Old 05-27-2012, 03:35 PM
BillyWagoneer's Avatar
BillyWagoneer BillyWagoneer is offline
anyone wanna do me a huge favor?
and plug there vac advance tube into a vac gauge and tell me what your reading or if you know what your supposed to be reading?
87 gwag
De Smogged
Promar Amc 360 Ci
Melling MTA-1 Cam
Edelbrock Double roller Timing set
Proform HEI
Performer Intake
Edelbrock 1826 Thunder series
Holley Red Fuel Pump
40 series flowmaster
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 05-27-2012, 08:51 PM
Rich88's Avatar
Rich88 Rich88 is offline
If you're talking about the vacuum at the hose going to the distributor advance diaphragm and at idle, you'll get -0- if its ported vacuum and anywhere from 15" to 19" if its manifold vacuum, depending on the health of the engine, vacuum leaks (if any) and altitude. For this reason you'll get all kinds of different answers.
88 GW 360-.030 over/2150/727/229/Posi, e-pump, AC (broke), tow package, Monroe Air Shocks, dizzy manifold vacuum, CTO-Free, AIR-free, oil & tranny coolers, dried knuckle blood all over, GM 350 TBI in a box, waiting...
Old 05-27-2012, 09:40 PM
Beach_Dude's Avatar
Beach_Dude Beach_Dude is offline
As Rich said, it's a ported vacuum from your manifold. If you should read the same as everywhere else. Have you done a vacuum test yet anyhow, and what are your readings?
1977 Jeep Cherokee Chief
360 w/ MC 4350
Modified header exhaust w/ported AIR Injection
Slightly modified suspection
Old 05-27-2012, 11:39 PM
well thats weird. i get a reading of about 9 on my vacum advance line. there is a nipple on the manifold itself wich you plug a line that comed of the air filter into. when i plug my vacum gauge into that i get a reading of about 19. any other places i can plug into to see if im getting a good reading? and also if my vac advance line is only getting 9 in. of vacum then i have a leak somewhere?
87 gwag
De Smogged
Promar Amc 360 Ci
Melling MTA-1 Cam
Proform HEI
Performer Intake
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 05-28-2012, 07:35 AM
serehill serehill is offline
Nope
This is about normal & there is a difference because one is ported & one is not. I don't agree is should be zero ported but it should be lower substantialy than non ported. Mine is about 17 non ported & I think about 6 ported.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 05-28-2012, 10:29 AM
Rich88's Avatar
In my previous post (#2) I said you could expect -0- vacuum if you are using ported vacuum for the distributor. And ported vacuum comes from the carb, not the manifold.
Since I'm set up to use manifold vacuum for many years for my distributor, I forgot if ported is 0 at idle or if you should get some low reading. Apparently I was wrong, and as Serehill suggests you should get something. Sorry 'bout that.
Otherwise your reading of 19 at manifold vacuum is good...for manifold.
Old 05-30-2012, 01:02 AM
Near zero at idle with the choke off.
MOVING SOON! Crusher alert!
Pics of parts for sale stuff: http://tinyurl.com/jimsclads
Old 05-30-2012, 01:06 AM
lil jeep mec's Avatar
lil jeep mec lil jeep mec is offline
im getting 16 from the manifold on mine :/ common reasons other than unplugged vac lines?
sorry not trying to take over the thread!
Old 05-30-2012, 06:53 AM
710 Burner's Avatar
If you have the HDCooling system with two CTO valves and an LNR valve controlling the vacuum to the distributor, Yes you will get about 9" at idle... and you can expect all of those valves to be leaking vacuum.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Theres a huge, terrifying snake on my engine! duncanstives General FSJ Tech 9 04-05-2011 08:29 AM
Anyone got Mondays off and wanna go play? banjoguy North West 1 04-04-2011 11:29 PM
Wanna get rid of your JUNK? skinnyD General FSJ Discussion 0 05-16-2010 04:38 AM
Need a 3D favor... Brizio General FSJ Discussion 0 11-21-2009 08:52 PM
Favor: What door latch do you have? shimniok General FSJ Tech 12 01-24-2007 07:06 PM
