Looks great so far! Im collecting parts now for my LS swap. Looks like its the correct shop for it to be happening though! Bet that Jeep never thought it would be under a GTO
LS3 Swap into a 1980 Wagoneer
He dose not have the TC adapter on it yet. He mentioned it in the caption above the photo.Life happens while you are making plans...............
Originally posted by babywagSo someone is now making an adapter setup to utilize the 2wd output shaft?
I have a NP242 AMG and a 4l80e sitting in my garage from an H1 hummer.
My shaft appears much shorter than a standard 2wd 4l80e.
It is 3" long (stick out) from the rear of the 4l80e case.
Can provide you pics & measurements if you need 'em?
EDIT: It's for sale as well if interested?Last edited by babywag; 02-20-2015, 12:06 PM.Tony
Couple updates: Waiting on just a few more parts then its off to paint!
New in box NP 242 AMG
0211151303 by Iroc313, on Flickr
4L80 and converter, waiting on adapter for t case
0302151312 by Iroc313, on Flickr
New CTS-V accessories fit like a glove. Looks like we can keep the battery in the stock location
0302151311a by Iroc313, on Flickr
0302151311 by Iroc313, on Flickr
0302151257 by Iroc313, on Flickr
Originally posted by babywagI have a NP242 AMG and a 4l80e sitting in my garage from an H1 hummer.
I'll update this week when its all together! Sorry for the late reply.
Originally posted by jeepin87So, what have you found that will not clear so far? Heater box? Brake booster? We will be doing some LS swaps soon so any and all info you can provide would be greatly appreciated!
We are waiting to mount the trans and transfer case to see if it clears the fuel tank (which supposedly isn't a problem on 80+ trucks), and if we used a different style accessory drive we would have had to relocate the battery. The oil pan (whatever style that this motor comes with) is pretty close to the diff, I may end up replacing it with a truck style one, but this is going to have a lift on it too, so I may end up leaving it.
Radiator and hydroboost are in! The radiator is awesome, as well as the fan shroud, Novak makes some amazing stuff! I would definitely recommend them if you're considering an LS swap into an SJ. (the hydroboost isn't mounted correctly in that picture BTW, I didn't realize it utilizes the old plate off of the stock booster)
0306151141a by Iroc313, on Flickr
0306151141 by Iroc313, on Flickr
Still have PLENTY of room with the motor mounts on the middle setting. In case we have to move everything forward for the 242 to clear the gas tank.Last edited by ls3waggy; 03-06-2015, 11:34 PM.
Originally posted by ls3waggyTo answer this question the heater box is very close, similar to the old motor except this time it's in close proximity of the coil packs. It may fit but it's definitely going to be tight if you used the stock heater box.
That's exactly the info I was looking for! Thanks! Swap is looking good!Lots of rigs, parts, and lost knowledge.
