Old 09-11-2003, 04:25 PM
1BDWAGN 1BDWAGN is offline
Question
I have asked on here several times about swapping in a newer Chevy truck drivetrain but after see what the reall cost was it is just going to eat too much of my budget for the Wagon. Today I ordered BJ's 4" lift and a few days ago I got a complete TBI setup from an 89 Chevy truck. So my question is about adapting the TBI setup to my Grand Wagoneer. Would I benefit from the performer EGR manifold or should I just stick with the stock 2bbl manifold since the TBI is 2bbl. Also has anyone passed an IM-240 emissions test with an aftermarket cam (thinking about the crane 260)? I hope figuring out the wiring harness isn't too hard. I still have to get an in-line fuel pump and figure out how to let the ECM control the stock distributor. I wonder how the 360 will run on the stock 350 chip. I do have a eprom burner and a copy of diacom but getting things right if they are off will take a lot of work. Anyone have any tips on installation?
[ September 11, 2003, 10:26 PM: Message edited by: bd2thbnAZ ]
4" lift, 15X8 rims w/32" MTRs, TFI, and Magnaflow exhaust.
Old 09-12-2003, 04:13 AM
kreb's Avatar
kreb kreb is offline
i think that you would be better of with an aluminum intake. it is lighter and will dissipate heat much better. the 2bbl intake does not flow to bad but you would lighten up the front end a bit and pick up performance.
benjamin
Kreboneer
1991 Grand Wagoneer
360/ 2150
4" Rusty's lift 32x11.5 BFG KM, 1.5" block rear MSD/TFI, Pioneer sound
'85 grill, '78 WT wheels
houston, tx
hermanbloom79@yahoo.com
"if you don't have time to do it right, you don't have time to do it twice." - stolen from another board member who's name i can't recall
Old 09-12-2003, 05:19 AM
gpd gpd is offline
Keep us up to date on your build up. (Pictures)
1991 GW, Dark Silver, Sand Leather Interior. TFI Ignition. Rebuilt 2bbl carb. Tongue & groove rear interior panels.
Old 09-12-2003, 11:28 AM
DieselSJ DieselSJ is offline
It is actually easier to adapt the GM TBIs to a 4bbl intake. The adapters are readily available from Holley (through Summit or Jegs). I haven't seen an adapter for a 2bbl, but they probably do exist. Plus, the 4bbl will give better performance over the factory 2bbl. You may want to consider a Performer RPM intake.
As for getting it running, go to www.customefis.com and buy his DIY manual. It shows you how to modify your distributor, plus it gets into how to tune the TBI systems. It is definitely worth the money.
Another good source for EFI info is www.diy-efi.org -they have been having site trouble so they may not be up all the time.
[ September 12, 2003, 05:31 PM: Message edited by: Mark in WA ]
Mark
87 Grand, 6.5L diesel, MHI TE06H turbo, Detroit Diesel single plane intake, Art Carr 700R4, CS-130, hydroboost. 21/24mpg and an almost dead 229 (*&^%$# viscous) [208 on the way]
81 CJ5, Bowtie 350, T176, 30, 20, 300, small lift, 285/75/16 MTRs courtesy of Goodyear.
Old 09-12-2003, 11:38 AM
Ted Wendel Ted Wendel is offline
I can build you a GM HEI for it, that is EMC controlled.
Old 09-12-2003, 12:09 PM
I will try to document everything for others. So far I have spent a few days researching TBI setups over the net. The DIY manual was already on order and should be here any day. My biggest hurdle so far looks like it may be in the chip tuning. But I am getting a laptop and a version of WINALDL to fix that. I would like to swap in a little hotter cam than stock but I am looking for one that will give me the least amount of hassle with the TBI and yet give decent gains. Ted I have sent you an e-mail.
AMC 360 Build or swap?? rustywag General FSJ Tech 36 05-22-2011 08:02 PM
Engine final assembly questions JeepsAndGuns General FSJ Tech 29 08-02-2005 02:31 PM
360 build help stinky General FSJ Tech 14 01-16-2004 12:09 PM
AMC 360 block same as Mopar 360? DDGETHS General FSJ Tech 10 12-02-2002 09:55 AM
360 Build options billyrb Engine 15 02-04-2002 03:54 AM
