Old 05-27-2012, 07:36 PM
jamesdart
Posts: n/a
starter interchange
i found the starter power stud stripped on my 78 wagoneer when i went to change the cable out. when i was looking around online 3 places had pics of the starters and they all looked the same, but my starter looked different. so i was poking around evilbay for some other stuff and saw a starter for a 73 model and it looked like mine i then searched for a 77 starter and it looks like the one i have. whats the difference, is one better than the other? can i use either one? my 78 has a 360 and turbo 400.
Old 05-28-2012, 08:47 AM
You can get a rethreading kit and extend the stud
MOVING SOON! Crusher alert!
Pics of parts for sale stuff: http://tinyurl.com/jimsclads
Old 05-28-2012, 04:16 PM
jamesdart
Posts: n/a
what is this rethreading kit and where do you get it? the starter worked fine.
im tempted to braze the stud and rethread it. there was a little mor ethread on the end so i added an extra lockwasher, it stripped that right off. real soft. nothing like the copper threads on the solenoid studs.
Old 05-29-2012, 07:20 AM
710 Burner's Avatar
AFAIK the starter is the same on the 360 and 401 regardless of which auto transmission you have until they changed to the Mitsubishi starter in '88. Despite being a "Ford" starter in appearance, you cannot use a starter from any Ford. The AMC nosecone is a different lenght.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Old 05-29-2012, 02:11 PM
jamesdart
Posts: n/a
so the nose is the same on the 77 and earlier vs the 78 and later? somewhere around there is the change. the motor end of the cumutator end of the starter is different. the newer one looks better to me, the way the cable attaches to it.
Old 05-30-2012, 01:42 AM
The repair stud was designed for Ford starters. Since I don't work in a parts shop now, I can't access the part #
Possessed starter AMSting General FSJ Tech 7 12-07-2010 09:51 PM
Starter Problem? krmusher General FSJ Tech 20 09-14-2009 07:36 AM
New Starter Binding cpoole General FSJ Tech 4 12-26-2008 08:03 AM
jeep wont start starter ? solenoid? gremlins? westcoastflea General FSJ Tech 7 10-19-2006 07:39 PM
hooked up battery terminals wrong-now just clicking... ctjeepman General FSJ Tech 10 09-18-2004 10:23 PM
