Old 04-09-2004, 01:35 PM
Max Power's Avatar
Max Power Max Power is offline
Cutting a hole in ones hood is not an action which should be undertaken lightly...I pulled some stuff from the junkyard, and mocked it up, but none of it looked right. I'm glad my buddy gave me the boat catalog.
I think that heat killed my last carb, the accel. pump diaphragm was kinda deformed and looked almost melted. I'm very happy w/ my 2 electric fan system, but I want to increase its effectiveness and give the heat a place to go @ short stoplights when I don't want the fans to turn on.. I got these awesom 4x12x7/8 SS vents from west marine.
model number 386559 SFVEN#13585
mock up...
approximately where the vents will come thru on the other side, I've got the 3/8 water heater insulation upgrade on the underside of my hood.
I propped up the hood and put a tarp across the engine bay... one down.
pretty happy w/ the fit...
view from underneath... please lets keep the comments tasteful regarding my getto fab brake reservoir lid tiedown.
all done...
I used stainless #8x1/2 sheet metal screw (which I will probably change to rivets) and a little black rtv
guess I need to think about painting the beast pretty soon.
cheers,
Robert
[ April 11, 2004, 09:12 PM: Message edited by: Coach McGuirk ]
______________________________________
Cheers,
Robert
www.rbk3.com/fsj
1980 Jeep Cherokee Laredo WT 360/727/208
1980 MBZ Euro 300D 4-speed manual - Oil Squeezer
1984 MBZ Euro 300D 5-speed manual - Oil Squeezer
Old 04-09-2004, 01:48 PM
J20 project's Avatar
Kinda reminds me of the 67 chevelle grills in my hood. I think it will look good.
J20
<a href=\"http://photos.yahoo.com/hpjr2000\" target=\"_blank\">http://photos.yahoo.com/hpjr2000</a><br />76 J20 NEW 401, D60,Locked 44HD,T18,D20. 6in lift,sway disconnects,dual batts, 9K Warn winch, custom front bumper, custom paint, aux tank, cooling fan. 34x10.5x16 Swampers.
Old 04-09-2004, 01:49 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
They look good, I think once you get a coat of paint on there they'll really look great.
Anthony
Anthony
1983 J-10 - 4.6L(MPFI)/CS144/NV3550/D300/44/44/3.54/32
1983 Honda CB1100F
1983 Honda CB1000C
Old 04-09-2004, 01:51 PM
PlumCrazy's Avatar
PlumCrazy PlumCrazy is offline
Location: Just S. of Branson (in Beautiful Razorback Country)
Thumbs up
Actually that looks pretty good...wonder what it would look like down the side on the fender or near the rear behind the w/w about where the chrome moulding sits?
What did the pair set you back?
My license plate says "Crazy" not stupid
*STATUS running while I'm gathering parts*
1966 Pontiac LeMans Convertible "Un-Named"
*STATUS on hold for shortage of fundage*
http://community.webshots.com/user/fsjplumcrazy
Old 04-09-2004, 03:22 PM
illegalFSJ illegalFSJ is offline
The vents look great.
But I'm wondering about the underhood insulation. If you think that heat may have been a factor in your carburetor failure, why are you trying to keep all that heat in by insulating the under side of the hood?
Taking the insulation out would probably lower the underhood temperature.
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 04-09-2004, 04:03 PM
looks good I have you noticed any differance in your under hood temps? Check out Gwinns hood in the ouray section
Old 04-10-2004, 12:20 AM
Max Power's Avatar
thanks everyone for the replies, yeah my buddy wanted me to mount them on the quarter panels, (like on a boat)....
anyway, I was just looking for unobtrusive vents that weren't made out of anything rustable or meltable, and I'm pretty sure thats what I ended up w/.
Illegal-I put the insulation on when I still had a mechanical fan, mostly for noise insulation reasons, also to keep the rest of the car cooler, and b/c I think it looks cool, but it really did raise the underhood temps.
I have not started the engine yet, but I know its gonna be much louder now, and hopefully much cooler. I will post the results.
Cheers,
Robert
www.rbk3.com/fsj
Old 04-10-2004, 03:32 AM
AMX factor's Avatar
AMX factor AMX factor is offline
Those look good. How much were they? I use a hood scoop on mine with no insulation. Yes lots of engine noise but I don't overheat. In the summer the heat waves actually obscure your view in front of the scoop.
"I'm sick of this sickness, don't touch me you'll get this."
1984 GWag "orphan" for sale
2 x 1975 Matador "murder machines"
1970 SST390 Javelin 10 yr project!
Old 04-10-2004, 04:15 AM
Jlamb's Avatar
Jlamb Jlamb is offline
I have one question... Whats up with that block of wood and hose clamp on the master cylinder?
1979 J20,360,TH400,QT
Old 04-10-2004, 05:44 AM
Max Power's Avatar
the SS vents cost 17.99 each.
jlamb-thats my getto fab brake reservoir lid tiedown, I'll make you one for $49.99
Cheers,
Robert
www.rbk3.com/fsj
Old 04-10-2004, 06:50 AM
full_hydro full_hydro is offline
do you have a catalog or part number for the louvers..
I dig em.. in '98 jeep put louvers on the grand cherokees with the 5.9... i like the look..
Old 04-10-2004, 02:39 PM
pb's Avatar
pb pb is offline
Looks sweet, but why use RTV if water will get in through the vents and rust stuff in the engine compartment anyway?
Gotta second losing the foil reflecting the heat down. I think that is a big source of the temp problems.
Paul
1975 Wagoneer DD
Old 04-10-2004, 03:49 PM
Gambler68's Avatar
Rabble Rouser
looks great man! Think you've started a trend
I guess if I cant have a blower peekin up through the hood, the vents would do
much better on top, dont think they'd do much good on the sides, unless they were reversed to catch air and force it in, but from what I've gathered, our trucks are already well designed for suckin air up from underneath (and rocks, shrubs, small animals..)
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 04-11-2004, 03:11 PM
Max Power's Avatar
I used rtv to make sure they will never rattle or vibrate loose.
Not concerned about rust, theres too many oil leaks under there to allow any rust to form.
Model numbers are posted under the first pic.
I will definately be keeping the foil faced insulation.
still have not driven it yet.
Cheers,
Robert
www.rbk3.com/fsj
