Old 07-13-2012, 05:43 PM
Zigged 79 Zigged 79 is offline
Undercoating
What is the hot set up for undercoating the frame and inside panels etc? How is that working out on previously undercoated Jeeps?
Old 07-13-2012, 07:53 PM
Jeep Craze's Avatar
Jeep Craze Jeep Craze is offline
check out www.eastwood.com they are even in Pottstown Pa. I used their chassis paints on my chevy build and they are top notch.
91 GW 360/727 Black cherry metallic, maroon interior, getting a restoration
82 CJ8 Scrambler-awaiting something to be done
83 CJ8 Scrambler-Wifes Toy 258/4spd, 4" lift, 35" tires,
Old 07-14-2012, 06:27 PM
Kempton! That's cool. Right, I forgot about Eastwood.I'm forgetting a lot of stuff. I guess they would have stuff for the floor boards also.
Old 07-14-2012, 06:52 PM
TheDude's Avatar
TheDude TheDude is offline
http://masterseriesct.com/
I used their sealing silver primer on my 715. Great results and awesome customer service.
RM
89 YJ AMC 150, AX5, NP231, 30 - 8.8 "Spot"
75 J10 AMC 360, T18A, D20, 44 - 44 Camper "Pops"
76 J10 AMC 360, TH400, Q-Trac, 44 - 44
67 M715 AMC 360, SM465, NP205, 60 - 70 "Tsar"
C'mon... Start...
Old 07-14-2012, 08:55 PM
dbabicky's Avatar
dbabicky dbabicky is offline
Spray the underside of your truck with a good coat of used motor oil, then find a really dusty road to drive up and down about ten times. Best undercoating in the world.
1975 J-10,360,TH400,QT,
1978 Cherokee Chief,360,TH400,QT with low range,
1998 Wrangler,TJ,4.0L,5spd
1995 Grand Cherokee,ZJ,4.0L, auto
all with a looney DAV behind the wheel.
"Old age and treachery will always overcome youth and skill"
Old 07-15-2012, 12:27 PM
That's good I like that. Gave me a smile.
Old 07-16-2012, 05:12 AM
leadsled01 leadsled01 is offline
Fluid Film is what I use. Used to swear by motor or hydraulic oil but it attacks anything rubber. Fluidfilm actually protects metal and rubber.
engine bay paint vs undercoating 44BZ General FSJ Discussion 14 05-18-2011 04:21 PM
Rust, POR-15, bed liner, undercoating, & sound deadening Tigger4X General FSJ Discussion 2 10-09-2010 11:54 AM
replacing floors - POR-15 and undercoating? elskeptico General FSJ Tech 3 12-22-2009 04:14 PM
Suggestions on undercoating removal? Charlie_B General FSJ Tech 8 09-23-2009 10:11 AM
Undercoating alternatives? UnkleMunky General FSJ Tech 4 04-27-2001 06:33 AM
