 AM
The pressure relief in the pump may be stuck open. Turn the steering wheel lock to lock with the wheels off the ground and running. First, it should be easy. If not, then balljoint bind is possible. Going to the lock may bump it up enough to knock the regulator loose.
Old 10-01-2015, 11:23 AM
Rich88's Avatar
Good ideas
Will do the jack-it-up & play-with-it thing this weekend.
Meanwhile, I ordered a new PS pump anyway. Just went over 160K, so can't hurt.
Tnx guys
Power steering issue when Cold? adzam General FSJ Tech 5 01-12-2015 07:18 PM
Another power steering question.... 44BZ General FSJ Tech 1 04-19-2010 01:17 PM
AMC 327 power steering conversion?? 44BZ General FSJ Tech 3 02-26-2010 10:04 AM
Power steering pump OR Steering box??? HOOT General FSJ Tech 6 11-27-2009 10:52 PM
power steering question supercopjason General FSJ Tech 2 09-25-2007 09:39 AM
