Old 07-10-2012, 07:33 AM
Ristow Ristow is online now
J20 goodies.
Old 07-10-2012, 08:10 AM
brushawg's Avatar
brushawg brushawg is offline
Nice, are you going to put it on the front it back?
Just
Expect
Every
Problem
Got to love them
Old 07-10-2012, 08:20 AM
threepiece188 threepiece188 is offline
Is that a parting line through the center of the sprocket case on that PTO and are those three bolts I see that look like they are holding the two halves together?
That looks like a wide spool winch. I had trouble with clearance issues (I think with the steering gear) when installing one on my J20. I swaped in a narrow spool.
I blow my horn before it happens, not after.
A good mechanic can fix their own mistakes.
Waste not war not.
Ignorant is blist.
When you're in a hurry... slow down.
Measure once... cut twice.
Old 07-10-2012, 09:08 AM
it'll go on the front. yah,looks like it bolts together with three bolts.
Old 07-10-2012, 10:46 AM
Nice!
Old 07-10-2012, 03:08 PM
Those winches are junk. You should put it on one of your trucks and send it my way so I can scrap it for you....
If that's a 12" drum winch your good to go, that was what Jeep used as SE for the Saginaw steering rigs. If it's a 14" (what Jeep ran on the Ross rigs) you will have to swap the drum and shaft or off set the winch.
1971 Gladiator J2000 Custom-Cab Platform-Stake Dump
1970 Gladiator J3000 3407Z Camper Truck
1963 Gladiator J300 Thriftside
Visit the Land of Off Topic!
http://gwamp.com/offtopic/index.php
Old 07-10-2012, 03:10 PM
Is that a Koenig PTO? All the Ramsey PTO's I've seen have a cover with many small 1/4" bolts holding it on to the chain case.
Old 07-10-2012, 03:40 PM
tkiller13's Avatar
tkiller13 tkiller13 is offline
Looks like a koenig pto.
chris
Old 07-10-2012, 06:22 PM
yah,i think it says koenig on it.
if my winch is so big and mighty it needs be off set so be it.
Old 07-10-2012, 06:23 PM
may have to throw the 4" springs under it now.....
Old 07-11-2012, 07:23 AM
j20brett's Avatar
j20brett j20brett is offline
Throw yer back out hoistin it up ,eh? Nice lookin winch
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-d44hd front aussie/d60 rear welded - CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy, hp60, 14-bolt, NWF Black Box/NP205, 5.13's, SOA, 42's
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 07-11-2012, 11:48 AM
12" drum. yee-haw!
Old 07-12-2012, 12:50 AM
Gambler68's Avatar
Rabble Rouser
that'd look better on my 68 Gladiator
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 07-12-2012, 12:54 AM
REDONE's Avatar
REDONE REDONE is offline
Fab/Tech Moderator
Nope, 12" drum only fits J-10s. Send me it, I'll give yuh $20 plus shipping. Since you seem like a nice kid.
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 07-12-2012, 01:43 PM
44BZ's Avatar
44BZ 44BZ is offline
Is this PTO setup OE FSJ equipment? I've found a few Ramsey and Koenig PTO units locally, but they're mostly off Willys rigs with a Dana 18. Maybe the Dana 18 PTO units will also work with the Dana 20? I'm very much in the dark
Zack - 68 J2000, AMC 327 w/ Rambler 4bbl and Pertronix upgrade, Holley TA470, T18 4spd, dana 20 (twin sticked), 3" body lift and 38s ~ running AND driving!
J10 vs J20 Frame ? jeephabit3 General FSJ Tech 5 03-30-2012 06:27 PM
J20 steering box and brake booster in a Cherokee rmorit01 General FSJ Tech 5 02-23-2010 08:35 PM
BIG plans for the J20... **CrewCab** Dmntxn77 General FSJ Discussion 26 06-23-2008 11:58 AM
J20 axles in a J10 - Driveshaft ? HOOT General FSJ Tech 5 06-19-2008 08:36 PM
Factory J20 5/4 ton??? Elliott General FSJ Tech 17 09-20-2004 01:55 PM
