Old 07-23-2012, 12:18 PM
spyoung's Avatar
spyoung spyoung is offline
Tailgate window crank
I recently purchased a 79 Chief. The previous owner had started to restore and decided to sell. one of my first jobs is getting the tailgate back in order. I installed a new mechanism for the window, hand crank. As I was installing the hand crank, it fell apart. Checking on Bj's website, they say they done sell that style anymore. Does anyone know of one that is good and can be purchased? or should I look into fabricating one?
Thanks
Old 07-23-2012, 01:59 PM
Tinkerjeep's Avatar
Banned
not so much.
Maybe buy the electric motor and actuator from a member here and remove the in-tailgate-switch...they usually grenade internally and all the contacts ...DON'T contact anymore. Then run the wires from the gate-glass-motor to the dash switch...its a bit inconvenient (or you could wire in an aftermarket switch in the gate) but then the tailgate glass actually works.
Old 07-23-2012, 06:24 PM
spyoung's Avatar
The tailgate came to me gutted. The P.O. sent a kit for a hand crank. It was at one time an electric motor, the switch is still in the dash. I installed the mechanism for the window this morning, the hand crank mechanism. The problem was when I was installing the crank handle it fubared on me. I was thinking I could use a 12Pt. Socket and just do it manuel for now. I havent found a socket to fit it though .
Old 07-24-2012, 12:18 PM
I found a manual crank set up (early FSJ wagoneer) in a picknpull in Arlington, WA but didn't have time or $$ to pull it (the sun had fried my brain. I was taking Altazzo tail lights from a Mustang convertible to put in my Eagle wagon and an HEI dist)
Old 07-26-2012, 01:59 PM
Tinkerjeep's Avatar
Banned
Mm-kay...I'm back. I looked at the TSM and the window actuation assembly is basically similar. but there is a side plate attached for the motor drive. and on the hand crank there is a small addition at the top that houses the gears for that.
Long story short... unless you have all the right parts for either you got nothing to work with. I do have a motor...and a couple dash switches but may not have the wiring harness intact to run the motor.
On another note: the splines and shaft are exactly the same as the door window crank stub. You can cut down a door latch handle or window crank handle and "fab" your own...but you will run into a clearance issue between the "new" lever arm and the vertical ridge in the tailgate.
I'm looking for some hardware for my daughters 76 Wag tailgate hand-crank. missing base-plate and knob from the lever/arm.
Old 07-26-2012, 02:06 PM
itselliot's Avatar
tailgate
I have the mechanism (electric) complete. salvaged from a tailgate I bought just for the glass. Not sure any longer what it came from, best guess would be a late 70's cherokee chief.
Pm your location and for details .
hpschrot@hotmail.com
616 four 03 44 0 five
'78 J-20 401 Q/T not quite stock anymore....Frame off Resto Mod..Super Cab nearing completion.
Old 08-02-2012, 07:00 PM
Tinkerjeep's Avatar
Banned
Hah! I thought you were talking to me. forgive the PM I sent.
Old 10-24-2012, 10:21 PM
spyoung's Avatar
Today I got back to work on the window crank problem. After rebuilding the carb, fixing the exhaust leaks, the stupid gas tank rock guard, and more stuff im sure.
So heres what a did, why it worked and why it didnt.
I welded two 1/2" nuts together they slide over the spine shaft almost snug. I then ground down the welds so a 3/4" socket fit. When the double nuts slide over the spline, it leaves about 1/2" gap from the face to the end of the shaft. I welded it in and Whalla! window comes down and goes up.....almost all the way. For some reason the teeth on the drive gears are slipping! Teeth are broken off!
Upon further reasearch on this site I find that the spacers that were used for the electric window drive are not to be used for the manual....Some how some way this must have put the gears in a bind. Tomorrow I am going to see if I can disassemble the gears and turn them around to get good teeth to the drive gear and re install without the spacers. This discovery would explain why the hand crank was wearing out in the first half of the teeth, like I couldnt get the crank into the spline far enough.
Old 10-25-2012, 03:59 AM
For those of you who have stripped crank handles you might want to keep them, particularly if they are in otherwise good condition. I have figured a way to repair these (the drive spline portion) to better than new condition. I probably won't be working on this process anytime soon however.
