Old 04-24-2013, 06:05 PM
BillyWagoneer's Avatar
BillyWagoneer BillyWagoneer is offline
dry starts and lifter noise
its been about 1000 miles since my cam swap and it had a really light lifter tick since i put it in which from what i have read is pretty normal. recently it has seemed to get a little louder. not by much and its still not even noticeable in the car when driving (unless the windows are down and im driving next to something for the sound to bounce off of) also recently its been dry starting if it sits for more than 6 or so hours. in the morning itll take about 3 or so seconds before the valve noise goes away. thoughts?
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
True Dual side pipes
TF 727 & np229
B&M Shift Kit
12 Bolt rear & D44 front
4.10's and ARB lockers
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-24-2013, 06:50 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
What weight oil are you running and what kind of filter?
Originally posted by Ristow
i bet it was Simon....
Old 04-24-2013, 07:30 PM
Rosella 15 40 with Lucas additive. napa gold filter.
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 05:02 AM
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
Same exact thing with mine. Don't know if it's the oil or the lifter. Again we have the same motor.
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
Old 04-25-2013, 05:14 AM
How long yours been doing it?
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 07:12 AM
hookedup50 hookedup50 is offline
Mine did that and I stole the pre/post oiler off my turbodiesel. Expensive solution, but that engine will live longer.
Jennifer: 89 GW 360/727/D44 2"lift 31" BF KM2
Harriett: 97 chevy 2500 ext cab P/U 6.5 TD
Lorraine: 73 Datsun 240z
07 Colorado
http://s1196.photobucket.com/albums/aa416/hookedup50/
Old 04-25-2013, 07:43 AM
svining's Avatar
svining svining is offline
Exclamation Mine too!
Stock 360 running Mobil 1, 10-40, and mobil 1 filter. Its always done it, worse in cold, but just momentarily after start, until pressure climbs a bit. Is that Back-flow? I can change filters next change. I was going to Mobil 1 5-30 next Oil change, Probably in the fall.
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 04-25-2013, 08:19 AM
IM gonna start running Valvoline vr1 50 w. Well see. The dry starts started when I noticed the lifter noise so that's why IM worried
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 08:32 AM
addicted's Avatar
Big Meanie
Running that thick oil isn't going to help your issue any. Even where you live its still gotta get flowing. Try a different filter and a thinner oil like a 10w30.
Old 04-25-2013, 08:45 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
They changed the filter sometime around 1987 from the Napa #1258 to the 1085. The 1258 sucks, the 1085 is good, and no, they are not interchangable.
If you use the early style filter, use a Baldwin B9, B39, Purolator L30005, or ACDelco PF24. Baldwins are hard to find, Purolators come from Pep Boys, and the AC from O'Reilly's. You usually have to ask at the counter for those filters.
'84 AMC Eagle Limited, 258 I6
Old 04-25-2013, 08:48 AM
My oil pressure is great. 30 at idle 60 cruising.
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 09:06 AM
My filter is a napa 1626
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 09:13 AM
Billygoat's Avatar
I have found that the current lifters available all are loud, IIRC correctly the oil inlet hole in them is higher than stock AMC - the current ones are a universal.
I have never had a engine with replacement lifters not have lifter rattle.
Old 04-25-2013, 09:15 AM
I guess that's comforting... It really isn't bad it's just there and I feel like it shouldn't be
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 09:25 AM
Billygoat's Avatar
I hate it, my rebuilt 401 and it is all clicky...
I thought someone had lifters made correctly (maybe bull tear?) but they are pricey.
Old 04-25-2013, 09:30 AM
IM gonna go to roller rockers. I guess for now I'll just deal with it.
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 11:32 AM
budryzer's Avatar
budryzer budryzer is offline
Clackety clack clack
I don't have this issue currently with two AMC 8's I'm running. I imagine there are a lot of others that don't as well but since it's no issue for them they just don't chime in???? I think the most important thing is to determine that it is a lifter for certain! It definately takes two people and a lot of cold starts!
85 GW 360/2v
SOA/SF 36's
68 AMX
04 BMW 325
85 FLT
77 Hercules 250
ASUS laptop with theamcfurom.com as homepage
Old 04-25-2013, 11:51 AM
Cold start noise is oil starvation/excessive clearances.
Thicker oil is only going to make it WORSE.
Vr1 50w is racing oil, and not really suited for a daily driven street engine.
Stick with lower weight quality oil like 10w-30.
I used to run 15w-40 for a time in my '88, one of the reasons I stopped was the cold start rattle it caused.
Went back to 10w-30 no more noises.
1994 Caprice wagon
Old 04-25-2013, 12:57 PM
What's up with this? My napa filter is a 1626?
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 04-25-2013, 01:48 PM
You have the correct filter, he is stuck in the 70's.
1994 Caprice wagon
Lifter noise/Rough running 360 jkilgo General FSJ Tech 3 01-29-2010 09:06 AM
