Go Back   International Full Size Jeep Association > Events > Las Cruces
Old 10-28-2012, 09:47 PM
broken axel
getting tired of this I tell ya...
This happened after a vibration at 65, shaft sheared off at the outer seal 70 miles from home. Luna and I are home safe and sound except for the brain damage from the burst of adrenalin. Krista picked us up in Shiprock. Wally will be home tomorrow. I am beat.
Old 10-28-2012, 10:05 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
Is that the same as last time? Or did the whole shaft come out that time? I have a parts 44 here with gear damage should you try to repair that and not do the upgrade now.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 10-28-2012, 10:43 PM
Time for full floaters. Glad to hear your ok Luna is going to start not wanting to go in the Jeep if you keep this up!
Old 10-28-2012, 10:50 PM
The shaft broke at the outer seal right where the hub flange meets the shaft. I thought it was a clean break at first but on closer inspection, it looks a little twisted. There was a vibration just before and I let off the gas running 65 on new black top in a flat area. It was much easier to manage off the road than last time. This may have failed due to the previous damage, dunno. Maybe it's true that 35s kill D44s. I am done with it.
Old 10-28-2012, 11:02 PM
Heimeken's Avatar
Heimeken Heimeken is offline
I had the same issue with my J10, fixed it broke, fixed it, got towed, fixed it, wheel ran out before me, I concluded the axle had a slight bend. Got rid of the original 44 and got another... but never felt comfortable. That is why my "new" J10 is getting J20 axles. Glad you and Luna are home, time for the 3/4 ton upgrade.
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 10-28-2012, 11:03 PM
Stuka's Avatar
Stuka Stuka is offline
Are you running a locker in back flint?
Would not be the first twisted shaft I have seen. You could go alloy shafts, which can be up to 40% stronger. More so if you are using 30 year old shafts. But really a 14FF or D70 are what you want for a never break situation. Or a 35 spline D60.
Glad you were safe!
Old 10-28-2012, 11:08 PM
the original Honcho's Avatar
Holy cow Flint! Good to hear you and Luna are home safe and sound, thats the most important thing
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
Old 10-28-2012, 11:29 PM
Michael's Avatar
Michael Michael is offline
Yikes, glad ur ok
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 10-29-2012, 12:44 AM
Hey Flint do you want me to turn loose the hounds and see what can be found?
Old 10-29-2012, 06:19 AM
Thanks everyone.
Stuka - This axle has had a Lockright with hardened pin in it since 2002. The left axle shaft was replaced after bearing failure. This axle is scrap metal.
Thanks for that thought Charlie. I have almost everything I need to step up and run a Dodge D60 rear with a J20 front on SOA/SF. One of the things I need is Popeye arms.
Old 10-29-2012, 06:47 AM
dangit!
i hate D44 rears. crappy axle.
i had thought you did the FF rear axle already.
Old 10-29-2012, 06:51 AM
I didn't get the message last time I reckon.
Old 10-29-2012, 06:54 AM
i think about my pos D44 rear in the '91 frequently as i drive myself. i really don't care for flange retainer rear axles.
you have a FF all set to go in,and D44hd front as well correct?
my cherokee will be FF rear too,as soon as i get off my duff and get it in.
y'know,it seems the AMC20 rear axles don't spit the shafts out like the danas' do.
Old 10-29-2012, 07:17 AM
Stuka's Avatar
Yeah you don't hear about as many FSJ M20's breaking shafts. Mine has held up well with a detroit and 4.56's.
As for the D44, a lot has to do with them being old too. As I know guys with JK's that run 37's and beat on them hard and rare break. And a 4dr JK can sometimes out weigh an FSJ. There are some differences in them. R&P is much larger and the tubes are thicker. And the tube thickness may be the key. Although it could also be most of the JK'ers I know have rubicons so on the street they are unlocked. Where as most of us run automatic lockers. So on the street the shafts are being abused more.
Either way a full floater would at least prevent the tire from coming off. Even though a D60 shaft is the same strength as a D44 shaft, unless its a 35 spline obviously.
Old 10-29-2012, 07:30 AM
I have towed some heavy loads with Wally over the years. Most recently 40 bales of hay on a 16' car trailer. The axles on Wally are original except a rebuild with all new bearings in 2002 with 3.73 gear change then R&R bearings in 09 after the other axle came out. Also, we have been running Royal Purple in axles and tcases since 2002 sans the QT stuff. If I remember right these D44s have about 282,000 miles on them.
Is a dodge dana 60 going to have enough offset? I know we originally tried to run a centered 9 inch and found that even in a Dana 20 equipped FSJ that the rear was offset to bypass the gas tank with the drive shaft. That is why I ended up with J-20 axles in the first place and you know where that led to!
Old 10-29-2012, 07:37 AM
80-91 FSJ uses centered rear punkin axles. The D60 will fit fine.
Old 10-29-2012, 07:42 AM
seems like it's the drivers side that usually goes,too. wonder if the crown of the road has a factor in that.
i overfill mine to force more oil to the bearing.
Old 10-29-2012, 08:14 AM
Sounds good I guess all of them around here are 70s
Old 10-29-2012, 08:16 AM
Heimeken's Avatar
282K miles! Sounds like it held up just fine, just old like alot of our stuff.
78 J10 "Imoteb"
broken hood cable Robert2912 General FSJ Tech 13 01-17-2012 03:49 PM
Broken Exhaust Manifold Bolts AMC4ME General FSJ Tech 11 12-04-2011 09:24 PM
Axel shaft off center in the hub BoringBen General FSJ Tech 2 10-31-2010 10:13 AM
Axel shaft off center ih hub BoringBen General FSJ Discussion 2 10-30-2010 11:57 PM
Broken seat Tourettes General FSJ Tech 1 12-28-2009 06:51 PM