The generation of the past was appalled with the idea that the government would install a device inside the bodies of its people that would track their performance and influence their behavior, the generation of the near future will insist upon it.
Old 02-20-2013, 04:06 AM
Overdriven Overdriven is offline
I'm curious how you figured out how to repair the rear crank window gears. I just bought an 83 Cherokee and I really want to keep the manual handle.
Your in box is full. I tried to PM you.
Thanks
Tyson.
Old 02-20-2013, 04:35 AM
This may or may not work for you.
Depends on where and how bad the teeth are stripped.
http://www.ttsfabworks.com/tech/mantgaterepair.JPG
Old 02-20-2013, 06:46 AM
svining's Avatar
svining svining is offline
I have a brand new Manual type
I read BJ's explanation of why they don't carry the manual style anymore. I bought one from Team Grand. I never used it because my motorized system only had a broken wire and now works fine.
I'm curious how you modify the kit so if I ever need to use it, i can with reasonable confidence. Pictures are great. I did hear before that the shaft didn't extend into the gears far enough and to delete the spacers used on the motorized version.
I've stockpiled switches and motors etc to last me awhile. If anyone needs a new manual type I would be willing to sell it. Chrome is nice quality.
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 02-20-2013, 11:37 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
The early style cranks with the Jeep logo in the middle are nearly impossible to find. My original stripped out its splines.
The later smooth style tend to come apart. The handle seperates from the "bearing" I guess you could say that screws to the tailgate sheet metal. I solved this by grooving the retaining collar and installing a snap ring.
I still try not to use the tailgate window.
'84 AMC Eagle Limited, 258 I6
Old 02-20-2013, 07:21 PM
I tore into the tailgate today to find that the regulator and arms are in perfect shape. So is the splines on the gear that connects the exterior crank to the regulator. The two things that are bad are the crank handle itself (all the splines are stripped out of it) and the metal strip that connects the glass to the regulator. it's rotted in half which allows the window to bind up.
The window strip and seal can be had from BJ's. Need to replace the window crank handle though. How much you want for it?
Old 02-20-2013, 09:59 PM
Mr Carts Mr Carts is offline
I got one from BJs last year and the handle came off. I also could not get the lock to seat into the handle.
1980 Cherokee WT 360 TFI Contour Fan 727 208
3.31 285/75X16
Old 02-21-2013, 04:28 AM
Someone please enlighten me. This is my first experience with the manual crank. I'm not going to assume I have the stock handle or the stock gear that connects it to the regulator.
The handle looks to have threads3/4 through it that are stripped out. There are about 1/2 inch worth of threads still in the very bottom of the female end of the crank.
The gear that connects it to the regulator does not protrude through the tailgate. Yet if I put the handle in place and push hard enough the treads engage and it moves the window.
Is my problem the crank handle being one of the newer/cheaper or the gear being the wrong size? I want to make sure I'm chasing the correct demon here.
The metal sleeve that has a rubber strip in it at the base of the window is rotted in half. I'm sure this allowed extra binding to break what threads were in the rest of the crank handle. I know I need to replace it.
Thanks.
Old 02-21-2013, 05:10 AM
Awesome writeup. I'll keep this one for later if needed.
Old 02-23-2013, 09:34 PM
Tinkerjeep's Avatar
Banned
I believe the window/door handle splines on the regulaters (doors) are the same spline count. Dissassemble a door reg and replace the shaft in the rear Tailgate mechanism...sound stupid or plausible?
Rear tailgate window hand crank kit tjmackey1 General FSJ Discussion 15 09-10-2014 12:06 PM
tailgate window c.v.paul General FSJ Tech 2 07-07-2010 02:46 PM
Washers for tailgate window regulator Matthew W. Woodruff General FSJ Tech 1 06-29-2003 01:01 PM
ELECTRIC TAILGATE WINDOW medic General FSJ Tech 7 11-28-2002 02:40 AM
Finally, Official FSJ Club Memeber.. Tailgate window sticking... Manhattan General FSJ Tech 4 05-22-2002 04:39 AM
